🐍 CircuitPython is the easiest way to program microcontrollers now celebrating over 200 boards!🐍
FONA 3G modules from Digikey won't boot
Re: FONA 3G modules from Digikey won't boot
by rskup on Wed Apr 07, 2021 6:49 pm
Me again...not sure if you have drivers installed but the port isn't showing up, or if you're not even able to get the drivers.
Anyways, found this old post where Adafruit put the link to Simcom for drivers and other stuff, scroll to bottom:
viewtopic.php?f=54&t=158486&p=785246&hilit=usb#p785246
rskup
by elin05 on Wed Apr 07, 2021 6:57 pm
I'll be adding that to my list of things to try.
elin05
by elin05 on Wed Apr 07, 2021 11:55 pm
Does the SIM card even need to be in the FONA for the board to boot up?
It would be difficult to solder and unsolder it to my PCB. I'll try soldering temporary jumper wires for connecting to an Arduino with headers.
elin05
by elin05 on Thu Apr 08, 2021 12:15 am
Made some progress. I was able to get the correct drivers installed and now I see the various COM ports available. I can open the AT com port, but I see no output nor does my input seem to do anything.
elin05
by rskup on Thu Apr 08, 2021 10:32 am
Ah, ok, sounds like (without a sim) you're using the FONA 3G just for the gps?
When you say you're not seeing any input/output I'm guessing you're using something like PuTTY or X-CTU (like in the tutorial) to send AT commands to the FONA?
If so, going by my old-brain memory again, in the past when I'm not seeing anything, or seeing goofy characters, it's been because of baud rates. Not sure what your terminal baud rate is at, but try selecting a lower rate.
Not sure how familiar you are with AT commands, so forgive me if I'm stating the obvious, but the easiest one to test with is sending "AT", hopefully you get back "OK" at some point as you lower the baud rate.
rskup
by elin05 on Thu Apr 08, 2021 11:29 pm
I do plan to use a SIM for the cellular network eventually, but I don't have one at the moment.
I am using PuTTY with a baud rate of 115200. It seems like it just isn't echoing my input. I tried typing in "at" and pressing Enter, despite not seeing that input, and was able to get an "OK" response:
Screen Shot 2021-04-08 at 8.09.22 PM.png (16.82 KiB) Viewed 20 times
Anyway, now that I've figured out my board responds to serial AT commands in Direct USB mode, I tried connecting it to my Arduino again. Now I get my original issue again, where the FONA is not responding to my Arduino's AT messages.
elin05
by rskup on Fri Apr 09, 2021 7:23 am
To enable echo, type:
ATE1
and if you ever want to disable echo, type:
ATE0
Ok, now you have it hooked up to the Arduino and no response...let me ask, are you by chance still powering the FONA board with the USB cable?
rskup
