antenna patch
I have tried the LiPo battery and I have also used an external power supply set to max 4.45 volts DC @ a max AMP of 2.25
VBATT to GND reads 4.33 VDC
Please see attached pictures and included sketch with the I.M.E.I section removed due to restrictions of forums.
It is my hope you can help me see the error in my ways and find a solution caused by an ID10t error and not a hardware issue.
Many thanking Ewes'
J
This is an example for our Adafruit FONA Cellular Module
since the FONA 3G does not do auto-baud very well, this demo
fixes the baud rate to 4800 from the default 115200
Designed specifically to work with the Adafruit FONA 3G
----> http://www.adafruit.com/products/2691
----> http://www.adafruit.com/products/2687
These cellular modules use TTL Serial to communicate, 2 pins are
required to interface
products from Adafruit!
#include "Adafruit_FONA.h"
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
// this is a large buffer for replies
char replybuffer[255];
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
//#include <SoftwareSerial.h>
//SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
//SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
HardwareSerial *fonaSerial = &Serial1;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
while (!Serial);
Serial.begin(9600);
Serial.println(F("FONA set baudrate"));
Serial.println(F("First trying 115200 baud"));
// start at 115200 baud
fonaSerial->begin(115200);
fona.begin(*fonaSerial);
// send the command to reset the baud rate to 4800
fona.setBaudrate(4800);
// restart with 4800 baud
fonaSerial->begin(4800);
Serial.println(F("Initializing @ 4800 baud..."));
if (! fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find FONA"));
while (1);
Serial.println(F("FONA is OK"));
