Can't compile FONA sketch
by Sh0velman on Fri Jan 12, 2018 8:00 am
Greetings, I am trying to compile a (previously working) GPS tracking sketch using the FONA808 breakout and a Feather Huzzah.
I have tried compiling on both Mac and Windows, with differing (but related) error messages reported. I'll attach them in a text file, too many characters to add to post.
Any help would be great, I really need this to work!
FONA_Compile_Errors.txt
(145.44 KiB) Downloaded 113 times
Sh0velman
Re: Can't compile FONA sketch
by adafruit_support_rick on Fri Jan 12, 2018 12:25 pm
If you post the sketch, we can try to reproduce this.
What libraries are you using, and what are the version numbers?
by Sh0velman on Fri Jan 12, 2018 12:48 pm
I can't compile the "FONAtest" sketch with the current required libraries, as installed by the library manager on a freshly installed Arduino IDE on a freshly installed copy of Windows 10. Gets the same exact stack traces dumped.
Compiles fine for an Uno, but not for the Huzzah.
I had this compiling for an M0 Basic as well (but serial comms to the FONA module seems to be a hard nut to crack, so I was trying to revert to the "Proven" route... silly me! :D)
Sh0velman
by adafruit_support_rick on Sun Jan 14, 2018 4:09 pm
Well, looking at the fona library, it just isn't designed to work on an ESP8266. It would have to be modified.
by Sh0velman on Sun Jan 14, 2018 8:53 pm
adafruit_support_rick wrote:Well, looking at the fona library, it just isn't designed to work on an ESP8266. It would have to be modified.
That's wild, because the examples on learn. and my working solution from over a year ago were definitely running just fine on the ESP8266!
If I could get some help tonight on my M0 sketch to see why I can't get the serial to work, despite doing the special steps needed to configure the SERCOMS, it would get me where I need to be, functionally.
Should I open a new thread or can I post the code here?
Sh0velman
by Sh0velman on Mon Jan 15, 2018 3:37 am
Here's the code, just in case you are willing to look at it. There's been a lot of iteration, but this represents the last code/hw configuration that I tried. I still have it wired up like this, so it's easy to try anything you may see that needs to change...
Thanks in advance!
#include <Arduino.h>   // required before wiring_private.h
#include "wiring_private.h" // pinPeripheral() function
#include <Wire.h>
#include <Adafruit_FONA.h>
#include <Adafruit_MQTT_FONA.h>
#include <Adafruit_MQTT.h>
#include <Adafruit_MQTT_Client.h>
Uart fonaSS (&sercom1, 5, 11, SERCOM_RX_PAD_3, UART_TX_PAD_0);
// Battery Status Message variables
long batterySMSLastCheckpoint = 0; //updated every time a message is dispatched.
long batterySMSInterval = 3600000; //in milliseconds.
long runtimeBatterySMSInterval = 500; // don't change this, we're using it as an easy way to send an SMS immediately upon startup. We set it to the interval above after the first cycle.
// Latitude & longitude for distance measurement
float initialLatitude;
float initialLongitude;
float latitude, longitude, speed_kph, heading, altitude;
char *dtostrf (double val, signed char width, unsigned char prec, char *sout) {
  char fmt[20];
  sprintf(fmt, "%%%d.%df", width, prec);
  sprintf(sout, fmt, val);
  return sout;
// FONA pins configuration
#define FONA_RX              12   // FONA serial RX pin (pin 2 for shield).
#define FONA_TX              11   // FONA serial TX pin (pin 3 for shield).
#define FONA_RST             9   // FONA reset pin (pin 4 for shield)
// FONA GPRS configuration
#define FONA_APN             "wholesale"  // APN used by cell data service (leave blank if unused)
#define FONA_USERNAME        ""  // Username used by cell data service (leave blank if unused).
#define FONA_PASSWORD        ""  // Password used by cell data service (leave blank if unused).
// Adafruit IO configuration
#define AIO_SERVER           "io.adafruit.com"  // Adafruit IO server name.
#define AIO_SERVERPORT       1883  // Adafruit IO port.
#define AIO_USERNAME         "Sh0velman"  // Adafruit IO username (see http://accounts.adafruit.com/).
#define AIO_KEY              ""  // Adafruit IO key (see settings page at: https://io.adafruit.com/settings).
// Feeds
#define LOCATION_FEED_NAME       "gps_tracker_location"  // Name of the AIO feed to log regular location updates.
#define BATTERY_FEED_NAME       "gps_tracker_battery"  // Name of the AIO feed to log battery updates
#define WIFI_FEED_NAME       "gps_tracker_wifi"  // Name of the AIO feed to log visible wifi ssid updates.
#define MAX_TX_FAILURES      8  // Maximum number of publish failures in a row before resetting the whole sketch.
// FONA instance & configuration
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);                 // FONA library connection.
// Setup the FONA MQTT class by passing in the FONA class and MQTT server and login details.
Adafruit_MQTT_FONA mqtt(&fona, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
uint8_t txFailures = 0;                                       // Count of how many publish failures have occured in a row.
// Feeds configuration
Adafruit_MQTT_Publish location_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/" LOCATION_FEED_NAME "/csv");
Adafruit_MQTT_Publish battery_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/" BATTERY_FEED_NAME);
  pinMode(11, OUTPUT);
  pinMode(12, INPUT);
  while (!Serial);
  //  This is watchdog code that will monitor the loop and reset the unit if it doesn't respond within a certain time.
  // Initialize serial output.
  Serial.begin(115200);
  Serial.println(F("GPS Tracker Project with Adafruit IO & FONA808"));
  // Initialize the FONA module
  Serial.println(F("Initializing FONA....(may take 10 seconds)"));
  fonaSS.begin(4800);
    pinPeripheral(11, PIO_SERCOM);
   pinPeripheral(12, PIO_SERCOM);
  if (!fona.begin(fonaSS)) {
    halt(F("Couldn't find FONA"));
  fonaSS.println("AT+CMEE=2");
  Serial.println(F("FONA is OK"));
  // Wait for FONA to connect to cell network (up to 8 seconds, then watchdog reset).
  Serial.println(F("Checking for network..."));
  while (fona.getNetworkStatus() != 1) {
    delay(500);
  // Enable GPS.
  fona.enableGPS(true);
  // Start the GPRS data connection.
  fona.setGPRSNetworkSettings(F(FONA_APN));
  //fona.setGPRSNetworkSettings(F(FONA_APN), F(FONA_USERNAME), F(FONA_PASSWORD));
  delay(2000);
  Serial.println(F("Disabling GPRS"));
  fona.enableGPRS(false);
  delay(2000);
  Serial.println(F("Enabling GPRS"));
  if (!fona.enableGPRS(true)) {
    halt(F("Failed to turn GPRS on, resetting..."));
  Serial.println(F("Connected to Cellular!"));
  // Wait a little bit to stabilize the connection.
  delay(3000);
  // Now make the MQTT connection.
  int8_t ret = mqtt.connect();
  if (ret != 0) {
    Serial.println(mqtt.connectErrorString(ret));
    halt(F("MQTT connection failed, resetting..."));
  Serial.println(F("MQTT Connected!"));
  // Initial GPS read
  bool gpsFix = fona.getGPS(&latitude, &longitude, &speed_kph, &heading, &altitude);
  initialLatitude = latitude;
  initialLongitude = longitude;
  // update our timer value at the start of the loop.
//   last_loop = millis();
  // Reset everything if disconnected or too many transmit failures occured in a row.
  if (!fona.TCPconnected() || (txFailures >= MAX_TX_FAILURES)) {
    halt(F("Connection lost, resetting..."));
  // Grab a GPS reading.
  float latitude, longitude, speed_kph, speed_mph, heading, altitude;
  speed_mph = speed_kph * 0.621371192;
  Serial.print("Latitude: ");
  printFloat(latitude, 5);
  Serial.println("");
  Serial.print("Longitude: ");
  printFloat(longitude, 5);
  Serial.println("");
  // Grab battery reading
  uint16_t vbat;
  fona.getBattPercent(&vbat);
  // Log the current location to the path feed, then reset the counter.
  logLocation(latitude, longitude, altitude, speed_mph, location_feed);
  logBatteryPercent(vbat, battery_feed);
  // Wait 30 seconds
  delay(60000);
// Log battery
void logBatteryPercent(uint16_t indicator, Adafruit_MQTT_Publish& publishFeed) {
    char sendBuffer[120];
    memset(sendBuffer, 0, sizeof(sendBuffer));
    int index = 0;
    // Start with '0,' to set the feed value.  The value isn't really used so 0 is used as a placeholder.
//    sendBuffer[index++] = '0';
    sendBuffer[index++] = indicator;
  // Publish
  Serial.print(F("Publishing battery percentage: "));
  Serial.println(indicator);
  // see if it is time to send a battery percentage text to us
  if (millis() > (batterySMSLastCheckpoint + runtimeBatterySMSInterval))
    runtimeBatterySMSInterval = batterySMSInterval;
    sendBatterySMS(indicator);
  if (!publishFeed.publish(sendBuffer)) {
    Serial.println(F("Publish failed!"));
    txFailures++;
  else {
    Serial.println(F("Publish succeeded!"));
    txFailures = 0;
// Serialize the lat, long, altitude to a CSV string that can be published to the specified feed.
void logLocation(float latitude, float longitude, float altitude, float speed_mph, Adafruit_MQTT_Publish& publishFeed) {
  if (!latitude < (float)2.0) {
    // Initialize a string buffer to hold the data that will be published.
    int index = 0;
    sendBuffer[index++] = speed_mph;
    sendBuffer[index++] = ',';
    // Now set latitude, longitude, altitude separated by commas.
    dtostrf(latitude, 2, 6, &sendBuffer[index]);
    index += strlen(&sendBuffer[index]);
    dtostrf(longitude, 3, 6, &sendBuffer[index]);
    dtostrf(altitude, 2, 6, &sendBuffer[index]);
    dtostrf(speed_mph, 2, 2, &sendBuffer[index]);
    // Finally publish the string to the feed.
    Serial.print(F("Publishing location: "));
    Serial.println(sendBuffer);
      txFailures++;
    else {
      txFailures = 0;
  else {
    Serial.println(F("Invalid GPS data. Skipping interval."));
// Halt function called when an error occurs.  Will print an error and stop execution while
// doing a fast blink of the LED.  If the watchdog is enabled it will reset after 8 seconds.
void halt(const __FlashStringHelper *error) {
  Serial.println(error);
  //  while (1) {
  //    digitalWrite(ledPin, LOW);
  //    delay(100);
  //    digitalWrite(ledPin, HIGH);
  //    delay(100);
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);  // wait 5 seconds
  Serial.println("MQTT Connected!");
void printFloat(float value, int places) {
  // this is used to cast digits
  int digit;
  float tens = 0.1;
  int tenscount = 0;
  int i;
  float tempfloat = value;
  // make sure we round properly. this could use pow from <math.h>, but doesn't seem worth the import
  // if this rounding step isn't here, the value  54.321 prints as 54.3209
  // calculate rounding term d:   0.5/pow(10,places)
  float d = 0.5;
  if (value < 0)
    d *= -1.0;
  // divide by ten for each decimal place
  for (i = 0; i < places; i++)
    d /= 10.0;
  // this small addition, combined with truncation will round our values properly
  tempfloat +=  d;
  // first get value tens to be the large power of ten less than value
  // tenscount isn't necessary but it would be useful if you wanted to know after this how many chars the number will take
  if (value < 0)
    tempfloat *= -1.0;
  while ((tens * 10.0) <= tempfloat) {
    tens *= 10.0;
    tenscount += 1;
  // write out the negative if needed
  if (value < 0)
    Serial.print('-');
  if (tenscount == 0)
    Serial.print(0, DEC);
  for (i = 0; i < tenscount; i++) {
    digit = (int) (tempfloat / tens);
    Serial.print(digit, DEC);
    tempfloat = tempfloat - ((float)digit * tens);
    tens /= 10.0;
  // if no places after decimal, stop now and return
  if (places <= 0)
    return;
  // otherwise, write the point and continue on
  Serial.print('.');
  // now write out each decimal place by shifting digits one by one into the ones place and writing the truncated value
  for (i = 0; i < places; i++) {
    tempfloat *= 10.0;
    digit = (int) tempfloat;
    // once written, subtract off that digit
    tempfloat = tempfloat - (float) digit;
void sendBatterySMS(uint16_t battlevel)
  char *matt = "999999999";
  char *mel = "999999999";
  String msghdr = "GPS TRACKER BATTERY: ";
  char msg[120];
  sprintf(msg, "%s  %i%% remaining.", msghdr.c_str(), battlevel);
  fona.sendSMS(matt, msg);
  delay(300);
//   fona.sendSMS(mel, msg);
  delay(300);
  batterySMSLastCheckpoint = millis();
Sh0velman
by adafruit_support_rick on Tue Jan 16, 2018 3:28 pm
I don't think you can use 5 and 11 for RX andTX on sercom1:
The sercom1 example in the tutorial uses 11 and 10:
https://learn.adafruit.com/using-atsamd ... om-already
by Sh0velman on Tue Jan 16, 2018 4:40 pm
Thanks for the reply and information!
I don't have the board in front of me at the moment, but I seem to remember there being a reason I couldn't do 10 and 11. It also makes sense why I could see the TX serial bits on the scope but the RX line was totally flat.
I will check this and circle back.
adafruit_support_rick wrote:I don't think you can use 5 and 11 for RX andTX on sercom1:
Sh0velman
by adafruit_support_rick on Wed Jan 17, 2018 8:37 am
For sercom1, TX can be 10 or 11, and RX can be 10, 11, 12, or 13.
Also, I notice that you're doing the pinPeripheral thing for 11 and 12:
  fonaSS.begin(4800);
by Sh0velman on Thu Jan 18, 2018 6:18 pm
Thanks for looking at that mess. There's a lot of junk in there that shouldn't be, it's a very dirty branch of my git.
Here's the most basic test of this configuration I can think of, and it is not working. It's the basic FONA test using this code: (The serial pins are now configured exactly like the tutorial linked before, fyi)
Also note that if you want to run this code verbatim, you'll need to do a find/replace for `iemi` and replace it with the correct order of letters. This was because the forum's spam filter was catching the post and rejecting it. Sorry for any confusion!
  This is an example for our Adafruit FONA Cellular Module
  Designed specifically to work with the Adafruit FONA
  ----> http://www.adafruit.com/products/1946
  ----> http://www.adafruit.com/products/1963
  ----> http://www.adafruit.com/products/2468
  ----> http://www.adafruit.com/products/2542
  These cellular modules use TTL Serial to communicate, 2 pins are
  required to interface
  products from Adafruit!
THIS CODE IS STILL IN PROGRESS!
Open up the serial console on the Arduino at 115200 baud to interact with FONA
Note that if you need to set a GPRS APN, username, and password scroll down to
the commented section below at the end of the setup() function.
#include "Adafruit_FONA.h"
// #define FONA_RX 2
// #define FONA_TX 3
#define FONA_RST 9
// this is a large buffer for replies
char replybuffer[255];
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
// #include <SoftwareSerial.h>
// SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
// SoftwareSerial *fonaSerial = &fonaSS;
#include <Wire.h>
Uart fonaSerial (&sercom1, 11, 10, SERCOM_RX_PAD_0, UART_TX_PAD_2);
// Hardware serial is also possible!
//  HardwareSerial *fonaSerial = &Serial1;
// Use this for FONA 800 and 808s
// Use this one for FONA 3G
//Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
  while (!Serial);
  Serial.println(F("FONA basic test"));
  Serial.println(F("Initializing....(May take 3 seconds)"));
  fonaSerial.begin(4800);
// fonaSerial.begin(4800);
pinPeripheral(10, PIO_SERCOM);
  if (! fona.begin(fonaSerial)) {
    Serial.println(F("Couldn't find FONA"));
    while (1);
  type = fona.type();
  Serial.print(F("Found "));
  switch (type) {
    case FONA800L:
      Serial.println(F("FONA 800L")); break;
    case FONA800H:
      Serial.println(F("FONA 800H")); break;
    case FONA808_V1:
      Serial.println(F("FONA 808 (v1)")); break;
    case FONA808_V2:
      Serial.println(F("FONA 808 (v2)")); break;
    case FONA3G_A:
      Serial.println(F("FONA 3G (American)")); break;
    case FONA3G_E:
      Serial.println(F("FONA 3G (European)")); break;
    default:
      Serial.println(F("???")); break;
  // Print module iemi number.
  char iemi[15] = {0}; // MUST use a 16 character buffer for iemi!
  uint8_t iemiLen = fona.getiemi(iemi);
  if (iemiLen > 0) {
    Serial.print("Module iemi: "); Serial.println(iemi);
  // Optionally configure a GPRS APN, username, and password.
  // You might need to do this to access your network's GPRS/data
  // network.  Contact your provider for the exact APN, username,
  // and password values.  Username and password are optional and
  // can be removed, but APN is required.
  //fona.setGPRSNetworkSettings(F("your APN"), F("your username"), F("your password"));
  // Optionally configure HTTP gets to follow redirects over SSL.
  // Default is not to follow SSL redirects, however if you uncomment
  // the following line then redirects over SSL will be followed.
  //fona.setHTTPSRedirect(true);
  printMenu();
void printMenu(void) {
  Serial.println(F("-------------------------------------"));
  Serial.println(F("[?] Print this menu"));
  Serial.println(F("[a] read the ADC 2.8V max (FONA800 & 808)"));
  Serial.println(F("[b] read the Battery V and % charged"));
  Serial.println(F("[C] read the SIM CCID"));
  Serial.println(F("[U] Unlock SIM with PIN code"));
  Serial.println(F("[i] read RSSI"));
  Serial.println(F("[n] get Network status"));
  Serial.println(F("[v] set audio Volume"));
  Serial.println(F("[V] get Volume"));
  Serial.println(F("[H] set Headphone audio (FONA800 & 808)"));
  Serial.println(F("[e] set External audio (FONA800 & 808)"));
  Serial.println(F("[T] play audio Tone"));
  Serial.println(F("[P] PWM/Buzzer out (FONA800 & 808)"));
  // FM (SIM800 only!)
  Serial.println(F("[f] tune FM radio (FONA800)"));
  Serial.println(F("[F] turn off FM (FONA800)"));
  Serial.println(F("[m] set FM volume (FONA800)"));
  Serial.println(F("[M] get FM volume (FONA800)"));
  Serial.println(F("[q] get FM station signal level (FONA800)"));
  // Phone
  Serial.println(F("[c] make phone Call"));
  Serial.println(F("[A] get call status"));
  Serial.println(F("[h] Hang up phone"));
  Serial.println(F("[p] Pick up phone"));
  // SMS
  Serial.println(F("[N] Number of SMSs"));
  Serial.println(F("[r] Read SMS #"));
  Serial.println(F("[R] Read All SMS"));
  Serial.println(F("[d] Delete SMS #"));
  Serial.println(F("[s] Send SMS"));
  Serial.println(F("[u] Send USSD"));
  // Time
  Serial.println(F("[y] Enable network time sync (FONA 800 & 808)"));
  Serial.println(F("[Y] Enable NTP time sync (GPRS FONA 800 & 808)"));
  Serial.println(F("[t] Get network time"));
  // GPRS
  Serial.println(F("[G] Enable GPRS"));
  Serial.println(F("[g] Disable GPRS"));
  Serial.println(F("[l] Query GSMLOC (GPRS)"));
  Serial.println(F("[w] Read webpage (GPRS)"));
  Serial.println(F("[W] Post to website (GPRS)"));
  // GPS
  if ((type == FONA3G_A) || (type == FONA3G_E) || (type == FONA808_V1) || (type == FONA808_V2)) {
    Serial.println(F("[O] Turn GPS on (FONA 808 & 3G)"));
    Serial.println(F("[o] Turn GPS off (FONA 808 & 3G)"));
    Serial.println(F("[L] Query GPS location (FONA 808 & 3G)"));
    if (type == FONA808_V1) {
      Serial.println(F("[x] GPS fix status (FONA808 v1 only)"));
    Serial.println(F("[E] Raw NMEA out (FONA808)"));
  Serial.println(F("[S] create Serial passthru tunnel"));
  Serial.println(F(""));
  Serial.print(F("FONA> "));
  while (! Serial.available() ) {
    if (fona.available()) {
      Serial.write(fona.read());
  char command = Serial.read();
  Serial.println(command);
  switch (command) {
    case '?': {
        printMenu();
        break;
    case 'a': {
        // read the ADC
        uint16_t adc;
        if (! fona.getADCVoltage(&adc)) {
          Serial.println(F("Failed to read ADC"));
        } else {
          Serial.print(F("ADC = ")); Serial.print(adc); Serial.println(F(" mV"));
        break;
    case 'b': {
        // read the battery voltage and percentage
        uint16_t vbat;
        if (! fona.getBattVoltage(&vbat)) {
          Serial.println(F("Failed to read Batt"));
        } else {
          Serial.print(F("VBat = ")); Serial.print(vbat); Serial.println(F(" mV"));
        if (! fona.getBattPercent(&vbat)) {
        } else {
          Serial.print(F("VPct = ")); Serial.print(vbat); Serial.println(F("%"));
        break;
    case 'U': {
        // Unlock the SIM with a PIN code
        char PIN[5];
        flushSerial();
        Serial.println(F("Enter 4-digit PIN"));
        readline(PIN, 3);
        Serial.println(PIN);
        Serial.print(F("Unlocking SIM card: "));
        if (! fona.unlockSIM(PIN)) {
          Serial.println(F("Failed"));
        } else {
          Serial.println(F("OK!"));
        break;
    case 'C': {
        // read the CCID
        fona.getSIMCCID(replybuffer);  // make sure replybuffer is at least 21 bytes!
        Serial.print(F("SIM CCID = ")); Serial.println(replybuffer);
        break;
    case 'i': {
        // read the RSSI
        uint8_t n = fona.getRSSI();
        int8_t r;
        Serial.print(F("RSSI = ")); Serial.print(n); Serial.print(": ");
        if (n == 0) r = -115;
        if (n == 1) r = -111;
        if (n == 31) r = -52;
        if ((n >= 2) && (n <= 30)) {
          r = map(n, 2, 30, -110, -54);
        Serial.print(r); Serial.println(F(" dBm"));
        break;
    case 'n': {
        // read the network/cellular status
        uint8_t n = fona.getNetworkStatus();
        Serial.print(F("Network status "));
        Serial.print(n);
        Serial.print(F(": "));
        if (n == 0) Serial.println(F("Not registered"));
        if (n == 1) Serial.println(F("Registered (home)"));
        if (n == 2) Serial.println(F("Not registered (searching)"));
        if (n == 3) Serial.println(F("Denied"));
        if (n == 4) Serial.println(F("Unknown"));
        if (n == 5) Serial.println(F("Registered roaming"));
        break;
    /*** Audio ***/
    case 'v': {
        // set volume
        flushSerial();
        if ( (type == FONA3G_A) || (type == FONA3G_E) ) {
          Serial.print(F("Set Vol [0-8] "));
        } else {
          Serial.print(F("Set Vol % [0-100] "));
        uint8_t vol = readnumber();
        Serial.println();
        if (! fona.setVolume(vol)) {
        } else {
        break;
    case 'V': {
        uint8_t v = fona.getVolume();
        Serial.print(v);
          Serial.println(" / 8");
        } else {
          Serial.println("%");
        break;
    case 'H': {
        // Set Headphone output
        if (! fona.setAudio(FONA_HEADSETAUDIO)) {
        } else {
        fona.setMicVolume(FONA_HEADSETAUDIO, 15);
        break;
    case 'e': {
        // Set External output
        if (! fona.setAudio(FONA_EXTAUDIO)) {
        } else {
        fona.setMicVolume(FONA_EXTAUDIO, 10);
        break;
    case 'T': {
        // play tone
        flushSerial();
        Serial.print(F("Play tone #"));
        uint8_t kittone = readnumber();
        Serial.println();
        // play for 1 second (1000 ms)
        if (! fona.playToolkitTone(kittone, 1000)) {
        } else {
        break;
    /*** FM Radio ***/
    case 'f': {
        // get freq
        flushSerial();
        Serial.print(F("FM Freq (eg 1011 == 101.1 MHz): "));
        uint16_t station = readnumber();
        Serial.println();
        // FM radio ON using headset
        if (fona.FMradio(true, FONA_HEADSETAUDIO)) {
          Serial.println(F("Opened"));
        if (! fona.tuneFMradio(station)) {
        } else {
          Serial.println(F("Tuned"));
        break;
    case 'F': {
        // FM radio off
        if (! fona.FMradio(false)) {
        } else {
        break;
    case 'm': {
        // Set FM volume.
        flushSerial();
        Serial.print(F("Set FM Vol [0-6]:"));
        Serial.println();
        if (!fona.setFMVolume(vol)) {
        } else {
        break;
    case 'M': {
        // Get FM volume.
        uint8_t fmvol = fona.getFMVolume();
        if (fmvol < 0) {
        } else {
          Serial.print(F("FM volume: "));
          Serial.println(fmvol, DEC);
        break;
    case 'q': {
        // Get FM station signal level (in decibels).
        flushSerial();
        Serial.println();
        int8_t level = fona.getFMSignalLevel(station);
        if (level < 0) {
          Serial.println(F("Failed! Make sure FM radio is on (tuned to station)."));
        } else {
          Serial.print(F("Signal level (dB): "));
          Serial.println(level, DEC);
        break;
    /*** PWM ***/
    case 'P': {
        // PWM Buzzer output @ 2KHz max
        flushSerial();
        Serial.print(F("PWM Freq, 0 = Off, (1-2000): "));
        uint16_t freq = readnumber();
        Serial.println();
        if (! fona.setPWM(freq)) {
        } else {
        break;
    /*** Call ***/
    case 'c': {
        // call a phone!
        char number[30];
        flushSerial();
        Serial.print(F("Call #"));
        readline(number, 30);
        Serial.println();
        Serial.print(F("Calling ")); Serial.println(number);
        if (!fona.callPhone(number)) {
        } else {
          Serial.println(F("Sent!"));
        break;
    case 'A': {
        // get call status
        int8_t callstat = fona.getCallStatus();
        switch (callstat) {
          case 0: Serial.println(F("Ready")); break;
          case 1: Serial.println(F("Could not get status")); break;
          case 3: Serial.println(F("Ringing (incoming)")); break;
          case 4: Serial.println(F("Ringing/in progress (outgoing)")); break;
          default: Serial.println(F("Unknown")); break;
        break;
    case 'h': {
        // hang up!
        if (! fona.hangUp()) {
        } else {
        break;
    case 'p': {
        // pick up!
        if (! fona.pickUp()) {
        } else {
        break;
    /*** SMS ***/
    case 'N': {
        // read the number of SMS's!
        int8_t smsnum = fona.getNumSMS();
        if (smsnum < 0) {
          Serial.println(F("Could not read # SMS"));
        } else {
          Serial.print(smsnum);
          Serial.println(F(" SMS's on SIM card!"));
        break;
    case 'r': {
        // read an SMS
        flushSerial();
        Serial.print(F("Read #"));
        uint8_t smsn = readnumber();
        Serial.print(F("\n\rReading SMS #")); Serial.println(smsn);
        // Retrieve SMS sender address/phone number.
        if (! fona.getSMSSender(smsn, replybuffer, 250)) {
          Serial.println("Failed!");
          break;
        Serial.print(F("FROM: ")); Serial.println(replybuffer);
        // Retrieve SMS value.
        uint16_t smslen;
        if (! fona.readSMS(smsn, replybuffer, 250, &smslen)) { // pass in buffer and max len!
          break;
        Serial.print(F("***** SMS #")); Serial.print(smsn);
        Serial.print(" ("); Serial.print(smslen); Serial.println(F(") bytes *****"));
        Serial.println(F("*****"));
        break;
    case 'R': {
        // read all SMS
        uint16_t smslen;
        int8_t smsn;
          smsn = 0; // zero indexed
          smsnum--;
        } else {
          smsn = 1;  // 1 indexed
        for ( ; smsn <= smsnum; smsn++) {
          if (!fona.readSMS(smsn, replybuffer, 250, &smslen)) {  // pass in buffer and max len!
            Serial.println(F("Failed!"));
            break;
          // if the length is zero, its a special case where the index number is higher
          // so increase the max we'll look at!
          if (smslen == 0) {
            Serial.println(F("[empty slot]"));
            smsnum++;
            continue;
        break;
    case 'd': {
        // delete an SMS
        flushSerial();
        Serial.print(F("Delete #"));
        Serial.print(F("\n\rDeleting SMS #")); Serial.println(smsn);
        if (fona.deleteSMS(smsn)) {
        } else {
          Serial.println(F("Couldn't delete"));
        break;
    case 's': {
        // send an SMS!
        char sendto[21], message[141];
        flushSerial();
        Serial.print(F("Send to #"));
        readline(sendto, 20);
        Serial.println(sendto);
        Serial.print(F("Type out one-line message (140 char): "));
        readline(message, 140);
        Serial.println(message);
        if (!fona.sendSMS(sendto, message)) {
        } else {
        break;
    case 'u': {
      // send a USSD!
      char message[141];
      flushSerial();
      uint16_t ussdlen;
      if (!fona.sendUSSD(message, replybuffer, 250, &ussdlen)) { // pass in buffer and max len!
      } else {
        Serial.print(F("***** USSD Reply"));
        Serial.print(" ("); Serial.print(ussdlen); Serial.println(F(") bytes *****"));
    /*** Time ***/
    case 'y': {
        // enable network time sync
        if (!fona.enableNetworkTimeSync(true))
          Serial.println(F("Failed to enable"));
        break;
    case 'Y': {
        // enable NTP time sync
        if (!fona.enableNTPTimeSync(true, F("pool.ntp.org")))
        break;
    case 't': {
        // read the time
        char buffer[23];
        fona.getTime(buffer, 23);  // make sure replybuffer is at least 23 bytes!
        Serial.print(F("Time = ")); Serial.println(buffer);
        break;
    /*********************************** GPS (SIM808 only) */
    case 'o': {
        // turn GPS off
        if (!fona.enableGPS(false))
          Serial.println(F("Failed to turn off"));
        break;
    case 'O': {
        // turn GPS on
        if (!fona.enableGPS(true))
          Serial.println(F("Failed to turn on"));
        break;
    case 'x': {
        int8_t stat;
        // check GPS fix
        stat = fona.GPSstatus();
        if (stat < 0)
          Serial.println(F("Failed to query"));
        if (stat == 0) Serial.println(F("GPS off"));
        if (stat == 1) Serial.println(F("No fix"));
        if (stat == 2) Serial.println(F("2D fix"));
        if (stat == 3) Serial.println(F("3D fix"));
        break;
    case 'L': {
        // check for GPS location
        char gpsdata[120];
        fona.getGPS(0, gpsdata, 120);
          Serial.println(F("Reply in format: mode,longitude,latitude,altitude,utctime(yyyymmddHHMMSS),ttff,satellites,speed,course"));
        else
          Serial.println(F("Reply in format: mode,fixstatus,utctime(yyyymmddHHMMSS),latitude,longitude,altitude,speed,course,fixmode,reserved1,HDOP,PDOP,VDOP,reserved2,view_satellites,used_satellites,reserved3,C/N0max,HPA,VPA"));
        Serial.println(gpsdata);
        break;
    case 'E': {
        flushSerial();
          Serial.print(F("GPS NMEA output sentences (0 = off, 34 = RMC+GGA, 255 = all)"));
        } else {
          Serial.print(F("On (1) or Off (0)? "));
        uint8_t nmeaout = readnumber();
        // turn on NMEA output
        fona.enableGPSNMEA(nmeaout);
        break;
    /*********************************** GPRS */
    case 'g': {
        // turn GPRS off
        if (!fona.enableGPRS(false))
        break;
    case 'G': {
        // turn GPRS on
        break;
    case 'l': {
        // check for GSMLOC (requires GPRS)
        uint16_t returncode;
        if (!fona.getGSMLoc(&returncode, replybuffer, 250))
        if (returncode == 0) {
        } else {
          Serial.print(F("Fail code #")); Serial.println(returncode);
        break;
    case 'w': {
        // read website URL
        uint16_t statuscode;
        int16_t length;
        char url[80];
        flushSerial();
        Serial.println(F("NOTE: in beta! Use small webpages to read!"));
        Serial.println(F("URL to read (e.g. www.adafruit.com/testwifi/index.html):"));
        Serial.print(F("http://")); readline(url, 79);
        Serial.println(url);
        Serial.println(F("****"));
        if (!fona.HTTP_GET_start(url, &statuscode, (uint16_t *)&length)) {
          break;
        while (length > 0) {
          while (fona.available()) {
            char c = fona.read();
            // Serial.write is too slow, we'll write directly to Serial register!
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
            loop_until_bit_is_set(UCSR0A, UDRE0); /* Wait until data register empty. */
            UDR0 = c;
#else
            Serial.write(c);
#endif
            length--;
            if (! length) break;
        Serial.println(F("\n****"));
        fona.HTTP_GET_end();
        break;
    case 'W': {
        // Post data to website
        int16_t length;
        char url[80];
        char data[80];
        flushSerial();
        Serial.println(F("NOTE: in beta! Use simple websites to post!"));
        Serial.println(F("URL to post (e.g. httpbin.org/post):"));
        Serial.println(F("Data to post (e.g. \"foo\" or \"{\"simple\":\"json\"}\"):"));
        readline(data, 79);
        Serial.println(data);
        if (!fona.HTTP_POST_start(url, F("text/plain"), (uint8_t *) data, strlen(data), &statuscode, (uint16_t *)&length)) {
          break;
            UDR0 = c;
#else
            Serial.write(c);
#endif
            length--;
        fona.HTTP_POST_end();
        break;
    case 'S': {
        Serial.println(F("Creating SERIAL TUBE"));
        while (1) {
          while (Serial.available()) {
            delay(1);
            fona.write(Serial.read());
        break;
    default: {
        Serial.println(F("Unknown command"));
        printMenu();
        break;
  // flush input
  flushSerial();
void flushSerial() {
    Serial.read();
char readBlocking() {
  while (!Serial.available());
  return Serial.read();
uint16_t readnumber() {
  uint16_t x = 0;
  char c;
  while (! isdigit(c = readBlocking())) {
    //Serial.print(c);
  Serial.print(c);
  x = c - '0';
  while (isdigit(c = readBlocking())) {
    Serial.print(c);
    x *= 10;
    x += c - '0';
  return x;
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout) {
  uint16_t buffidx = 0;
  boolean timeoutvalid = true;
  if (timeout == 0) timeoutvalid = false;
  while (true) {
    if (buffidx > maxbuff) {
      //Serial.println(F("SPACE"));
      break;
      char c =  Serial.read();
      //Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
      if (c == '\r') continue;
      if (c == 0xA) {
        if (buffidx == 0)   // the first 0x0A is ignored
          continue;
        timeout = 0;         // the second 0x0A is the end of the line
        break;
      buff[buffidx] = c;
      buffidx++;
    if (timeoutvalid && timeout == 0) {
      //Serial.println(F("TIMEOUT"));
      break;
    delay(1);
  buff[buffidx] = 0;  // null term
  return buffidx;
This is all I get when I try to run it. I have a LiPoly battery connected to the FONA module, as required, the `network` light blinks occasionally, but that's all the activity I see.
FONA basic test
Attempting to open comm with ATs
   ---> AT
   ---> AT
   ---> AT
   ---> AT
   ---> AT
Sh0velman
by adafruit_support_rick on Sat Jan 20, 2018 5:39 pm
Works for me. I added the interrupt handler:
#define FONA_RST 9
#include <Wire.h>
uint8_t type;
void SERCOM1_Handler()
  fonaSerial.IrqHandler();
  while (!Serial);
    while (1);
  type = fona.type();
  switch (type) {
    case FONA800L:
    case FONA800H:
    case FONA808_V1:
    case FONA808_V2:
    case FONA3G_A:
    case FONA3G_E:
    default:
  if (iemiLen > 0) {
  printMenu();
  // Phone
  // SMS
  // Time
  // GPRS
  // GPS
  switch (command) {
    case '?': {
        printMenu();
        break;
    case 'a': {
        // read the ADC
        uint16_t adc;
        } else {
        break;
    case 'b': {
        uint16_t vbat;
        } else {
        } else {
        break;
    case 'U': {
        char PIN[5];
        flushSerial();
        readline(PIN, 3);
        } else {
        break;
    case 'C': {
        // read the CCID
        break;
    case 'i': {
        // read the RSSI
        int8_t r;
        break;
    case 'n': {
        Serial.print(n);
        break;
    /*** Audio ***/
    case 'v': {
        // set volume
        flushSerial();
        } else {
        Serial.println();
        } else {
        break;
    case 'V': {
        Serial.print(v);
        } else {
        break;
    case 'H': {
        } else {
        break;
    case 'e': {
        } else {
        break;
    case 'T': {
        // play tone
        flushSerial();
        Serial.println();
        } else {
        break;
    /*** FM Radio ***/
    case 'f': {
        // get freq
        flushSerial();
        Serial.println();
        } else {
        break;
    case 'F': {
        // FM radio off
        } else {
        break;
    case 'm': {
        // Set FM volume.
        flushSerial();
        Serial.println();
        } else {
        break;
    case 'M': {
        // Get FM volume.
        if (fmvol < 0) {
        } else {
        break;
    case 'q': {
        flushSerial();
        Serial.println();
        if (level < 0) {
        } else {
        break;
    /*** PWM ***/
    case 'P': {
        flushSerial();
        Serial.println();
        } else {
        break;
    /*** Call ***/
    case 'c': {
        // call a phone!
        char number[30];
        flushSerial();
        Serial.println();
        } else {
        break;
    case 'A': {
        // get call status
        switch (callstat) {
        break;
    case 'h': {
        // hang up!
        } else {
        break;
    case 'p': {
        // pick up!
        } else {
        break;
    /*** SMS ***/
    case 'N': {
        if (smsnum < 0) {
        } else {
        break;
    case 'r': {
        // read an SMS
        flushSerial();
          break;
        uint16_t smslen;
          break;
        break;
    case 'R': {
        // read all SMS
        uint16_t smslen;
        int8_t smsn;
          smsnum--;
        } else {
            break;
          if (smslen == 0) {
            smsnum++;
            continue;
        break;
    case 'd': {
        // delete an SMS
        flushSerial();
        } else {
        break;
    case 's': {
        // send an SMS!
        flushSerial();
        } else {
        break;
    case 'u': {
      // send a USSD!
      char message[141];
      flushSerial();
      uint16_t ussdlen;
      } else {
    /*** Time ***/
    case 'y': {
        break;
    case 'Y': {
        break;
    case 't': {
        // read the time
        char buffer[23];
        break;
    case 'o': {
        // turn GPS off
        break;
    case 'O': {
        // turn GPS on
        break;
    case 'x': {
        int8_t stat;
        // check GPS fix
        if (stat < 0)
        break;
    case 'L': {
        char gpsdata[120];
        else
        break;
    case 'E': {
        flushSerial();
        } else {
        break;
    case 'g': {
        // turn GPRS off
        break;
    case 'G': {
        // turn GPRS on
        break;
    case 'l': {
        } else {
        break;
    case 'w': {
        // read website URL
        int16_t length;
        char url[80];
        flushSerial();
          break;
            UDR0 = c;
#else
            Serial.write(c);
#endif
            length--;
        break;
    case 'W': {
        int16_t length;
        char url[80];
        char data[80];
        flushSerial();
        readline(data, 79);
          break;
            UDR0 = c;
#else
            Serial.write(c);
#endif
            length--;
        break;
    case 'S': {
        while (1) {
            delay(1);
        break;
    default: {
        printMenu();
        break;
  // flush input
  flushSerial();
    Serial.read();
  uint16_t x = 0;
  char c;
    //Serial.print(c);
  Serial.print(c);
  x = c - '0';
    Serial.print(c);
    x *= 10;
    x += c - '0';
  return x;
  while (true) {
      break;
      if (c == 0xA) {
          continue;
        break;
      buff[buffidx] = c;
      buffidx++;
      break;
    delay(1);
  return buffidx;
by Sh0velman on Sat Jan 20, 2018 5:45 pm
Can you post a basic circuit diagram describing how you have the M0 Basic and FONA808 connected?
Thanks again for all of the help.
Sh0velman
