Feather Huzzah32 and Adafruit IO
by DrDetroit on Tue Aug 07, 2018 10:45 pm
Oddly enough, I can't find an example of a sketch that puts the Huzzah32 onto Adafruit IO. The wifi library is different, and that's confusing the mqtt library (apparently).
Any hints?
DrDetroit
Re: Feather Huzzah32 and Adafruit IO
by brubell on Wed Aug 08, 2018 10:09 am
Are you using the Adafruit IO Arduino Library (https://learn.adafruit.com/welcome-to-a ... -based-6-2)?
Could you paste the output (including errors) from the Arduino IDE?
brubell
by DrDetroit on Wed Aug 08, 2018 11:27 am
I did manage to get it to work with this code literally 15m ago. It was snagged from Adel Kassah's related Youtube video. I combined publish and subscribe, and here's what I ended up with.
// Generated with a lot of love//
// with TUNIOT FOR ESP32 //
// Website: Easycoding.tn //
// Minor Modifications by Robert Jones
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#include <WiFi.h>
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 1883
#define AIO_USERNAME "DrDetroit"
#define AIO_KEY "shh..It's a secret"
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
Adafruit_MQTT_Subscribe onoff = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/onoff");
//Added 9:56AM
Adafruit_MQTT_Publish test = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/test");
boolean MQTT_connect();
boolean MQTT_connect() { int8_t ret; if (mqtt.connected()) { return true; } uint8_t retries = 3; while ((ret = mqtt.connect()) != 0) { mqtt.disconnect(); delay(2000); retries--;if (retries == 0) { return false; }} return true;}
void setup()
Serial.begin(115200);
mqtt.subscribe(&onoff);
WiFi.disconnect();
delay(3000);
Serial.println("START");
WiFi.begin("ATT4aky3rk 2.4Ghz","8#jus4vvu37r");
while ((!(WiFi.status() == WL_CONNECTED))){
delay(300);
Serial.print("..");
Serial.println("Connected");
Serial.println("Your IP is");
Serial.println((WiFi.localIP()));
void loop()
if (MQTT_connect()) {
Adafruit_MQTT_Subscribe *subscription_name;
while ((subscription_name = mqtt.readSubscription(1000))) {
if (subscription_name == &onoff) {
Serial.println("New value on onoff");
Serial.println(((char *)onoff.lastread));
//this just sends out the number '4'
if (test.publish("4")) {
Serial.println("Published");
delay(2000);
DrDetroit
by DrDetroit on Fri Aug 10, 2018 2:27 pm
Solved.
DrDetroit
