3G GPRS Error
- PabloOyarzo
- adafruit_support_rick
Re: 3G GPRS Error
The FonaTest 'w' command doesn't work on the 3G. AT_HTTPTERM and AT_HTTPINIT are Fona 800/808 commands
- Tkall
Re: 3G GPRS Error
Wow....that could have been written in big red letters somewhere.The FonaTest 'w' command doesn't work on the 3G. AT_
Re: 3G GPRS Error
I'm working on adapting this code to be something simple to do a get or post
// Notes on the AT command functions
// sendReceiveATCommand function send a command to 3G module and only expect for a defined time and waits for the result.
// sendReceiveATCommand2 function send a command to 3G module and compare the result to a given string, when there's a match it stops waiting.
//Send URL Request
Serial.println("\r\nChecking that things are set up now...\r\n");
sendReceiveATCommand("AT+CREG?",2000);
delay(1000);
sendReceiveATCommand("AT+CGSOCKCONT=1,\"IP\",\"internet\"", 4000); // Internet is for the optus WAN
Serial.println("\r\nStarting to send commands...\r\n");
sendReceiveATCommand2("AT+CHTTPACT=\"my.sqlserver\",80", "\r\n+CHTTPACT: REQUEST","\r\nERROR", 5000);
delay(100);
Serial.print("GET /mysqlserver.php?ID=");
Serial.print(AssetID);
Serial.print("&PH=");
Serial.print(UserPhoneNumber);
Serial.print(" HTTP/1.1\r\n");
fonaSS.print("GET /mysqlserver.php?ID=");
fonaSS.print(AssetID);
fonaSS.print("&PH=");
fonaSS.print(UserPhoneNumber);
fonaSS.print(" HTTP/1.1\r\n");
delay(100);
Serial.print("Host: my.sqlserver\r\n");
fonaSS.print("Host: my.sqlserver\r\n");
delay(100);
Serial.print("Connection: close\r\n\r\n");
fonaSS.print("Connection: close\r\n\r\n");
delay(100);
fonaSS.write(0x1A);
delay(100);
} // end of sendPHP
String sendReceiveATCommand(const char *toSend, unsigned long milliseconds)
String result;
Serial.print("Sending: ");
Serial.println(toSend);
fonaSS.println(toSend);
unsigned long startTime = millis();
Serial.print("Received: ");
while (millis() - startTime < milliseconds)
if (fonaSS.available())
char c = fonaSS.read();
Serial.write(c);
result += c; // append to the result string
} // end of if (fonaSS.available())
} // end of while (millis() - startTime < milliseconds)
Serial.println(); // new line after timeout.
return result;
} // end of string
String sendReceiveATCommand2(const char *toSend, const char *toCheck1, const char *toCheck2, unsigned long milliseconds)
char answer_check [3];
String result;
char result_char[50];
Serial.write(c);
result.toCharArray(result_char, 50);
if(strcasestr(result_char,toCheck1) || strcasestr(result_char,toCheck2))
milliseconds = 0;
} // end of if(strcasestr(result_char,toCheck1) || strcasestr(result_char,toCheck2))
} // if (fonaSS.available())
return result;
} // end of string
Re: 3G GPRS Error
Sorry. It does actually warn of this on the product page:Tkall wrote:Wow....that could have been written in big red letters somewhere.The FonaTest 'w' command doesn't work on the 3G. AT_
Please note! We've had a lot of requests for a 3G cell module and we're happy to oblige but this module has many small differences between it and the FONA 800 and 808, so it is not a drop-in replacement! In particular the data functionality is not as easy to use. We are adapting our FONA library to support the 3G chipset and right now we have SMS, calling, and basic functionality working but it will be a while until we get full GPRS TCP/IP and HTTP support. Also, the GPS is not as fast and low-power as the one on the FONA 808. We recommend this module for people who are able to handle a more advanced experience. Beginners will like our FONA 80x series more.
Re: 3G GPRS Error
Yes.Tkall wrote:Is the 800 series 2G?
- Tkall
Re: 3G GPRS Error
The 800 series is 2G and the 2G networks are shutting down. I was using Cricket Wireless and they recently discontinued 2G service so I bought a bunch of the 3G FONA's. I understand the library is in development but I wonder if any progress is being made or if Adafruit did just enough work to bring the 3G to market and then stopped working on it.
Sure I would rather use the box of 800's I already have but I don't have access to the 2G network any longer. So some of us have no choice but to use the 3G FONA and it is tricky trying to plan jobs with vague statements such as:
"it will be a while until we get full GPRS TCP/IP and HTTP support."
- adafruit2
Re: 3G GPRS Error
there is no ETA - the 3G modules from SIMCOM are not easy to use, we haven't found a good way to add all support!
- Tkall
Re: 3G GPRS Error
And there you have it boys and girls, we are on our own.
- adafruit2
Re: 3G GPRS Error
hiya - tkall, please email support@adafruit for a refund on this module. we have no other 3G module at this time.
- Tkall
Re: 3G GPRS Error
I don't want a refund....I just don't want to work any harder than I have to.
Re: 3G GPRS Error
Would it be possible to get a breakdown of where the development is up to and the current stumbling blocks?
