Adafruit Fona library for Arduino Uno Wifi Rev2
Adafruit cellular platform - SMS and IoT over celluar
mahmoodalam
Post by mahmoodalam »
I have the "Adafruit FONA 808 Shield - Mini Cellular GSM + GPS for Arduino". I want to use this shield on Arduino Uno Wifi Rev2. Where can I find the supporting fona library ?
Thanks.
mahmoodalam
Re: Adafruit Fona library for Arduino Uno Wifi Rev2
The Adafruit Fona library mentioned by you is working for the Arduino Uno and not Arduino Uno Wifi Rev2. With the later it is giving compilation errors, shown in the file attached. Can you help me in identifying the errors and fixing them.
FonaLibraryErrorMessagesUnoWiFiRev2.txt
(71.61 KiB) Downloaded 19 times
adafruit_support_mike
Oh lovely.. the Arduino board support package disabled the F() macro, which broke all the relevant type declarations in the FONA library.
You should be able to work around most of the trouble by changing this line of FONAPlatStd.h
https://github.com/adafruit/Adafruit_FO ... tStd.h#L59
to this:
typedef const char *	FONAFlashStringPtr;
And then you'll have to change this part of the header:
https://github.com/adafruit/Adafruit_FO ... #L202-L207
to convert all the string storage to type 'const char*':
  const char apn[ 4 ];
for instance.
Return to “FONA”
