📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
fona 808 shield only recognize first call
by cuevas957 on Sat Aug 24, 2019 4:58 pm
need help.
im using
fona 808 shield
arduino uno
lypo battery
using the example code "IncomingCall.ino" only change the connection pins
from
#define FONA_RX 3
#define FONA_TX 4
#define FONA_RST 5
to
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
Im not sure, but I could swear that uses to recognize several calls, but now, only recognize the first time I call the number, then nothing else happens when I call.
i was working with fona library, I replace whith the original library and doesn't make any other changes in IncomingCalls.ino
Help me pease, don't know If I have to make some kind of reset to the shield or some thing like that.
thanks
IncomingCall.ino
// FONA Incoming Call Number Example
// Listens for a call and displays the phone number of the caller (if available).
// Use this example to add phone call detection to your own FONA sketch.
#include "Adafruit_FONA.h"
// Pins which are connected to the FONA.
// Note that this is different from FONAtest!
#define FONA_RX            2
#define FONA_TX            3
#define FONA_RST           4
// Note you need to map interrupt number to pin number
// for your board.  On an Uno & Mega interrupt 0 is
// digital pin 2, and on a Leonardo interrupt 0 is
// digital pin 3.  See this page for a complete table:
//   http://arduino.cc/en/Reference/attachInterrupt
// Make sure this interrupt pin is connected to FONA RI!
#define FONA_RI_INTERRUPT  0
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
//  HardwareSerial *fonaSerial = &Serial1;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
  Serial.begin(115200);
  Serial.println(F("FONA incoming call example"));
  Serial.println(F("Initializing....(May take 3 seconds)"));
  fonaSerial->begin(4800);
  if (! fona.begin(*fonaSerial)) {
    Serial.println(F("Couldn't find FONA"));
    while(1);
  Serial.println(F("FONA is OK"));
  // Enable incoming call notification.
  if(fona.callerIdNotification(true, FONA_RI_INTERRUPT)) {
    Serial.println(F("Caller id notification enabled."));
  else {
    Serial.println(F("Caller id notification disabled"));
void loop(){
  // Create a small string buffer to hold incoming call number.
  char phone[32] = {0};
  // Check for an incoming call.  Will return true if a call is incoming.
  if(fona.incomingCallNumber(phone)){
    Serial.println(F("RING!"));
    Serial.print(F("Phone Number: "));
    Serial.println(phone);
cuevas957
Re: fona 808 shield only recognize first call
by adafruit_support_mike on Sun Aug 25, 2019 12:28 pm
Try using the ‘fonatest’ sketch that comes with the FONA library. Does that work the way it should?
by cuevas957 on Sun Aug 25, 2019 2:11 pm
first off all. thanks for your reply.
And yes, the fonatest code works fine, but its different
- incomingcall.ino works with interruption
- fonatest.ino dont, in fonatest.ino just print from fona incoming
while (fona.available()) {
      Serial.write(fona.read());
i have being trying with the fonatest code to detect a call and parse the telephone number when a call is detected, but I can't make it work.
when I have a call in fonatest.ino the serial monitor bring that:
/////////////SERIAL MONITOR/////////////////
RING
+CLIP: "656969585",161,"",0,"",0
cuevas957
by cuevas957 on Sun Aug 25, 2019 3:24 pm
SOLVED!!
post the code if anybody need it or someone know how to optimize or another better way to do the same
String s;
void setup()
s.reserve(100);
void loop()
  char c;
  int i = 0;
    c = fona.read();
    Serial.write(c);
    if (c != 0xA)
      s += c;
    else
      if (s.indexOf("RING") != -1)
        Serial.println("INCOMING CALL");
        fona.hangUp();
      s = "";
cuevas957
by adafruit_support_mike on Wed Aug 28, 2019 12:08 am
Glad to hear you got things working. Happy hacking!
