I have purchased 3 "FONA 3G Cellular + GPS Breakout" boards over the last several months. I am using these in the "Rotary Cell Phone" project designed by Justine Haupt. The battery I use in the project is the one recommended (Adafruit product 258) and this battery has never been connected incorrectly. I have now had two of these boards fail with what seems to be burn out of the the MCP73831 LiPo charger. The first failure I attributed to perhaps shorting something inadvertently (not that I thought I did that) and it wasn't clear to me that the LiPo chip was at fault. But, with a second one now failing, I investigated a bit and realize that the boards are functional with the exception of the LiPo chips, which have failed. My phone build is complete and the phone is/was functional but I've been debugging software on the phone. I don't believe I've done anything "wrong" and have only had the boards connected to computer Usb ports for debugging the phone software. The failure is that the battery just stops charging. I've discussed this issue in the Rotary Cellphone forum (may need to request access):
http://skysedge.us/forum/viewtopic.php?f=4&t=1496
It was recommended there that I contact Adafruit and request exchange/repair of these parts. It was also recommended that I request, if possible, the current programming resistor (R3) be changes from 2k to 3k.
Thanks for any help you can provide!
