GEOFENCING HELP with FONA 808 GPRS/GPS
by amason101070 on Mon Nov 13, 2017 12:38 pm
[My apologies. I did not realize there was a dedicated FONA area in the forums. I have posted this to the Arduino section earlier this morning.
I received the fona 808 gprs + GPS board a couple of weeks ago and love it, but i ran into a snag. Following the directions to setup geofencing from Adafruit I was able to successfully log data in real time as well as view that data in real time on a map block. I don't know what I did, but for some reason I can no longer receive live data through the geo_fencing sketch. If I enter all my APN and IO Key info into the MQTT library, I can see a live feed, but when i enter that same info into the geofencing sketch I get nothing.
Can someone tell me what I have to change/add to the geofencing sketch? I know how to manually create a new feed and dashboard, but for example lets say I wanted to add a new real time feed that I can view on a live map called NYCGPS. What and where would I have to add and edit this in the Geo sketch?
I thank you in advance for any help. I am working on a project that the deadline is coming up quickly and I have hit a snag and panic is starting to set in.
I just checked again and the MQTT connects without issue, but not the geofencing. I am pasting the code i am using below. Thank you in advance for any help. I also changed my actual apn, username and key info, but why i actually have in the code on my end is correct. I say it's correct because MQTT accepts it without issue. Thanks.
Code Below.
Thanks all,
Ron
// Geo Fencing project with Adafruit IO
// Author: Marco Schwartz
// Inspired by the code from Tony DiCola
// Released under a MIT license:
// https://opensource.org/licenses/MIT
// Libraries
#include <Adafruit_SleepyDog.h>
#include <SoftwareSerial.h>
#include "Adafruit_FONA.h"
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_FONA.h"
// Alarm pins
const int ledPin = 6;
// Size of the geo fence (in meters)
const float maxDistance = 100;
// Latitude & longitude for distance measurement
float initialLatitude;
float initialLongitude;
float latitude, longitude, speed_kph, heading, altitude;
// FONA pins configuration
#define FONA_RX              2   // FONA serial RX pin (pin 2 for shield).
#define FONA_TX              3   // FONA serial TX pin (pin 3 for shield).
#define FONA_RST             4   // FONA reset pin (pin 4 for shield)
// FONA GPRS configuration
#define FONA_APN             "MY APN HERE"  // APN used by cell data service (leave blank if unused)
#define FONA_USERNAME        "MY APN HERE"  // Username used by cell data service (leave blank if unused).
#define FONA_PASSWORD        "MY APN HERE"  // Password used by cell data service (leave blank if unused).
// Adafruit IO configuration
#define AIO_SERVER           "www.io.adafruit.com"  // Adafruit IO server name.
#define AIO_SERVERPORT       1883  // Adafruit IO port.
#define AIO_USERNAME         "MY USERNAME HERE"  // Adafruit IO username (see http://accounts.adafruit.com/).
#define AIO_KEY              "MY KEY HERE"  // Adafruit IO key (see settings page at: https://io.adafruit.com/settings).
// Feeds
#define LOCATION_FEED_NAME       "NYCGPS"  // Name of the AIO feed to log regular location updates.
#define MAX_TX_FAILURES      3  // Maximum number of publish failures in a row before resetting the whole sketch.
// FONA instance & configuration
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);     // FONA software serial connection.
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);                 // FONA library connection.
const char MQTT_SERVER[] PROGMEM    = AIO_SERVER;
const char MQTT_USERNAME[] PROGMEM  = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM  = AIO_KEY;
// Setup the FONA MQTT class by passing in the FONA class and MQTT server and login details.
Adafruit_MQTT_FONA mqtt(&fona, MQTT_SERVER, AIO_SERVERPORT, MQTT_USERNAME, MQTT_PASSWORD);
uint8_t txFailures = 0;                                       // Count of how many publish failures have occured in a row.
// Feeds configuration
const char LOCATION_FEED[] PROGMEM = AIO_USERNAME "/feeds/NYCGPS" LOCATION_FEED_NAME "/NYCGPS";
Adafruit_MQTT_Publish location_feed = Adafruit_MQTT_Publish(&mqtt, LOCATION_FEED);
const char BATTERY_FEED[] PROGMEM = AIO_USERNAME "/feeds/battery";
Adafruit_MQTT_Publish battery_feed = Adafruit_MQTT_Publish(&mqtt, BATTERY_FEED);
const char ALERTS_FEED[] PROGMEM = AIO_USERNAME "/feeds/alerts";
Adafruit_MQTT_Publish alerts_feed = Adafruit_MQTT_Publish(&mqtt, ALERTS_FEED);
  // Initialize serial output.
  Serial.begin(115200);
  Serial.println(F("Geofencing with Adafruit IO & FONA808"));
  // Set alarm components
  pinMode(ledPin, OUTPUT);
  // Initialize the FONA module
  Serial.println(F("Initializing FONA....(may take 10 seconds)"));
  fonaSS.begin(4800);
  if (!fona.begin(fonaSS)) {
    halt(F("Couldn't find FONA"));
  fonaSS.println("AT+CMEE=2");
  Serial.println(F("FONA is OK"));
  // Use the watchdog to simplify retry logic and make things more robust.
  // Enable this after FONA is intialized because FONA init takes about 8-9 seconds.
  Watchdog.enable(8000);
  Watchdog.reset();
  // Wait for FONA to connect to cell network (up to 8 seconds, then watchdog reset).
  Serial.println(F("Checking for network..."));
  while (fona.getNetworkStatus() != 1) {
   delay(500);
  // Enable GPS.
  fona.enableGPS(true);
  // Start the GPRS data connection.
  Watchdog.reset();
  fona.setGPRSNetworkSettings(F(FONA_APN));
  //fona.setGPRSNetworkSettings(F(FONA_APN), F(FONA_USERNAME), F(FONA_PASSWORD));
  delay(2000);
  Watchdog.reset();
  Serial.println(F("Disabling GPRS"));
  fona.enableGPRS(false);
  delay(2000);
  Watchdog.reset();
  Serial.println(F("Enabling GPRS"));
  if (!fona.enableGPRS(true)) {
    halt(F("Failed to turn GPRS on, resetting..."));
  Serial.println(F("Connected to Cellular!"));
  // Wait a little bit to stabilize the connection.
  Watchdog.reset();
  delay(3000);
  // Now make the MQTT connection.
  int8_t ret = mqtt.connect();
  if (ret != 0) {
    Serial.println(mqtt.connectErrorString(ret));
    halt(F("MQTT connection failed, resetting..."));
  Serial.println(F("MQTT Connected!"));
  // Initial GPS read
  bool gpsFix = fona.getGPS(&latitude, &longitude, &speed_kph, &heading, &altitude);
  initialLatitude = latitude;
  initialLongitude = longitude;
  // Set alert to 0
  logAlert(0, alerts_feed);
  // Watchdog reset at start of loop--make sure everything below takes less than 8 seconds in normal operation!
  Watchdog.reset();
  // Reset everything if disconnected or too many transmit failures occured in a row.
  if (!fona.TCPconnected() || (txFailures >= MAX_TX_FAILURES)) {
    halt(F("Connection lost, resetting..."));
  // Grab a GPS reading.
  Serial.print("Latitude: ");
  printFloat(latitude, 5);
  Serial.println("");
  Serial.print("Longitude: ");
  printFloat(longitude, 5);
  Serial.println("");
  // Calculate distance between new & old coordinates
  float distance = distanceCoordinates(latitude, longitude, initialLatitude, initialLongitude);
  Serial.print("Distance: ");
  printFloat(distance, 5);
  Serial.println("");
  // Set alarm on?
  if (distance > maxDistance) {
    logAlert(1, alerts_feed);
  // Grab battery reading
  uint16_t vbat;
  fona.getBattPercent(&vbat);
  // Log the current location to the path feed, then reset the counter.
  logLocation(latitude, longitude, altitude, location_feed);
  logBatteryPercent(vbat, battery_feed);
  // Wait 5 seconds
  delay(5000);
// Log alerts
void logAlert(uint32_t alert, Adafruit_MQTT_Publish& publishFeed) {
  // Publish
  Serial.print(F("Publishing alert: "));
  Serial.println(alert);
  if (!publishFeed.publish(alert)) {
    Serial.println(F("Publish failed!"));
    txFailures++;
  else {
    Serial.println(F("Publish succeeded!"));
    txFailures = 0;
// Log battery
void logBatteryPercent(uint32_t indicator, Adafruit_MQTT_Publish& publishFeed) {
  // Publish
  Serial.print(F("Publishing battery percentage: "));
  Serial.println(indicator);
  if (!publishFeed.publish(indicator)) {
    txFailures++;
  else {
    txFailures = 0;
// Serialize the lat, long, altitude to a CSV string that can be published to the specified feed.
void logLocation(float latitude, float longitude, float altitude, Adafruit_MQTT_Publish& publishFeed) {
  // Initialize a string buffer to hold the data that will be published.
  char sendBuffer[120];
  memset(sendBuffer, 0, sizeof(sendBuffer));
  int index = 0;
  // Start with '0,' to set the feed value.  The value isn't really used so 0 is used as a placeholder.
  sendBuffer[index++] = '0';
  sendBuffer[index++] = ',';
  // Now set latitude, longitude, altitude separated by commas.
  dtostrf(latitude, 2, 6, &sendBuffer[index]);
  index += strlen(&sendBuffer[index]);
  dtostrf(longitude, 3, 6, &sendBuffer[index]);
  dtostrf(altitude, 2, 6, &sendBuffer[index]);
  // Finally publish the string to the feed.
  Serial.print(F("Publishing location: "));
  Serial.println(sendBuffer);
  if (!publishFeed.publish(sendBuffer)) {
    txFailures++;
  else {
    txFailures = 0;
// Halt function called when an error occurs.  Will print an error and stop execution while
// doing a fast blink of the LED.  If the watchdog is enabled it will reset after 8 seconds.
void halt(const __FlashStringHelper *error) {
  Serial.println(error);
  while (1) {
    digitalWrite(ledPin, LOW);
    delay(100);
    digitalWrite(ledPin, HIGH);
    delay(100);
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);  // wait 5 seconds
  Serial.println("MQTT Connected!");
void printFloat(float value, int places) {
  // this is used to cast digits
  int digit;
  float tens = 0.1;
  int tenscount = 0;
  int i;
  float tempfloat = value;
    // make sure we round properly. this could use pow from <math.h>, but doesn't seem worth the import
  // if this rounding step isn't here, the value  54.321 prints as 54.3209
  // calculate rounding term d:   0.5/pow(10,places)
  float d = 0.5;
  if (value < 0)
    d *= -1.0;
  // divide by ten for each decimal place
  for (i = 0; i < places; i++)
    d/= 10.0;
  // this small addition, combined with truncation will round our values properly
  tempfloat +=  d;
  // first get value tens to be the large power of ten less than value
  // tenscount isn't necessary but it would be useful if you wanted to know after this how many chars the number will take
  if (value < 0)
    tempfloat *= -1.0;
  while ((tens * 10.0) <= tempfloat) {
    tens *= 10.0;
    tenscount += 1;
  // write out the negative if needed
  if (value < 0)
    Serial.print('-');
  if (tenscount == 0)
    Serial.print(0, DEC);
  for (i=0; i< tenscount; i++) {
    digit = (int) (tempfloat/tens);
    Serial.print(digit, DEC);
    tempfloat = tempfloat - ((float)digit * tens);
    tens /= 10.0;
  // if no places after decimal, stop now and return
  if (places <= 0)
    return;
  // otherwise, write the point and continue on
  Serial.print('.');
  // now write out each decimal place by shifting digits one by one into the ones place and writing the truncated value
  for (i = 0; i < places; i++) {
    tempfloat *= 10.0;
    digit = (int) tempfloat;
    Serial.print(digit,DEC);
    // once written, subtract off that digit
    tempfloat = tempfloat - (float) digit;
// Calculate distance between two points
float distanceCoordinates(float flat1, float flon1, float flat2, float flon2) {
  // Variables
  float dist_calc=0;
  float dist_calc2=0;
  float diflat=0;
  float diflon=0;
  // Calculations
  diflat  = radians(flat2-flat1);
  flat1 = radians(flat1);
  flat2 = radians(flat2);
  diflon = radians((flon2)-(flon1));
  dist_calc = (sin(diflat/2.0)*sin(diflat/2.0));
  dist_calc2 = cos(flat1);
  dist_calc2*=cos(flat2);
  dist_calc2*=sin(diflon/2.0);
  dist_calc +=dist_calc2;
  dist_calc=(2*atan2(sqrt(dist_calc),sqrt(1.0-dist_calc)));
  dist_calc*=6371000.0; //Converting to meters
  return dist_calc;
amason101070
Re: GEOFENCING HELP with FONA 808 GPRS/GPS
by smgs on Wed Nov 15, 2017 6:17 pm
Hey Ron,
Do you need to be outside of the geo fence area you set initially for it to post the live data to your feed?
just a thought.
Simon
smgs
by amason101070 on Wed Nov 15, 2017 9:01 pm
Hi Simon.
I thought about that and changed the default setting from 100 to 10. I bet it's something that is missing or out of place, but unfortunately I am not a programmer so I am at the mercy of the programming world. Thanks for your input though. It is appreciated!
Ron
amason101070
