Feather 32u4 FONA AT+CBC value to sms
by Cristian_S on Fri Nov 13, 2020 10:30 am
Hello!
How can I send the AT+CBC value as a sms ?
I've tried:
Declared "batt" as char, string, int. All I get are weird signs on the sms to the phone.
But it show right on the serial monitor.
fona.println("AT+CBC");
updateSerial(); //loop function --> serial.available
batt = fona.read();
fona.print(batt); // to send as sms.
delay(1000);
fona.print((char)26);
and i also tested:
fona.sendSMS(callerIDbuffer, batt);
same result.
Regards
Cristian
Cristian_S
Re: Feather 32u4 FONA AT+CBC value to sms
by rskup on Fri Nov 13, 2020 6:03 pm
Just tossing this out there, but have you looked at the AT+CMGF (SMS Message Format) command?
You may have AT+CMGF=0 set, you probably want AT+CMGF=1
rskup
by Cristian_S on Sun Nov 15, 2020 8:51 am
Hi!
Thanks for the answer/guess :-). Yes I already have the AT+CMGF=1.
Do you know what "declaration" (char/String/int...) is using when sending SMS. Do I have to use char? or something else?
Cristian_S
by Cristian_S on Sun Nov 15, 2020 9:58 am
When I use the AT+CBC command I get in the serial monitor:
+CBC: 0,99,4194
but...
How do I save/send that as an SMS ?
When I use:
batt = fona.read();
It seems to save it "wrong" beacouse when I use Serial.println(batt) it shows strange signs dependent on how I have declared "batt".
Cristian_S
by rskup on Sun Nov 15, 2020 11:16 am
Ok, next toss (guess):
What about using fona.readString() rather than fona.read()?
https://www.arduino.cc/reference/tr/lan ... eadstring/
If that doesn't work, will fire up my fona 3g and try to duplicate what you're doing, sending the battery voltage as an SMS would be a useful addition for a gps tracker I'm trying to build, I like that idea.
rskup
by Cristian_S on Mon Nov 16, 2020 7:22 am
Hi!
Thanks rskup!
It works whit fona.readString() :-)
Now I get the entire SMS (AT + CBC) string to my phone. BUT I also hade to remove "updateSerial();" after the "fona.println("AT+CBC\r\n");"
otherwise it does not seem as if there is any value left to retrieve.
The result in the phone:
+CBC: 0,93,4144
OK
So I am very happy.. but I will try to break out a certain part of the string and just send one part of it ...
maybe using substring()?!
https://www.arduino.cc/reference/en/language/variables/data-types/string/functions/substring/
This is the working code:
String batt = "";
void battery()
  fona.println("AT+CMGF=1\r");
  updateSerial();
  fona.println("AT+CBC\r\n"); //Battery level
  //updateSerial();
  batt = fona.readString();
  Serial.println("Sending Data...");
  delay(1000);
  fona.print("AT+CMGS=\"+******************\"\r");  //phone number and country code
  delay(1000);
  Serial.println(batt);
  delay(1000);
  fona.print(batt);  //This string is sent as SMS
  delay(1000);
  fona.print((char)26);//Tell the module that it can send the SMS
  delay(1000);
  fona.println();
  Serial.println("Data Sent.");
  delay(1000);
void updateSerial()
  delay(500);
  while (Serial.available())
    fona.write(Serial.read());//Forward what Serial received to Software Serial Port
  while(fona.available())
    Serial.write(fona.read());//Forward what Software Serial received to Serial Port
Cristian_S
by rskup on Mon Nov 16, 2020 2:36 pm
Hey Cristian, cool, things are starting to work.
If you're just looking to only send the first line, I have used the "replace()" command for stripping out parts of a reply I didn't want.
So I played around a bit with my FONA 3G and I think (keyword - think) this will work for you:
batt.replace("\r","");
batt.replace("\n","");
batt.replace("OK","");
That should strip out the return character, the new line character, and the "OK".
Then your "batt" string should just be the "+CBC: 0,xx,yyyy" and nothing else.
fyi, I did try combining all three replace() lines into one like:
batt.replace("\r\nOK","");
but that did not work at all.
Ok, hope things keep going well!
rskup
by rskup on Mon Nov 16, 2020 6:22 pm
Yep, me again.
If you only want to pull the milli-volts out of batt, then try:
String battSub = batt.substring(batt.lastIndexOf(",")+1,batt.lastIndexOf(",")+5);
rskup
by Cristian_S on Tue Nov 17, 2020 8:07 am
Hi!
Thanks again rskup! Thank you very much for helping me whit the code! :-)
I used your code line and added so that the sms shows ***** mV and % left of the battery.
For example:
The message in the SMS
4200 mV
99%
void battery()
  fona.println("AT+CMGF=1\r"); //Set the module to SMS mode
  updateSerial();
  String battSubV = batt.substring(batt.lastIndexOf(",")+1,batt.lastIndexOf(",")+5);
  String battSubP = batt.substring(batt.lastIndexOf(",")+0,batt.lastIndexOf(",")-2);
  delay(500);
  fona.print("AT+CMGS=\"+******************\"\r");// Phone number,  include country code
  delay(500);
  Serial.println(battSubV);
  Serial.println(battSubP);
  delay(500);
  fona.print(battSubV + " mV" + "\r\n" + battSubP + " %");  //This string is sent as SMS
  delay(500);
  delay(500);
  fona.println();
  delay(500);
void updateSerial()
  delay(500);
Cristian_S
by rskup on Tue Nov 17, 2020 2:19 pm
Hey Cristian, I like how that looks, nice addition to any Fona project!
Dawned on me -- the "percent battery" could be one to three digits depending on its value (1-100).
Just replace your:
with this:
String battSubP = batt.substring(batt.indexOf(",")+1,batt.lastIndexOf(","));
Now it extracts the percent number between the two commas, whether one, two, or three digits.
Shouldn't have to worry about the millivolts, will always be 4 digits since the FONA won't work below about 3 volts, much less 1 volt.
Ok, hope all's well!
rskup
by Cristian_S on Wed Nov 18, 2020 8:49 am
Hello rskup!
Thanks again :-)
I noticed yesterday when I tested and the battery was fully charged that it showed 00 :-) then understood that I have to look at that line of code again. But then you had already fixed the solution for me :-) Thank you!
Regards
Cristian
Cristian_S
