Better antenna for fona
- jimbarstow
I'm using a fona with an SMA connector. In my workshop, I get a lousy signal and it won't connect but 60' away it works fine. I'm using the standard antenna (both straight and right angle). Is there a better antenna I could use that would provide stronger reception?
- tnts
Re: Better antenna for fona
Check the specs of your antenna - what's the <gain> parameter
Find new antenna (passive) with better gain ;)
Or search for schematics how to attach active antenna if power consumption is not a factor for your project
