MQTT server connection failed
by ellim on Sun Apr 14, 2019 5:22 pm
Hello!
I've connected a BNO055 imu to a feather 32u4 ble.
I've connected them to bluefruit and am getting the uart stream in the proper CSV format that shows up just fine on the plotter.
I've tried to connect to io.adafruit.com with the MQTT settings panel, and it works for a few seconds, with the feed showing plotted data, then it disconnects.
I've followed this tutorial: https://learn.adafruit.com/bluefruit-le-connect/mqtt
Any help with getting the connection to stop failing would be greatly appreciated!
ellim
Re: MQTT server connection failed
by Sam43054 on Mon Apr 15, 2019 12:59 pm
Hi
A few questions
Does the feather 32u4 ble. have the latest firmware ?
What platform are you using iOS or Android ? also what version
Is the Bluefruit App the latest versions
How often are you up loading data in the code?
Sam43054
by heeheejack on Mon Apr 15, 2019 1:21 pm
Thanks for the reply!
I have updated to the latest firmware
Android
I just downloaded it, so it should be the latest blue fruit
It should send data at 50 Hz
heeheejack
by collinmel on Fri Apr 19, 2019 11:47 pm
Hi heeheejack - Have you tried sending data at a slower speed? Adafruit.io has a rate limit of 1Hz:
https://learn.adafruit.com/welcome-to-a ... limit-16-5
collinmel
cron
