cannot send sms
cannot send sms
by fredpet on Wed Feb 13, 2019 6:42 pm
hi folks,
im using adafruit feather 32u4 FONA.
with the testsketch 'FONAtest' you can really test a lot of functions of the gsm-module.
some have i tested - they work fine.
its possible for me to
- setup phone calls
- receive phone calls
- receive sms.
i have a very good signal strength (otherwise the above functions wouldnt be possible) and a lipoly for powering the gsm-module peaks. antenna connected.
whats not possible for me is, to send SMS.
it appears:
'''''''''''' serial monitor:
FONA> s (sende sms)
Send to #0650990xxxx
Type out one-line message (140 char): mytext
---> AT+CMGF=1
<--- OK
---> AT+CMGS="0650990xxxx"
> mytext
^Z
Failed
FONA>
ERROR
anyone an idea to help me solve this problem?
many thanks in advance fredp
fredpet
Re: cannot send sms
by adafruit_support_mike on Sat Feb 16, 2019 3:00 am
If the other features work, and you're using the FonaTest sketch, the most likely reason for the failure would be limitations on the cell plan for your SIM card.
At least check with your provider and see if they have any idea why outgoing SMS might fail.
Re: cannot send sms
by fredpet on Sat Feb 16, 2019 2:48 pm
dear mike,
thanks for your response!!
meanwhile I've tested the following:
a) using the sim in an ordinary smartphone - it can send and receive sms normally.
b) when using the sim in the FONA, sometimes(!!!) its posssible to send short sms (about 4 letters or so - cannot get any context) - BUT:
the receiving phone gets the message '>inhalt wird nicht unterstützt>> (content not supported).
with your reply you helped me on the right way and I did the following:
c) I changed the sim to another one from another provider. ==> now IT WORKS perfectly!!!!! (including the german 'umlauts' (diacrytic symbols))
thanks a lot!
fred
fredpet
Re: cannot send sms
by adafruit_support_mike on Sun Feb 17, 2019 2:45 am
Glad to hear you got it working. Happy hacking!
