No Update when ESP.DeepSleep'ing
by anthonyjclarke on Mon Oct 01, 2018 5:03 pm
*Newbie Alert*
Using the example DHT Temp logger, and all fine and working first time :)
However when I replace the Delay() with ESP.deepSleep(sleepSeconds * 1000000); the sketch continues to function (based on Serial monitor)
BUT there is no update to Adafruit.IO.... as soon as I switch back to Delay() its all working.
Here's my sketch,
// Adafruit IO Temperature & Humidity Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io-basics-temperature-and-humidity
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016-2017 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
// v1.0 October 1 2018
// Want to get Sleep working / initial attempt works but does not update Adafruit despite log saying so.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
// pin connected to DH22 data line
#define DATA_PIN D4 // Pin 2
// create DHT22 instance
DHT_Unified dht(DATA_PIN, DHT22);
// set up the 'temperature' and 'humidity' feeds
AdafruitIO_Feed *temperature = io.feed("temperature");
AdafruitIO_Feed *humidity = io.feed("humidity");
const int sleepSeconds = 60;    // 10 mins = 600 seconds
  // start the serial connection
  Serial.begin(115200);
  // Connect D0 to RST to wake up
  pinMode(D0, WAKEUP_PULLUP);
  // wait for serial monitor to open
  while(! Serial);
  // initialize dht22
  dht.begin();
  // connect to io.adafruit.com
  Serial.print("\n\nConnecting to Adafruit IO");
  io.connect();
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  Serial.println("\nStart of Loop(),\nConnecting to AdafruitIO");
  // wait for a connection - Probably not necessary, trying to Debug!
    Serial.print(".");
    delay(500);
  // we are connected
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  float celsius = event.temperature;
  Serial.print("celsius: ");
  Serial.print(celsius);
  Serial.println("C");
  dht.humidity().getEvent(&event);
  Serial.print("humidity: ");
  Serial.print(event.relative_humidity);
  Serial.println("%");
  // save celsius & humidity to Adafruit IO
  temperature->save(celsius);
  humidity->save(event.relative_humidity);
  // wait 5 seconds (5000 milliseconds == 5 seconds)
  delay(60000);
  Serial.println("\nSleeping now");
   // convert to microseconds
  // ESP.deepSleep(sleepSeconds * 1000000);
Reason: Please use [code] tags for readability
anthonyjclarke
Re: No Update when ESP.DeepSleep'ing
by brubell on Tue Oct 02, 2018 9:59 am
When using ESP.deepsleep with Adafruit IO, nothing should happen within the loop(), it should make a call to esp.deepsleep from within setup(): https://github.com/adafruit/Adafruit_IO ... ep.ino#L45
Here's a full example of Adafruit IO and ESP's DeepSleep: https://github.com/adafruit/Adafruit_IO ... psleep.ino
brubell
by anthonyjclarke on Tue Oct 02, 2018 4:07 pm
brubell wrote:When using ESP.deepsleep with Adafruit IO, nothing should happen within the loop(), it should make a call to esp.deepsleep from within setup(): https://github.com/adafruit/Adafruit_IO ... ep.ino#L45
Grr, lesson to self RTFM / examples and get to end before asking questions.
Really appreciate your help though!
anthonyjclarke
by anthonyjclarke on Tue Oct 02, 2018 5:14 pm
Sorry to be back, but adapted all the code (see below)....
I am getting one variable written to IO, not the second.... am I missing something :(
When I switch around the writes, only the first gets written, is there a limitation here?
humid->save(event.relative_humidity);
temp->save(celsius);
// Initial Release
// v1.1 October 3 2018
// Adapted after feedback from support to contain all writing in setup()
// Issue still is only writing one value....
#include "config.h"
#include <DHT.h>
#include <DHT_U.h>
  while(! Serial);
  Serial.println("\nAdafruit IO + DeepSleep");
  // connect to the Adafruit IO Library
  connectAIO();
  // initialize dht22
  dht.begin();
  delay(500);
  // set up and write to feed
  feedWrite();
  // let's go back to sleep for DEEPSLEEP_DURATION seconds...
  Serial.println("sleeping...");
  // Put the ESP into deepsleep for DEEPSLEEP_DURATION
  // NOTE: Make sure Pin 16 is connected to RST
// NOOP
void feedWrite(){
  // set up the 'temperature' and 'humid' feeds
  AdafruitIO_Feed *temp = io.feed("temperature");
  AdafruitIO_Feed *humid = io.feed("humidity");
  Serial.print("humid: ");
  Serial.println("Now writing to Adafruit IO");
  io.run();
void connectAIO() {
  Serial.println("Connecting to Adafruit IO...");
  io.connect();
  while (io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
anthonyjclarke
by brubell on Wed Oct 03, 2018 9:48 am
Do you see both incoming values on your monitor when they're sent? https://io.adafruit.com/monitor
Try adding a print statement between the two to make sure they're executing in-order:
  Serial.println("Sending temp...");
  Serial.println("Sending Humid...");
brubell
by anthonyjclarke on Wed Oct 03, 2018 6:19 pm
Thanks for ongoing support,
I modified the code (to do a serial print and introduce a "delay" in case that would help)
  io.run();
Looking at the Monitor, this is what I see, and I've shown the output from the Serial port
If I change the sleep to a Delay in the loop() then this is what I see....
Any suggestions? do you have any sample code where multiple values can be uploaded after a deep sleep?
anthonyjclarke
by brubell on Wed Oct 03, 2018 7:09 pm
Not that I know of, we'll go through it together though :)
Try moving io.run(); from the bottom of the function, to the top?
brubell
by anthonyjclarke on Wed Oct 03, 2018 8:12 pm
Made a change to the code, moving io.run to the top
void feedWrite(){
  delay(500);
  // read again
  io.run();
Now no updates!
anthonyjclarke
by anthonyjclarke on Wed Oct 03, 2018 8:48 pm
Did some other testing, using the sample code #19 for Deep Sleep.
With one value written works.
With the addition of deepsleep2 this results in NO updates.
void feedWrite(){
   // set up `deepsleep` feed
  AdafruitIO_Feed *deepsleep = io.feed("deepsleep");
  AdafruitIO_Feed *deepsleep2 = io.feed("deepsleep2");
  Serial.println("sending value to feed 'deepsleep");
  // send data to deepsleep feed
  deepsleep->save(1);
  deepsleep2->save(2);
  // write data to AIO
  io.run();
anthonyjclarke
by anthonyjclarke on Wed Oct 10, 2018 5:40 pm
Just wondering if you / anyone had any suggestions here?
anthonyjclarke
