MQTT BROKEN
MQTT BROKEN
by PanosProject on Wed May 06, 2020 4:58 pm
Hide
MQTT ERROR: unexpected error saving data on PanosProject/feeds/Irms, Validation failed: Name has already been taken, Key has already been taken
i got this error... i did a mistake and delete all data io .... and after this i tried to run again the same project and i receive this
PanosProject
Re: MQTT BROKEN
by brubell on Fri May 08, 2020 9:49 am
Hi PanosProject, I replied to your email. Let's continue this convo there, thanks!
brubell
Re: MQTT BROKEN
by fraktal on Fri May 29, 2020 5:59 pm
Hi
I'm trying to use the example sketch and am getting this same error. I've tried several times to get this working but would appreciate any help. Really of the idea of Adafruit IO but have not been able to find any help for this error from searching online.
Chris
fraktal
Re: MQTT BROKEN
by fraktal on Fri May 29, 2020 8:24 pm
To clarify a bit...
I'm running the example sketch on an ESP32 board. Everything seems to run fine from the hardware side. Have no problems connecting to Adafruit IO and my local WiFi.
When I go to the Adafruit IO page I get this message each time my sketch sends a message:
'MQTT ERROR: unexpected error saving data on fraktal/feeds/counter, Validation failed: Name has already been taken, Key has already been taken'
I tried using a feed name other than the default. Tried creating the feed on Adafruit IO first (not sure if this is needed or not).
This is my first attempt at IOT and I'm sure I am missing something obvious, but apparently it is not obvious to me :)
I really love the idea of IOT but am having a tough time getting started. Any help or suggestions for an IOT noob would be greatly appreciated.
fraktal
Re: MQTT BROKEN
by brubell on Mon Jun 01, 2020 11:10 am
Fraktal,
Which example sketch are you using?
brubell
Re: MQTT BROKEN
by fraktal on Mon Jun 01, 2020 2:20 pm
File -> Examples -> Adafruit IO Arduino -> adafruitio_00_publish
I was finally able to sort it out over the weekend. Given this was the third time I'd attempted this over the last year, I thought I would share with the forum for completeness. Please correct me if I am giving bad information.
When you create a feed on the Adafruit IO website, it puts it into a default group, When I created a feed called counter and examined the info, it said the name was 'counter' and the key was 'counter.' However if you view the 'Feeds' section of the website, it will show that the feed name is 'counter' and the key is actually 'default.counter'. To get the example to work I had to change the name of the feed in the Arduino sketch to 'default.counter'.
I'm guessing this was a newbie mistake that is probably outlined in one of the many tutorials, but hopefully this will save someone else some time in the future.
fraktal
Re: MQTT BROKEN
by mmorton on Wed Apr 21, 2021 2:52 pm
Thank you - you're not alone. I had the same issue. After reading this post, I got my code working too.
mmorton
