Arduino Nano Every with FONA 808 GPS Compile Errors
by ichasney on Mon Jan 13, 2020 6:46 pm
I recently purchased a FONA 808+GPS for use with an Arduino Nano Every. When compiling the FONAtest sketch I get a lot of compile problems. I'm using 1.8.1 of the IDE and the latest version 1.3.5 of the Adafruit FONA library from the library manager. I've tried with the ATMEGA328 emulator on and off but no effect. I've tried on Mac and a Windows 10 machine with the same results. If I use a start Arduino Uno everything works fine but the different architecture of the Nano Every seems to be causing problems.
It starts out erroring with:
no matching function for call to 'Adafruit_FONA::enableNTPTimeSync(bool, const char [13])'
If this is commented out if moves to a different missing function call:
no matching function for call to 'Adafruit_FONA::HTTP_POST_start(char [80], const char [11], uint8_t*, size_t, uint16_t*, uint16_t*)'
If this is commented out then it goes into a whole bunch of conversion fail errors, full logs attached. Is there anything that can be done? Any work arounds or plans to support the Nano Every board?
NanoEveryFONA808GPSCompileErrors.txt
Output Logs for Compile Errors with Nano Every and FONA 808 + GPS
(113.33 KiB) Downloaded 6 times
ichasney
Re: Arduino Nano Every with FONA 808 GPS Compile Errors
by adafruit_support_mike on Tue Jan 14, 2020 5:00 am
Errors like that are the software equivalent of a marching band hitting a banana peel: only the first to fall is related to the actual cause, everything else is collateral.
In this case, the compiler doesn't like the F() macro, which existed to save RAM on the Arduino Uno. 32-bit microcontrollers don't need it, and don't access Flash memory in the same way, so the macro doesn't work for them.
If you change line 59 of FONAPlatStd.h from this:
typedef const __FlashStringHelper *   FONAFlashStringPtr;
to this:
typedef const char *   FONAFlashStringPtr;
It should make things work.
https://github.com/adafruit/Adafruit_FO ... tStd.h#L59
by ichasney on Sun Jan 26, 2020 3:12 pm
Many thanks for your help Mike, I've persevered with trying to get the Nano Every working with the FONA 808. I've made a little progress and had some success but things are getting a little over my head. It's been a long time since I've done any C++ so I was a bit rusty. Sorry this is a bit of an essay but I better walk through everything I've done.
I followed your advice and replaced the __FlashStringHelper reference as you suggested on line 59 of FONAPlatStd.h and set it to a char.
There were some further compiler problems that I traced back to a problem to line 1518 of the ... The Adafruit_FONA::HTTP_para method didn't seem to accept the int32_t values being parsed to it. So I changed the type from to just int
https://github.com/adafruit/Adafruit_FONA/blob/master/Adafruit_FONA.cpp#L1518
boolean Adafruit_FONA::HTTP_para(FONAFlashStringPtr parameter,
                                 int32_t value) {
becomes
                                 int value) {
Everything then compiled OK.
Try as a might however I couldn't get it to work on SoftwareSerial I tried all sorts of configurations, different pins etc. So I gave up and had a look at using the second hardware serial port Serial1.
I knocked up a simple test sketch to prove my pinouts are working correctly and to prove that on a basic level I could talk to the FONA808, see attached file.
I was able to get a AT OK response and query things like battery state with AT+CBC, stuff like that.
I went to plug back in what I'd learned to the library FONAtest sketch and FONA library itself however the RST pin configuration had me puzzled. I couldn't fathom what it was for exactly. Every time I tried to configure it to a pin the test sketch would not return any OK responses when the sketch connection test ran and just kept restarting. Eventually I commented out the code controlling it.
https://github.com/adafruit/Adafruit_FONA/blob/master/Adafruit_FONA.cpp#L52
  pinMode(_rstpin, OUTPUT);
  digitalWrite(_rstpin, HIGH);
  delay(10);
  digitalWrite(_rstpin, LOW);
  delay(100);
So on to my final problem. When I run the FONATest sketch on Hardware Serial I get responses that look like they should be good, however it falls all the way through the FONA begin function and ends up telling me it can't connect to FONA. Despite a load of traces that say AT > OK, which look like it does have connection.
Looking into this in more detail it seems as though there is a series of functions designed to check and compare the replybuffer with the correct reply. This comparison appears to be failing and I can't understand why.
https://github.com/adafruit/Adafruit_FONA/blob/master/Adafruit_FONA.cpp#L1933
boolean Adafruit_FONA::sendCheckReply(char* send, FONAFlashStringPtr reply, uint16_t timeout) {
  if (! getReply(send, timeout) )
     return false;
  return (prog_char_strcmp(replybuffer, (prog_char*)reply) == 0);
Any assistance you could offer on where to go next would be extremely appreciated, as I'm getting a little out of my depth now.
Cheers
Charlie
HardwareSerialTestFONAArduinoNano.ino
(991 Bytes) Downloaded 3 times
ichasney
by ichasney on Sun Jan 26, 2020 6:01 pm
For reference, here is the output from the Serial Monitor when running FONATest
FONA basic test
Initializing....(May take 3 seconds)
Attempting to open comm with ATs
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
Timeout: No response to AT... last ditch attempt.
---> AT
<--- OK
---> AT
<--- OK
---> AT
<--- OK
---> ATE0
<--- OK
---> ATE0
<--- OK
Couldn't find FONA
ichasney
by ichasney on Mon Jan 27, 2020 1:51 pm
Thinking a bit more about what you said regarding there being no need for the F() functions anymore because accessing flash memory is done differently in this architecture, most of the comparison lines in these functions are comparing values in PROGMEM to values in RAM. Could making them all be in RAM be the way to go I wonder?
ichasney
