Identify transmitters and receivers
by Systembolaget on Wed Feb 05, 2020 5:56 am
We have 1. three air quality sensors that shall report to a base station and 2. three wind turbulence sensors that shall report to a base station and 3. three traffic noise sensors that shall report to a base station. All three sensor types are in different locations on a large city traffic intersection. The base station shall visualise the sensor's output in good/normal/bad states via RGB LEDs. But we also would like to transmit the data to Adafruit.IO every hour or so.
We looked at your 1. packet radio 2. LoRa radio and 3. WiFi products but wonder how do transmitters and receivers identify each other? And how would we relay the base station receiver data to Adafruit.IO?
In other words, what products should we buy for these kind of multi-sensor/multi-location set-ups?
Systembolaget
Re: Identify transmitters and receivers
by brubell on Thu Feb 06, 2020 10:34 am
Hi Systembolaget,
I feel you'd be best off with a LoRa or LoRaWAN setup, keeping in mind that a LoRaWAN setup will require a LoRaWAN gateway in addition to a base station.
Since the air quality sensors and the turbulence sensors send data to a base station, the base station should identify each data packet received by a sender. You can include an identifier value with the transmitted packet.
Check out this learning system guide for a setup similar to what you're proposing: https://learn.adafruit.com/multi-device ... re-network
brubell
by Systembolaget on Thu Feb 06, 2020 11:11 am
Great, thanks!
I was hoping to get away without a LoRaWAN gateway and use "simple" packet radio instead. But I shall check out your multi-sensor guide before buying.
Systembolaget
by brubell on Fri Feb 07, 2020 10:32 am
Systembolaget wrote:Great, thanks!
You could use a simple packet radio like a RFM69 + Feather. The "base station" would be a Raspberry Pi with a RFM69 connected. The base station, just like in the guide, would listen to and parse packets from your sensors.
brubell
by Systembolaget on Fri Feb 07, 2020 3:24 pm
Thanks, I'm trying to avoid having to get into Raspberry Pi for this task though; is that absolutely necessary you think?
Systembolaget
by brubell on Wed Feb 12, 2020 9:53 am
Systembolaget wrote:Thanks, I'm trying to avoid having to get into Raspberry Pi for this task though; is that absolutely necessary you think?
You could use a Feather RFM9x/RFM69 connected to an AirLift FeatherWing as a base station/gateway
brubell
by Systembolaget on Thu Feb 13, 2020 4:27 am
Right, so I would buy
1. several Adafruit Feather M0 RFM69HCW Packet Radio - 868 or 915 MHz – RadioFruit for each sensor location to transmit,
2. one Adafruit Feather M0 RFM69HCW Packet Radio - 868 or 915 MHz – RadioFruit at the base station to receive, and coupled to that
3. one Adafruit AirLift FeatherWing – ESP32 WiFi Co-Processor at the base station to relay to Adafruit IO.
Did I understand this correctly?
Systembolaget
by brubell on Thu Feb 13, 2020 9:57 am
Yep - looks good!
brubell
