I get no gps from my fona 5320e
this is what i get :
Adafruit FONA 808 & 3G GPS demo
Initializing FONA... (May take a few seconds)
Attempting to open comm with ATs
---> AT
<--- OK
---> ATE0
<--- OK
---> ATE0
<--- OK
---> AT+CVHU=0
<--- OK
---> ATI
<--- Manufacturer: SIMCOM INCORPORATED
Model: SIMCOM_SIM5320E
Revision: SIM5320E_V1.5
+GCAP: +CGSM,+DS,+ES
OK
---> AT+CPMS="SM","SM","SM"
<--- +CPMS: 5,20,5,20,5,20
---> AT+CGPS=1
<--- ERROR
FONA is OK
Enabling GPS...
---> AT+CGPSPWR?
<--- ERROR
---> AT+CGPSINFO
<--- +CGPSINFO:,,,,,,,,
Waiting for FONA GPS 3D fix...
---> AT+CGPSINFO
PROBLEM
Re: PROBLEM
Hmm.. the output says the 3G module is reporting errors for the commands that turn the GPS module on.
Re: PROBLEM
I don't see anything unusual there.
Are you sure the LiPo is charged? A lot of FONA problems trace back to voltage spikes on the supply lines when the radio tries to talk to the cell tower.
- sa7bi
Re: PROBLEM
i have fully charged my LiPo and i don't see any difference
Re: PROBLEM
Hmm.. try giving the FONA the command "AT+CGPSCOLD". That should force it to completely restart the GPS module.
- sa7bi
Re: PROBLEM
i cant send a command trough serial monitor . So how can i put the command in my code ?
Re: PROBLEM
Don't try sending the command through the Serial Monitor. Add it to your code, which produced the output in your first post of this thread.
- sa7bi
Re: PROBLEM
i have send the command and i don't see any difference.
Adafruit FONA 808 & 3G GPS demo Initializing FONA... (May take a few seconds)
---> AT
<--- AT
---> AT
<--- AT
---> ATE0
<--- ATE0
---> ATE0
<--- OK
---> AT+CVHU=0
<--- OK
---> ATI
OK
<--- +CPMS: 20,20,20,20,20,20
FONA is OK
---> AT+CGPSCOLD
<--- OK
Enabling GPS...
---> AT+CGPSPWR?
<--- ERROR
---> AT+CGPSINFO
---> AT
<--- AT
---> AT
<--- AT
---> ATE0
<--- ATE0
---> ATE0
<--- OK
---> AT+CVHU=0
<--- OK
---> ATI
OK
FONA is OK
---> AT+CGPSCOLD
<--- OK
Enabling GPS...
---> AT+CGPSPWR?
<--- ERROR
---> AT+CGPSINFO
Re: PROBLEM
Okay, the command was sent and accepted.
The SIM5320 doesn't support the 'AT+CGPSPWR' command, so you might as well delete that. Replace the 'AT+CGPS=1' command after the 'AT+CGPSCOLD' and see what that does.
- sa7bi
Re: PROBLEM
I don't see the 'AT+CGPSPWR' command in my code
this my code :
this my code :
#include "Adafruit_FONA.h"
// standard pins for the shield, adjust as necessary
#define FONA_RX 10
#define FONA_TX 11
#define FONA_RST 12
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
// HardwareSerial *fonaSerial = &Serial1;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
// Have a FONA 3G? use this object type instead
//Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
while (! Serial);
Serial.begin(115200);
Serial.println(F("Adafruit FONA 808 & 3G GPS demo"));
Serial.println(F("Initializing FONA... (May take a few seconds)"));
fonaSerial->begin(4800);
if (! fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find FONA"));
while(1);
Serial.println(F("FONA is OK"));
// Try to enable GPRS
Serial.println(F("Enabling GPS..."));
fona.enableGPS(true);
delay(2000);
float latitude, longitude, speed_kph, heading, speed_mph, altitude;
// if you ask for an altitude reading, getGPS will return false if there isn't a 3D fix
boolean gps_success = fona.getGPS(&latitude, &longitude, &speed_kph, &heading, &altitude);
if (gps_success) {
Serial.print("GPS lat:");
Serial.println(latitude, 6);
Serial.print("GPS long:");
Serial.println(longitude, 6);
Serial.print("GPS speed KPH:");
Serial.println(speed_kph);
Serial.print("GPS speed MPH:");
speed_mph = speed_kph * 0.621371192;
Serial.println(speed_mph);
Serial.print("GPS heading:");
Serial.println(heading);
Serial.print("GPS altitude:");
Serial.println(altitude);
} else {
Serial.println("Waiting for FONA GPS 3D fix...");
// Fona 3G doesnt have GPRSlocation :/
if ((fona.type() == FONA3G_A) || (fona.type() == FONA3G_E))
return;
// Check for network, then GPRS
Serial.println(F("Checking for Cell network..."));
if (fona.getNetworkStatus() == 1) {
// network & GPRS? Great! Print out the GSM location to compare
boolean gsmloc_success = fona.getGSMLoc(&latitude, &longitude);
if (gsmloc_success) {
Serial.print("GSMLoc lat:");
Serial.print("GSMLoc long:");
} else {
Serial.println("GSM location failed...");
Serial.println(F("Disabling GPRS"));
fona.enableGPRS(false);
Serial.println(F("Enabling GPRS"));
if (!fona.enableGPRS(true)) {
Serial.println(F("Failed to turn GPRS on"));
Last edited by adafruit_support_mike on Fri Apr 06, 2018 3:23 am, edited 1 time in total.
Reason: added CODE tags
Re: PROBLEM
Try switching over to the 'fonatest' sketch and use the menu commands from that to enable GPS and get a reading. Does the FONA work with that code?
- sa7bi
Re: PROBLEM
no it doesn't work . this what i get
FONA> O
---> AT+CGPSPWR?
<--- ERROR
Failed to turn on
FONA> o
---> AT+CGPSPWR?
<--- ERROR
Failed to turn off
FONA>
+STIN: 25
FONA> O
---> AT+CGPSPWR?
<--- ERROR
Failed to turn on
FONA> o
---> AT+CGPSPWR?
<--- ERROR
Failed to turn off
FONA>
+STIN: 25
Re: PROBLEM
Thank you.. something has to be going wrong at the hardware level.
Do you get the same output when you disconnect the GPS antenna?
- sa7bi
Re: PROBLEM
i have removed the gps antenne and i get the same output.
. Before the green led was always on and red one always blinking but now after a minute they go off why is that??
