Black Lives Matter - Action and Equality.
Grand Central M4 fails to connect using "AdafruitIO_WiFi.h"
Re: Grand Central M4 fails to connect using "AdafruitIO_WiFi
by marsmen on Mon May 11, 2020 8:13 pm
I downloaded and replaced with the updated changes.
It did not fix the issue.
I found the issue.
In WiFiNINA/src/WiFi.h, even though I updated it. It did not actually update the files. I manually removed the folder from the Arduino Library, downloaded the latest from https://github.com/adafruit/WiFiNINA
And put them in the library. That was successful.
marsmen
by brubell on Tue May 12, 2020 10:29 am
Last week we rolled out a patch for the library which may have resolved the issue on the thread. Please update your Adafruit IO Arduino library to 3.6.0 (https://github.com/adafruit/Adafruit_IO ... /tag/3.6.0).
brubell
by ahoadley on Tue May 12, 2020 2:59 pm
The patch has solved the problem. Thanks
I am still having problems with my systems locking up at variable connect time ranging from 6 to 36 hours or so. This has happened with both python and Arduino versions. Still trying to figure this one out. My best guest is a random connection issue that either the library or my program can't recover.
ahoadley
by marsmen on Tue May 12, 2020 4:49 pm
I updated everything yesterday. Today, Arduino Library Manager said my updated WiFiNINA was old (ver 1.4.0). It updated to 1.5.0. It quick working.
The time date on the WiFi.h in WiFiNINA of the 1.5.0 is December 30, 2019.
The time date on the WiFi.h in WiFiNINA of the 1.4.0 is February 5, 2020.
I am using the files updated February 5, 2020 without issue. It has the wifi.setpins in is and something that fixes a timeout error alarm in Arduino IDE.
marsmen
by brubell on Fri May 15, 2020 9:53 am
marsmen wrote:I updated everything yesterday. Today, Arduino Library Manager said my updated WiFiNINA was old (ver 1.4.0). It updated to 1.5.0. It quick working.
I do not know what you mean by quit working. Is the library unable to compile? Are you unable to connect to Adafruit IO?
Could you please paste the error you're getting from either the serial monitor or the Arduino IDE?
brubell
by marsmen on Fri May 22, 2020 8:26 pm
@brubell
It had the same errors with the wifi.setpins (same error repeated throughout the post) and a timing error.
marsmen
