FONA 3G no GPS Lock
Adafruit cellular platform - SMS and IoT over celluar
gdalgliesh
FONA 3G no GPS Lock
Post by gdalgliesh »
I finally got around to working with my "Adafruit FONA 3G Cellular Breakout - American version" which sadly took a year to the day from purchase.
Everything working accept the GPS being able to lock.I am using "SMA to uFL/u.FL/IPX/IPEX RF Adapter Cable" and "GPS Antenna - External Active Antenna - 3-5V 28dB 5 Meter SMA" from Adafruit and have soldered BIAS pad.
If I am reading the NMEA output correctly I am seeing 16 satellites which should be more than enough.
What am I missing?
AT+CGPS?
+CGPS: 1,1
OK
AT+CGPSINFO
+CGPSINFO:,,,,,,,,
AmpI/AmpQ: 1075/1051
$GPGSV,4,2,16,08,02,323,,10,51,265,,11,,,,12,,,*77
$GPGSV,4,3,16,13,09,036,,14,,,,15,35,054,,16,15,265,*43
$GPGSV,4,4,16,18,74,343,,20,24,059,,21,67,074,,22,,,*49
$GPGGA,150821.1,,,,,0,,,,,,,,*76
$GPVTG,,T,,M,,N,,K,N*2C
$GPRMC,,V,,,,,,,,,,N*53
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPGSV,4,1,16,01,,,,02,,,,05,,,,07,,,*7A
$GPGSV,4,3,16,13,09,036,,14,,,,15,34,053,,16,15,265,*45
$GPGGA,150822.1,,,,,0,,,,,,,,*75
$GPGGA,150823.1,,,,,0,,,,,,,,*74
gdalgliesh
Re: FONA 3G no GPS Lock
Well I know have a lock not sure why since I had left it over night and didn't lock but maybe a pwr cycle I did sorted it. Will see if it is reliable from hear forward.
Khush
Post by Khush »
I have the same problem with my Fona 3G. Not getting any GPS lock. So can you post the power circuit and pictures of soldered BIAS here?
adafruit_support_mike
Just toggle the KEY pin to GND for 2 seconds to turn the FONA off, then again for 2 seconds to turn the FONA back on.
Return to “FONA”
