Connection from ESP32 to Adafruit IO fails
by fab64 on Mon Aug 02, 2021 5:32 am
I am trying to connect to Adafruit IO to use the MQTT Broker to make a POC for a customer. Everything works fine using Arduino Nano 33 IOT.
Connection from ESP32 always fails.
I have written a simple sketch just to test the connection. A very similar connection code running from Nano get connected.
#include <WiFi.h>
#include <WiFiClientSecure.h>
const char ssid[] = "myssid";
const char pass[] = "mypassword";
#define BROKER_ADDRESS "io.adafruit.com"
#define BROKER_PORT 8883
/// Ca Cert Adafruit
const char* ca_cert1 = \
                       "-----BEGIN CERTIFICATE-----\n" \
                       "MIIGijCCBXKgAwIBAgIQAfUXR/1IrnlbCX0+CKqtnDANBgkqhkiG9w0BAQsFADBe\n" \
                       "ApmyW7PbQr+9lZuNzkqieNIt/VuCyNIKZEBJ3PA/2QfwvXdIpjE6M7yz+9kh9WdR\n" \
                       "Rg6qj6hPp2gvSQQrk361RY/sTtueAh4re8yyJDebH3B60kUwzNmMms7zcxQ0Ctvg\n" \
                       "/BDPVBd1VFF/tsoYO4P5iMar1YCl8BNozu6q4JP2E0HRygZD0U7vY2Gsi1wHdm5h\n" \
                       "VZnLJq6SRTbYUWY3tryEp2lJYQFiSoVfu5icebrLUVRmSl05PyYstjFekb9DCNyy\n" \
                       "LIBZsjmaFJoJCGo1y5cSqBYfwSsrq1aD9hn5LFeEVG+PEa10IlVv7l+33mLWZA==\n" \
                       "-----END CERTIFICATE-----\n";
WiFiClientSecure net;
  Serial.begin(115200);
  while (!Serial)
  delay(1500);
  Serial.println("Start");
  WiFi.begin(ssid, pass);
  Serial.println("checking wifi...");
  while (WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
    delay(1000);
  Serial.println("wifi connected");
  net.setCACert(ca_cert1);
  if (net.connect(BROKER_ADDRESS, BROKER_PORT)) {
    Serial.println("connected to server");
  else {
    Serial.println("connection to server failed");
  // put your main code here, to run repeatedly:
Any idea of what am I doing wrong?
fab64
Re: Connection from ESP32 to Adafruit IO fails
by brubell on Mon Aug 02, 2021 10:05 am
You're attempting to connect to an MQTT broker using a HTTP client (`WiFiClientSecure`) library, you'll need to use a MQTT client such as the Adafruit_MQTT library or Arduino client MQTT Library. Otherwise, use the HTTP API with the WiFiClientSecure library.
brubell
by fab64 on Mon Aug 02, 2021 12:27 pm
Thank you for your answer. Maybe my question was not clear enough.
My actual code uses an MQTT library (https://github.com/256dpi/arduino-mqtt) and doesn't connect to Adafruit IO.
Trying to sort the problem out I wrote the test code just to be sure that the issue is not related to SSL and/or the way I import the Adafruit IO certificate. I used that test code to check the SSL connection against other MQTT brokers (which use both self signed certificate and certificate signed by a CA) and if I can connect with the test code I can also connect with the MQTT Client.
My problem is that I cannot connect to Adafruit IO neither using the test code nor the MQTT Client.
Does Adafruit IO support only either Adafruit_MQTT or Arduino client MQTT Libraries?
fab64
by brubell on Tue Aug 03, 2021 5:04 pm
No, it supports any MQTT client library.
Could you post your original code, which connects to IO's MQTT broker? I'll take a look.
brubell
by fab64 on Wed Aug 04, 2021 3:24 am
I realized that the problem is with the way I use the certificate. Replacing:
with:
    net.setInsecure();
everything works as expected.
I got the certificate opening https://io.adafruit.com/ and saving the certificate via Firefox.
I attached my simplified code.
Thank you for your support.
ForumTest1.ino
(4.42 KiB) Downloaded 1 time
fab64
by fab64 on Thu Aug 05, 2021 12:42 pm
Any suggestions on how to properly load the CA certificate?
fab64
by brubell on Mon Aug 09, 2021 10:06 am
The `setCACert` is the standard call, could you please post your code within
code
tags instead of attaching it?
brubell
by fab64 on Tue Aug 10, 2021 2:00 am
Here it is.
I have to truncate the certificate because of the error:
"Your message contains banned spam words. Please rephrase your post without the following words: ...."
Since I think the issue is related to the way manage the certificate, I attached the code unchanged in the previous message
#include <MQTT.h>        // https://github.com/256dpi/arduino-mqtt
// Adafruit IO
#define BROKER_USER "<myuser>"
#define BROKER_PASSWORD "<mytoken>"
const char ssid[] = "<myssid>";
const char pass[] = "<mypassword>";
MQTTClient client;
unsigned long lastMillis = 0;
  Serial.print("Connecting to WiFi...");
    Serial.print(".");
    delay(1000);
  Serial.println(" connected!");
  net.setInsecure();                 // <-- This works!
  //net.setCACert(ca_cert1);         // <-- This doesn't work
  client.setOptions(60, false, 500);
  client.begin(BROKER_ADDRESS, BROKER_PORT, net);
  client.onMessage(messageReceived);
  connectToBroker();
void connectToBroker() {
  client.setOptions(20, true, 500);
  Serial.print("Connecting to MQTT Broker ...");
  while (!client.connect("ESP32", BROKER_USER, BROKER_PASSWORD)) {
    Serial.print("MQTT Client Disconnected! ");
    Serial.print(client.lastError()); Serial.println(" Return Code");
    Serial.println(client.returnCode());
    delay(1000);
  Serial.println("connected!");
  // Subscriptions
  client.subscribe("fab64/feeds/Light");
  client.loop();
  if (!client.connected()) {
    connectToBroker();
  // publish a message roughly every second.
  if (millis() - lastMillis > 60000) {
    lastMillis = millis();
    String payload = String(random(0, 100));
    client.publish("fab64/feeds/TC", payload, true, 1);   // retained - QoS 1
    Serial.println("Temperature updated");
void messageReceived(String &topic, String &payload) {
  Serial.print("Topic: ["); Serial.print(topic); Serial.print("] Payload: "); Serial.println(payload);
fab64
by brubell on Fri Aug 13, 2021 9:31 am
What's the contents of the certificate? ca_cert1
Could you paste it into https://gist.github.com and then post it here? I want to match it against our server.
brubell
by fab64 on Sat Aug 14, 2021 11:41 am
fab64
by brubell on Tue Aug 17, 2021 4:55 pm
IO's root CA looks like:
  // io.adafruit.com root CA
  const char *_aio_root_ca =
      "MIIDrzCCApegAwIBAgIQCDvgVpBCRrGhdWrJWZHHSjANBgkqhkiG9w0BAQUFADBh\n"
      "MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3\n"
      "d3cuZGlnaWNlcnQuY29tMSAwHgYDVQQDExdEaWdpQ2VydCBHbG9iYWwgUm9vdCBD\n"
      "QTAeFw0wNjExMTAwMDAwMDBaFw0zMTExMTAwMDAwMDBaMGExCzAJBgNVBAYTAlVT\n"
      "MRUwEwYDVQQKEwxEaWdpQ2VydCBJbmMxGTAXBgNVBAsTEHd3dy5kaWdpY2VydC5j\n"
      "b20xIDAeBgNVBAMTF0RpZ2lDZXJ0IEdsb2JhbCBSb290IENBMIIBIjANBgkqhkiG\n"
      "9w0BAQEFAAOCAQ8AMIIBCgKCAQEA4jvhEXLeqKTTo1eqUKKPC3eQyaKl7hLOllsB\n"
      "CSDMAZOnTjC3U/dDxGkAV53ijSLdhwZAAIEJzs4bg7/fzTtxRuLWZscFs3YnFo97\n"
      "nh6Vfe63SKMI2tavegw5BmV/Sl0fvBf4q77uKNd0f3p4mVmFaG5cIzJLv07A6Fpt\n"
      "43C/dxC//AH2hdmoRBBYMql1GNXRor5H4idq9Joz+EkIYIvUX7Q6hL+hqkpMfT7P\n"
      "T19sdl6gSzeRntwi5m3OFBqOasv+zbMUZBfHWymeMr/y7vrTC0LUq7dBMtoM1O/4\n"
      "gdW7jVg/tRvoSSiicNoxBN33shbyTApOB6jtSj1etX+jkMOvJwIDAQABo2MwYTAO\n"
      "BgNVHQ8BAf8EBAMCAYYwDwYDVR0TAQH/BAUwAwEB/zAdBgNVHQ4EFgQUA95QNVbR\n"
      "TLtm8KPiGxvDl7I90VUwHwYDVR0jBBgwFoAUA95QNVbRTLtm8KPiGxvDl7I90VUw\n"
      "DQYJKoZIhvcNAQEFBQADggEBAMucN6pIExIK+t1EnE9SsPTfrgT1eXkIoyQY/Esr\n"
      "hMAtudXH/vTBH1jLuG2cenTnmCmrEbXjcKChzUyImZOMkXDiqw8cvpOp/2PV5Adg\n"
      "06O/nVsJ8dWO41P0jmP6P6fbtGbfYmbW0W5BjfIttep3Sp+dWOIrWcBAI+0tKIJF\n"
      "PnlUkiaY4IBIqDfv8NZ5YBberOgOzW6sRBc4L0na4UU+Krk2U886UAb3LujEV0ls\n"
      "YSEY1QSteDwsOoBrp+uvFRTp2InBuThs4pFsiv9kuXclVzDAGySj4dzp30d8tbQk\n"
      "CAUw7C29C79Fv1C5qfPrmAESrciIxpg0X40KPMbp1ZWVbd4=\n"
You'd want to set the CACert with Adafruit MQTT using the following command:
_wifi_client_secure->setCACert(_aio_root_ca);
brubell
