AT+CDNSCFG not working
by justpierre on Sun Sep 13, 2020 8:46 am
Hi Guys,
I'm having some issue with my DNS when I want to use the AT+FTPGET=1 command (it returns +FTPGET: 1,62).
I'm trying to update my DNS using the command :
AT+CDNSCFG="8.8.8.8","8.8.4.4"
ERROR
but it doesn't work and I keep received an error message.
At the moment my DNS is
AT+CDNSCFG?
PrimaryDns: 0.0.0.0
SecondaryDns: 0.0.0.0
Anyone can help me with that??
(ps: I'm using a SIM800H)
Thanks,
Pierre.
justpierre
Re: AT+CDNSCFG not working
by rskup on Sun Sep 13, 2020 11:11 am
Just a quick (possibly useless) thought...is the APN info set(AT+CGDCONT=...)?
rskup
by justpierre on Sun Sep 13, 2020 11:46 am
I'm not too sure.. I used the function AT+SAPBR to configure my APN.
The result I had:
AT+SAPBR=2,1
OK
+SAPBR: 1,1,"10.147.43.2"
justpierre
by rskup on Sun Sep 13, 2020 12:47 pm
Hmmm, have not seen that command before.
I don't have an 800, I have the 5320 (FONA 3G), but I do see that the CGDCONT command is in the 800 manual.
So when you type:
AT+CGDCONT?
do you get anything?
rskup
by justpierre on Sun Sep 13, 2020 1:07 pm
I have this result:
AT+CGDCONT?
+CGDCONT: 1,"IP","giffgaff,.com","0.0.0.0",0,0
+CGDCONT: 2,"IP","","0.0.0.0",0,0
+CGDCONT: 3,"IP","","0.0.0.0",0,0
my APN should be giffgaff.com and not giffgaff, .com it might related to the issue I'm having then.
I tried to update by doing this :
AT+CGDCONT=1,"giffgaff.com"
ERROR
But that's not working...
justpierre
by rskup on Sun Sep 13, 2020 1:27 pm
I think you need to do this:
AT+CGDCONT=1,"IP","giffgaff.com"
rskup
by justpierre on Sun Sep 13, 2020 1:36 pm
It's the same.. I keep getting an error.
AT+CLTS=1
OK
AT+CIPSHUT
SHUT OK
AT+CGATT=1
OK
AT+SAPBR=3,1,"CONTYPE","GPRS"
OK
AT+SAPBR=3,1,"APN","giffgaff.com"
OK
AT+CSTT="giffgaff.com","giffgaff"
OK
AT+SAPBR=3,1,"USER","giffgaff"
OK
AT+SAPBR=1,1
OK
AT+SAPBR=2,1
+SAPBR: 1,1,"10.148.70.28"
AT+CCLK?
+CCLK: "20/09/13,18:23:33+04"
AT+CGDCONT?
ERROR
justpierre
by rskup on Sun Sep 13, 2020 1:51 pm
Hmmm, ok, thought the shorter version might work (saw in a couple examples), adding the 0.0.0.0 now (which is how I entered it for my 5320).
Try:
AT+CGDCONT=1,"IP","giffgaff.com","0.0.0.0"
edit...just saw something searching online, since you issued the command SAPBR = 1,1 (open bearer) earlier, it may not allow you to edit this.
Try closing it first, SAPBR = 0,1
rskup
by justpierre on Sun Sep 13, 2020 2:22 pm
I think I found the issue!
I was using the example code on arduino name: FONAtest.
It's possible using the serial monitor of the Arduino software to create a Serial passthru tunnel and send AT commands.
Instead, I tried to communicate directly to the FONA with the UART USB cable and this time I'm able to update the DNS settings !!
I think the issue is coming from the code on the arduino not letting me sending the right AT command.
Thanks for the help!
justpierre
by rskup on Sun Sep 13, 2020 2:27 pm
Ok, cool, hope all goes well!
rskup
