Fona doesn't power on.
Adafruit cellular platform - SMS and IoT over celluar
paperoga
Post by paperoga »
Hi, my problem is that the fona doesn't power on. I tried with lipo battery on another board and it's ok.
adafruit_support_jarek
Re: Fona doesn't power on.
Post by adafruit_support_jarek »
Hi there! Can you please take a picture of your wiring and attach it to a reply so we can take a look?
paperoga
Post by paperoga »
I've attached the photo.
Thanks.
20161130_083407 (Small).jpg (60.1 KiB) Viewed 652 times
It seems like the JST connector on the end of the battery lead is wired incorrectly... in the batteries we sell, the black ground wire is on the left side when looking into the plug: https://www.adafruit.com/products/258
paperoga
Post by paperoga »
Also with the correct polarity the situation doesn't change.
20161202_110917 Send.jpg (128.94 KiB) Viewed 628 times
Can you load and run the FONA Test sketch please: https://learn.adafruit.com/adafruit-fon ... duino-test
Once the Serial Monitor is open, please follow these instructions to get the battery state: https://learn.adafruit.com/adafruit-fon ... ry-voltage
Let us know what you get!
cry4brk
Post by cry4brk »
Did you connect the VIO pin to 5V or 3.3V? did you onnect the KEY to ground or long press the button?
paperoga
Post by paperoga »
Now the Fona starts.
Thanks a lot.
iqnaul
Post by iqnaul »
Hi
I have similar problem, how did you solve it?
tnts
Post by tnts »
He connected power, logic voltage pin and key.
Probably his charging circuit is dead because of wrong battery polarity (look out for that).
KeyWolf
Post by KeyWolf »
But when he LiPo Battery is diconnected or empty.. and u recharge the battery the fona wont start by its self..
u have to use the key-button to restart..
ist there a possibility to restart after power lost of the battery (after recharge)
i tried it with the key pin .. and pulsed it low.. no success
using a teensy 3,2
tnts
Post by tnts »
Not sure but: Ground the key permanentny
Or use reset pin.
KeyWolf
Post by KeyWolf »
did ground the key pin permanently... doesnt work for me either.. :-(
tnts
Post by tnts »
Reset pin now?
KeyWolf
Post by KeyWolf »
if the fona is off.. reset pin isnt usefull.. isn it?
i need to switch fona ON after LiPo change/recharge
Return to “FONA”
