Can't get fona to communicate with raspberry pi
by Abhireddy526 on Sun Aug 02, 2020 7:31 am
Hi I'm basically working on a project which requires an adafruit fona ufl version to communicate with the raspberry pi, the font is being powered with a 1200mah lithium ion battery. I have soldered rx on the fona to tx on the pi, tx on the fona to rx on the pi and vio on the fona to pin 1 (3.3v) on the pi. I've also installed minicom onto the raspberry pi and then I enter 'sudo minicom -D /dev/ttyAMA0 -b 9600' into the terminal. Then I get taken to a serial terminal which is perfect but then I can't type anything meaning I can't type AT and I can't get a response to tell me whether my fona is communicating properly with the raspberry pi or not. Does anybody know why this is happening, I have checked my connections properly by the way. Any help is appreciated thank you.
Abhireddy526
Re: Can't get fona to communicate with raspberry pi
by adafruit_support_carter on Mon Aug 10, 2020 10:12 am
Hey, sorry for the delayed response.
Please post a photo of your setup showing how everything is connected so we can look for any obvious hardware issues.
by Abhireddy526 on Mon Aug 10, 2020 10:56 am
Hi, thanks for replying im trying to upload the photo but apparently there's a maximum file size of 1mb and my photo is well over that so how would you like me to show you the photo?
Abhireddy526
by adafruit_support_carter on Mon Aug 10, 2020 11:25 am
You can resize it down. We don't need super hi res. 800x600 would be OK.
by Abhireddy526 on Mon Aug 10, 2020 4:35 pm
There are my main connections yo do with the font if you need an other photos or if you need me to zoom on any parts just ask and ill send the pictures. Thank you
Abhireddy526
by adafruit_support_carter on Tue Aug 11, 2020 10:51 am
This is most likely some form of wiring or other connection issue.
Can you back up and make a more direct connection between the Fona and the Pi more like this guide:
https://learn.adafruit.com/fona-tetheri ... i-758908-2
by Abhireddy526 on Wed Aug 12, 2020 5:14 am
Hi, thank you for the help, I have followed adafruit's fona setup and I've connected all the necessary wires, however I am unable to turn the fona on when I hold the key button for 2 seconds. None of the LEDs come on or flash at all. Do you know why this is happening, because obviously if it doesn't turn on I won't be able to connect it with the raspberry pi
Thank you
Abhireddy526
by adafruit_support_carter on Wed Aug 12, 2020 11:14 am
Have you reconnected with the simple and direct wiring shown in the guide linked? Or are you still wired per the more complex arrangement in your photos above?
by Abhireddy526 on Wed Aug 12, 2020 11:17 am
I've reconnected with the simple wiring so just with raspberry pi and fona I've removed all the other parts.
Abhireddy526
by adafruit_support_carter on Wed Aug 12, 2020 11:29 am
OK, please post a photo of the latest setup showing how everything is wired together.
by Abhireddy526 on Wed Aug 12, 2020 11:40 am
Here
Abhireddy526
by Abhireddy526 on Tue Sep 08, 2020 4:57 pm
Hi I've posted the photos do you know what is the problem now?
Abhireddy526
by adafruit_support_carter on Tue Sep 08, 2020 5:05 pm
This is still most likely a connection issue. Jumper wires, or a something like a cobbler breakout:
https://www.adafruit.com/product/2028
would be better than soldering directly to the Pi's header pins. The soldering in general looks like it might be cold and under soldered in various locations:
https://learn.adafruit.com/adafruit-gui ... n-problems
by Abhireddy526 on Sat Sep 26, 2020 7:35 am
Okay, thank you very much. However, could you pleas explain to me how to use the cobbler breakout, so that I can connect it from my raspberry pi to to my fona. Thank you
Abhireddy526
by adafruit_support_carter on Mon Sep 28, 2020 1:17 pm
Female/Female Jumper Wires:
https://www.adafruit.com/category/468
would allow you to connect between the male headers on the Pi and Fona. Soldering of the headers on the Fona must be good though.
The cobbler breakout could be used in conjunction with a breadboard:
https://www.adafruit.com/category/124
and male/male jumpers wires:
https://www.adafruit.com/category/471
to stage everything on the breadboard.
