Integration of IFTTT with Adafruit IO MQTT broker and Abode
by YoukimKudoh on Thu May 13, 2021 1:19 am
I have Adafruit IO and Abode added as services to my IFTTT account. I have built applets to trigger actions on Abode when messages are received on my Adafruit IO feeds. These applets work, however there is a great deal of latency between when the message is received by the Adafruit broker and when the IFTTT applet finally fires. Can anything be tweaked to reduce the delay between message and applet? Is there another MQTT service that has better integration with IFTTT?
YoukimKudoh
Re: Integration of IFTTT with Adafruit IO MQTT broker and Ab
by brubell on Fri May 14, 2021 9:32 am
The delay between Adafruit IO and IFTTT is on IFTTT's side as they guarantee a 15-minute interval window in which the applet can execute.
If Abode (I don't have any experience with this service) has the ability to receive a webhook, you could use adafruit io's reactive trigger feature with it: https://blog.adafruit.com/2020/08/06/ad ... dafruitio/
brubell
cron
