Suppose I do io.connect() in the setup() function and send data in the loop() function. After each "send" is complete, I have a delay(DELAY_TIME) statement to wait for awhile before sending more data. How long does the connection to IO stay open? If I send data only once every minute or so, will the connection still be open? If not, can I move the io.connect() into the loop() function to re-open the connection each time?
Thanks.
How long will IO stay connected?
- brubell
- Learn User Page
Re: How long will IO stay connected?
Which hardware platform and software library are you using to connect to Adafruit IO? I can give you an exact answer based off that.
- earthres
I'm using a HUZZAH32 with the Adafruit IO libraries for that board.
- brubell
- Learn User Page
The KeepAlive time is part of the MQTT specification, it's defined in the Adafruit MQTT library here and defaults to five minutes:earthres wrote:I'm using a HUZZAH32 with the Adafruit IO libraries for that board.
https://github.com/adafruit/Adafruit_MQ ... QTT.h#L104
It gets sent to IO when io.connect() is called. You may change it by editing that file on your computer.
- earthres
OK. Thanks. That's a VERY helpful answer. As I'm sure you know, there are a ton of online resources for posting environmental data to IoT dashboards, including Adafruit IO. Almost always, posting such data more frequently than every few minutes is a waste of data storage space and, for outdoor solar/battery-powered systems, a waste of power. Using a BME280 sensor to upload temperature, relative humidity, and pressure is a perfect example of a project where posting data at intervals under five minutes makes perfect sense and posting more frequently than that makes no sense for those particular measurements.
- brubell
- Learn User Page
Yep - that is a variable for you to adjust to your specifications!
