GPS Tracker Using Fona808 Shield NOT WORKING! Help
- Remix23
Re: GPS Tracker Using Fona808 Shield NOT WORKING! Help
Hi, no I haven't yet, as like said it may be the API which I am unsure how to change so I'll have to use adafruit.io instead of freeboard.io through another code. I'll have to take parts out of the code for that. It's a nightmare
- Remix23
Can someone please help me implement io.adafruit dashback into my code rather than Dweet.io. asap
- Remix23
Guys, I really need some help asap please. I've tried everything. GPS Test code works, i get my location but won't send the data to the website using my code, it worked before.
The code doesn't seem to be related to the hardware, or to the software handling communication between the microcontroller and the FONA. It seems to be a protocol issue related to the way the data gets sent to the online service where you want to display it.
The best suggestion I can give you is to back out from the existing code and write the simplest code you can that sends a hard-coded block of data to the online service, and focus on getting that to work. That will eliminate most of the distractions created by other parts of the code.
Once you have the microcontroller sending information to the online service in general, you can start playing around with the kinds of message you send. You should be able to work your way up to hard-coded GPS data, then switch over to values taken from the GPS module in real time.
The fact that the code worked at one time is njo longer relevant to what you're trying to do. If that was the controlling issue, the same code would still work now. The fact that the existing code doesn't work now means something has changed, and you need to find out what will work now.
- Remix23
I believe I have if we read the previous comments.
I was requesting help on implementing io.adafruit dashboard to my code so I can use that to have my dashboard such as Google maps as I do with freeboard.io.
I want to remove dweet.io which is what sends the data to the dashboard freeboard.io.... instead I want to use io.adafruit as I do not know how to change and apis or why it won't send data to it.
So require assistance to implement this to my code. I have checked websites and pdf about it but need help with my specific code.
Thank you
Thank you
Post the code you have now and we'll take a look. What's the last thing it does correctly before the first thing that doesn't work the way it should?
- Remix23
// Libraries
#include "Adafruit_FONA.h"
#include <SoftwareSerial.h>
// Pins
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
// Dweet.io Thing
String dweetThing = "hellobob";
// Variables
boolean GPSloc;
// Instances
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
while (!Serial);
Serial.begin(115200);
Serial.println(F("FONA GPS tracker"));
Serial.println(F("Initializing....(May take 3 seconds)"));
fonaSerial->begin(4800);
if (! fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find FONA"));
while(1);
Serial.println(F("FONA is OK"));
// Setup GPRS APN (username/password optional)
fona.setGPRSNetworkSettings(F("uk.lebara.mobi"), F("wap"), F("wap"));
//fona.setGPRSNetworkSettings(F("your_APN"), F("your_username"), F("your_password"));
// GPS
Serial.println(F("[O] Turn GPS on (FONA 808 & 3G)"));
Serial.println(F("[o] Turn GPS off (FONA 808 & 3G)"));
Serial.println(F("[L] Query GPS location (FONA 808 & 3G)"));
if (!fona.enableGPS(true)) {
Serial.println(F("Failed to turn on GPS"));
// Turn GPRS on
fona.enableGPRS(true);
// Decide between GPS or GPRS location
int8_t stat;
// Check GPS fix
stat = fona.GPSstatus();
if (stat < 0) {
GPSloc = false;
if (stat == 0 || stat == 1) {
GPSloc = false;
if (stat == 2 || stat == 3) {
GPSloc = true;
// Print which location method is used
Serial.print("Location method: ");
if (GPSloc) {Serial.println("GPS");}
else {Serial.println("GPRS");}
// Location variables
String location;
String latitude;
String longitude;
double latitudeNumeric;
double longitudeNumeric;
// Get location
if (GPSloc) {
location = getLocationGPS();
latitude = getLatitudeGPS(location);
longitude = getLongitudeGPS(location);
latitudeNumeric = convertDegMinToDecDeg(latitude.toFloat());
longitudeNumeric = convertDegMinToDecDeg(longitude.toFloat());
else {
location = getLocationGPRS();
latitude = getLatitudeGPRS(location);
longitude = getLongitudeGPRS(location);
latitudeNumeric = latitude.toFloat();
longitudeNumeric = longitude.toFloat();
Serial.print("Latitude, longitude: ");
Serial.print(latitudeNumeric, 6);
Serial.print(",");
Serial.println(longitudeNumeric, 6);
// Prepare request
uint16_t statuscode;
int16_t length;
char url[80];
String request = "www.dweet.io/dweet/for/" + dweetThing + "?latitude=" + String(latitudeNumeric) + "&longitude=" + String(longitudeNumeric);
request.toCharArray(url, request.length());
// Send location to Dweet.io
if (!fona.HTTP_GET_start(url, &statuscode, (uint16_t *)&length)) {
Serial.println("Failed!");
while (length > 0) {
while (fona.available()) {
char c = fona.read();
// Serial.write is too slow, we'll write directly to Serial register!
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
loop_until_bit_is_set(UCSR0A, UDRE0); /* Wait until data register empty. */
UDR0 = c;
#else
Serial.write(c);
#endif
length--;
fona.HTTP_GET_end();
// Wait for 10 seconds before next location
Serial.println(F("Waiting until next message..."));
delay(10000);
String getLocationGPRS() {
// Buffer for reply & returncode
char replybuffer[255];
uint16_t returncode;
// Get & return location
if (!fona.getGSMLoc(&returncode, replybuffer, 250))
return String("Failed!");
if (returncode == 0) {
return String(replybuffer);
} else {
return String(returncode);
String getLocationGPS() {
// Buffer
char gpsdata[255];
// Get data
fona.getGPS(0, gpsdata, 255);
return String(gpsdata);
String getLatitudeGPS(String data) {
// Find commas
int commaIndex = data.indexOf(',');
int secondCommaIndex = data.indexOf(',', commaIndex+1);
int thirdCommaIndex = data.indexOf(',', secondCommaIndex+1);
return data.substring(commaIndex + 1, secondCommaIndex);
String getLongitudeGPS(String data) {
// Find commas
return data.substring(secondCommaIndex + 1, thirdCommaIndex);
String getLongitudeGPRS(String data) {
// Find commas
return data.substring(0, commaIndex);
String getLatitudeGPRS(String data) {
// Find commas
double convertDegMinToDecDeg (float degMin) {
double min = 0.0;
double decDeg = 0.0;
//get the minutes, fmod() requires double
min = fmod((double)degMin, 100.0);
//rebuild coordinates in decimal degrees
degMin = (int) ( degMin / 100 );
decDeg = degMin + ( min / 60 );
return decDeg;
- Remix23
Need help today :(
Add Serial.print() statements in the code where you take the raw output from the GPS module and format it for transmission across the network. Work your way along, printing every intermediate value until you find the place where you get output you don't expect. That will help you zero in on the code that's causing the problem.
