📬❄️📦Adafruit Holiday Shipping Deadlines 2019: Attention all domestic customers! Please place UPS Ground and USPS First Class & Priority orders by 11am ET Monday December 9, 2019 📬❄️📦 Attention all international customers! Please place all UPS WORLDWIDE EXPRESS; SAVER, and DHL EXPRESS WORLDWIDE orders by 11am ET Monday December 9, 2019 📬❄️📦
Adafruit FONA 808 Shield GPS Problem
by nunosilvarocha on Tue Mar 05, 2019 7:10 pm
I have an Adafruit FONA 808 Shield that has worked perfectly on some tests I've done.
Now i needed the shield again, however the GPS does not work.
I use the Adafruit_FONA Library to do the first tests, the NMEA string is presented but the GPS never fixes the signal (wait more than 1 hour).
I'm doing the outdor tests and using a passive antenna (I already tested the anttena in other modules and it works).
All other functions work correctly.
I have measured the continuity between the antenna connector. Central pin and the SIM808 ok, GND ok.
What could be happening? Can you help?
nunosilvarocha
Re: Adafruit FONA 808 Shield GPS Problem
by adafruit_support_mike on Wed Mar 06, 2019 1:16 am
Post a sample of the raw NMEA sentences after the GPS module has been active for 10-15 minutes please. That will give us a better idea of what it's seeing.
by nunosilvarocha on Wed Mar 06, 2019 5:52 pm
GPS was active +/- 1 hour
Attached is a RAW NMEA print
nunosilvarocha
by adafruit_support_mike on Thu Mar 07, 2019 1:20 am
Thank you.
That says the GPS module only sees one satellite. The most likely reason for that would be a bad connection to the antenna. Double-check to make sure the uFL connector is seated properly and hasn't gotten damaged.
by nunosilvarocha on Thu Mar 07, 2019 5:11 am
I checked the uFL connector again (visual inspection and with the multimeter), cleaned it with isopropyl alcohol.
I checked the antenna connector.
I went back to testing and it's still the same.
nunosilvarocha
by adafruit_support_mike on Fri Mar 08, 2019 1:18 am
In that case, the FONA's GPS module may have been damaged.
When did you get the FONA Shield?
by nunosilvarocha on Fri Mar 08, 2019 6:14 am
I got the shild on 08/2016.
It was little used (about 20 hours), was always well treated and was always well conditioned.
How can I solve my problem?
nunosilvarocha
by adafruit_support_mike on Sat Mar 09, 2019 12:23 am
I'm afraid that's long past our 30-day return/replace period.
Try using other antennas to see if they happen to work better. You might also try a powered GPS antenna to see if that works. You'll need to close the solder jumper next to the uFL jack for the antenna so power reaches the antenna, but that's easy and reversible.
by csutakrichard on Tue Aug 13, 2019 9:44 am
Dear Mike,
I don't want to open a new topic since my question is connected to this one. Earlier you said
I'm not so experienced but enthusiastic. I want to use an active gps antenna. If i'm right I have to solder (red line) these things:
Am I right?
My Fona808 seems a little bit different in the back:
Picture are avaliable in these links too:
https://ibb.co/xGr1gHd
https://ibb.co/1J9Wk2P
Can you help me?
Thank you,
Richard
csutakrichard
by adafruit_support_mike on Tue Aug 13, 2019 9:00 pm
No, the jumper is on the front of the FONA, right next to the antenna jack:
by csutakrichard on Wed Aug 14, 2019 8:44 am
Thank you very much, I'll try solder it.
Richard
csutakrichard
by csutakrichard on Tue Aug 27, 2019 7:28 am
Dear Mike,
I am now here from summer vacation. I tried to solder it, but my Fona seems a little bit different. Earlier I sent photo about back, now I am sending on the front side. Maybe I have other version? I bought it in Hungary.
Can you help me?
Thank you,
Richard
csutakrichard
by adafruit_support_mike on Wed Aug 28, 2019 1:31 am
That's a different version of the FONA.
You don't need to modify any connections to use a powered GPS antenna with the FONA 808.
by csutakrichard on Thu Aug 29, 2019 7:14 am
Thank you very much your response and your kindness
Best regards,
Richard
csutakrichard
by lordjg on Thu Oct 03, 2019 6:45 am
Hello Guys,
I'm having the same issue with the same kind of FONA 808 (the breakout)
is this a suitable antena - https://www.adafruit.com/product/960 + https://www.adafruit.com/product/851 ?
lordjg
