first of all, I am pretty new to this, so please be patient! I got a Adafruit Feather HUZZAH ESP8266. I have set it up and run the basic scripts (led on/off and wifi connection) and everything looks OK. However, I have been trying to follow the adafruit digital output minitutorial, and I don't get it to work. In my serial monitor, all I can read is "connecting to Adafruit IO...........[etc]", but it never connects. I am using the arduino IDE to load the code, which again worked for the setup and the wifi connection test. Any idea idea/suggestion on what to check next?
Thanks!!
Adafruit Feather HUZZAH ESP8266 not connecting to Adafruit?
- vicentepp
- sommersoft
Re: Adafruit Feather HUZZAH ESP8266 not connecting to Adafru
Did you setup all of the appropriate fields in the config.h tab of the example?:
This of course assumes you are loading the example code from the Arduino IDE. If you post your actual code (without personal info like wifi_pass and your AIO key), it will help people decode any possible issues.
#define IO_USERNAME "your_username"
#define IO_KEY "your_key"
/******************************* WIFI **************************************/
#define WIFI_SSID "your_ssid"
#define WIFI_PASS "your_pass"
- vicentepp
I literally use the code in the example. I don't modify it at all; only in config.h, where I include my account, key, wifi network and password.
- sommersoft
Hmm. I just tried the example ("adafruitio_07_digital_out"; only changed config.h, like you), and it connects just fine. Which is weird because I don't even have a feed named "digital".
Are you sure you have your wifi & AIO values correct?
- dotpan
I'm experiencing the exact same thing. I know I've been able to connect before, but my project no longer does, it hangs at the "connecting to Adafruit IO" portion and returns io.status() = 1.
After some testing I found that the examples don't try an connect to Wifi then AIO, just AIO. So I commented out the Wifi connecting alone and I seem to be connecting.
https://github.com/seckela/anonChatCoun ... ounter.ino
- vicentepp
Hello everybody,
I still don't know what the exact issue is but I setup different wireless network (different access point) and now it seems the feather is connecting and working nicely. Therefore, the issue must be related with my router? Still when I test internet connection, it connects, but when trying to connect to adafruit, it just doesn't.
- dotpan
Do you have an example of your code (not your config.h code, but your setup code). I had the following code:
That was sitting in front of my io.connect setup, which when commented out made it so I reliably could connect.
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
- automationjackson
I am seeing the same thing. It says "connecting to adafruit IO" then just stalls out. I know i am getting online as i can ping the nodeMCU that i am using. I have changed the config.h file to my username and AIO key. Anyone have a fix for this? Where is the io.connect call located?
Ryan
Ryan
