AIO esp32/sim7000 combo
by TheRobertTalley on Sat Jul 31, 2021 7:26 pm
Im using a lilygo tcallsim7000a, a ublox 6m and adafruit io to make a data logger. Everything I have works well over wifi but MQTT connect crashes over cellular. Would the nice folks here please take a look at this **** sketch and tell me what is up with this? I know it's something I'm missing. everything i have seen is for a sim7000/arduino or esp32/wifi. this is a feeble example of combining the two.
https://github.com/TheRobertTalley/lily ... 0but%20meh
#include <Adafruit_FONA.h> // https://github.com/botletics/SIM7000-LTE-Shield/tree/master/Code its Tim WOO's
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <FS.h>
#include <SPI.h>
#include <SD.h>
#include <Ticker.h>
#include <HardwareSerial.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <Adafruit_MQTT.h>
#include <Adafruit_MQTT_Client.h>
#include <Adafruit_MQTT_FONA.h>
/************************* WiFi Access Point *********************************
#define WLAN_SSID ""
#define WLAN_PASS ""
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  8883
#define IO_USERNAME  ""
#define IO_KEY       ""
Adafruit_FONA_LTE fona = Adafruit_FONA_LTE();       //needed for passing fona class to mqtt
/************ Global State (you don't need to change this!) ******************/
// Setup the FONA MQTT class by passing in the FONA class and MQTT server and login details.
Adafruit_MQTT_FONA mqtt(&fona, AIO_SERVER, AIO_SERVERPORT, IO_USERNAME, IO_KEY);
// You don't need to change anything below this line!
#define halt(s) { Serial.println(F( s )); while(1);  }
// FONAconnect is a helper function that sets up the FONA and connects to
// the GPRS network. See the fonahelper.cpp tab above for the source!
boolean FONAconnect(const __FlashStringHelper *apn, const __FlashStringHelper *username, const __FlashStringHelper *password);
// How many transmission failures in a row we're willing to be ok with before reset
uint8_t txfailures = 0;
#define MAXTXFAILURES 3
uint32_t x=0;
/****************************** Feeds ****************************************************************************/
// Setup a feed called 'gpslat' for publishing.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>   // This feed is not needed, only setup if you want to see it
const char Battery_FEED[] PROGMEM = IO_USERNAME "/feeds/Battery";
Adafruit_MQTT_Publish batter = Adafruit_MQTT_Publish(&mqtt, Battery_FEED);
const char Solar_FEED[] PROGMEM = IO_USERNAME "/feeds/Solar";
Adafruit_MQTT_Publish lesol = Adafruit_MQTT_Publish(&mqtt, Solar_FEED);
const char gps_FEED[] PROGMEM = IO_USERNAME "/feeds/gpslatlng/csv";
Adafruit_MQTT_Publish gpslatlng = Adafruit_MQTT_Publish(&mqtt, gps_FEED);
//gpslatlng.publish(gpsbuffer);     !!!!!!!
const int offset = -5;  // Eastern Standard Time (USA)
float GPSalt, mv, SV;
char Datetime[12], thetimeo[12], Dateo[20],
latlong1[80], gpsMQTT[80], LAT1[15], LONG1[15], ALTo[15], SpeedO[15],
DAYo[8], MONTHo[8], YEARo[12],
houro[8], minuteo[8], secondo[8];
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
char replybuffer[255]; // this is a large buffer for replies
char inei[16] = {0}; // MUST use a 16 character buffer for InEI!    //AIO wont let me post with IM0000000EI.
#define SIMCOM_7000                 //pins for a tcallsim7000x
#define FONA_PWRKEY 5
#define FONA_RST 4
#define FONA_TX 26 // For GSM
#define FONA_RX 27
#define TXPin 32 // For GPS module (NEO-6M)
#define RXPin 33
#define SD_MISO     2
#define SD_MOSI     15
#define SD_SCLK     14
#define SD_CS       13
#define LED_PIN     12
#define BAT_ADC     35
#define SOLAR_ADC   36
#define GPSBaud   9600
#define samplingRate 15 // The time we want to delay after each post (in seconds)
#define timetochill 15000
const double HOME_LAT = 34.27;                          // Enter Your Latitude and Longitude here
const double HOME_LNG = -83.87;                         // to track how far away the "Dog" is away from Home
// The TinyGPS++ object
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin); //gps
HardwareSerial fonaSS(1);        //gsm
/**************************************************sleepy time***************************/
#define uS_TO_S_FACTOR 1000000ULL  /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP  150        /* Time ESP32 will go to sleep (in seconds) 300 is 5 min */
RTC_DATA_ATTR int bootCount = 0;
void print_wakeup_reason(){
  esp_sleep_wakeup_cause_t wakeup_reason;
  wakeup_reason = esp_sleep_get_wakeup_cause();
  switch(wakeup_reason)
    case ESP_SLEEP_WAKEUP_EXT0 : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
    case ESP_SLEEP_WAKEUP_EXT1 : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
    case ESP_SLEEP_WAKEUP_TIMER : Serial.println("Wakeup caused by timer"); break;
    case ESP_SLEEP_WAKEUP_TOUCHPAD : Serial.println("Wakeup caused by touchpad"); break;
    case ESP_SLEEP_WAKEUP_ULP : Serial.println("Wakeup caused by ULP program"); break;
    default : Serial.printf("Wakeup was not caused by deep sleep: %d\n",wakeup_reason); break;
/*******************************GPSMODuLE POWER STUFF**********************************/
// Send a byte array of UBX protocol to the GPS
void sendUBX(uint8_t *MSG, uint8_t len) {
  for(int i=0; i<len; i++) {
    ss.write(MSG[i]);
  //Serial.println();
/******************************************************** Void Setup!! ************************************/
void setup(){
  Serial.begin(115200);
  //Increment boot number and print it every reboot
  ++bootCount;
  Serial.println("Boot number: " + String(bootCount));
  //Print the wakeup reason for ESP32
  print_wakeup_reason();
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) +
  " Seconds");
  pinMode(FONA_RST, OUTPUT);
  digitalWrite(FONA_RST, HIGH); // Default state
  // Turn on the module by pulsing PWRKEY low for a little bit
  // This amount of time depends on the specific module that's used
  fona.powerOn(FONA_PWRKEY); // Power on the module
  ss.begin(GPSBaud);
  fonaSS.begin(115200, SERIAL_8N1, FONA_TX, FONA_RX); // baud rate, protocol, ESP32 RX pin, ESP32 TX pin
  Serial.println(F("Configuring to 9600 baud"));
  fonaSS.println("AT+IPR=9600"); // Set baud rate
  delay(100); // Short pause to let the command run
  fonaSS.begin(9600, SERIAL_8N1, FONA_TX, FONA_RX); // Switch to 9600
  if (! fona.begin(fonaSS)) {
    Serial.println(F("Couldn't find FONA"));
    while (1); // Don't proceed if it couldn't find the device
  type = fona.type();
  Serial.println(F("FONA is OK"));
  Serial.print(F("Found "));
  // Set modem to full functionality
  fona.setFunctionality(1); // AT+CFUN=1
  fona.setNetworkSettings(F("vzwinternet"), F(""), F(""));
  fona.setOperatingBand("CAT-M", 13);
  fona.setNetLED(false);
  // Configure a GPRS APN, username, and password.
  // You might need to do this to access your network's GPRS/data
  // network.  Contact your provider for the exact APN, username,
  // and password values.  Username and password are optional and
  // can be removed, but APN is required.
  //fona.setNetworkSettings(F("nxtgenphone"), F("your username"), F("your password"));
  //fona.setOperatingBand("CAT-M", 12); // AT&T uses band 12
  //fona.setNetworkSettings(F("m2m.com.attz")); // For AT&T IoT SIM card
  //fona.setNetworkSettings(F("telstra.internet")); // For Telstra (Australia) SIM card - CAT-M1 (Band 28)
  //fona.setNetworkSettings(F("hologram")); // For Hologram SIM card
  // Optionally configure HTTP gets to follow redirects over SSL.
  // Default is not to follow SSL redirects, however if you uncomment
  // the following line then redirects over SSL will be followed.
  //fona.setHTTPSRedirect(true);
  // Other examples of some things you can set:
  fona.setPreferredMode(38); // Use LTE only, not 2G
  fona.setPreferredLTEMode(1); // Use LTE CAT-M only, not NB-IoT
//  fona.setOperatingBand("CAT-M", 13); // Verizon uses band 13
  fona.enableRTC(true);
  fona.enableSleepMode(true);
  fona.set_eDRX(1, 4, "0010");
  fona.enablePSM(true);
  // Set the network status LED blinking pattern while connected to a network (see AT+SLEDS command)
  fona.setNetLED(true, 2, 64, 3000); // on/off, mode, timer_on, timer_off
  fona.setNetLED(false); // Disable network status LED
  //printMenu();
delay(5000);
SPI.begin(SD_SCLK, SD_MISO, SD_MOSI, SD_CS);
  if (!SD.begin(SD_CS)) {
    Serial.println("        SDCard MOUNT FAIL");
  } else {
    uint32_t cardSize = SD.cardSize() / (1024 * 1024);
    String str = "       SDCard Size: " + String(cardSize) + "MB";
    Serial.println(str);
void loop(){
  //connectwifi();
  //MQTT_connect();                                       // Run Procedure to connect to Adafruit IO MQTT
  getdatGPS();
  BatteryFlair();
  //readmenu();
  //RECtoMQTT();
void DistanceToHome() {
  float Distance_To_Home;                               // variable to store Distance to Home
  float GPSlat = (gps.location.lat());                  // variable to store latitude
  float GPSlng = (gps.location.lng());                  // variable to store longitude
  float GPSalt = (gps.altitude.feet());                 // variable to store altitude
  Distance_To_Home = (unsigned long)TinyGPSPlus::distanceBetween(gps.location.lat(),gps.location.lng(),HOME_LAT, HOME_LNG);  //Query Tiny GPS to Calculate Distance to Home
  Serial.println(F("  GPS Tracking"));
  Serial.println("---------------------");
  Serial.print("GPS Lat: ");
  Serial.println(gps.location.lat(), 6);               // Display latitude to 6 decimal points
  Serial.print("GPS Lon: ");
  Serial.println(gps.location.lng(), 6);               // Serial longitude to 6 decimal points
  Serial.print("Distance: ");
  Serial.println(Distance_To_Home);                    // Distance to Home measured in Meters
void getdatGPS()
  // This sketch displays information every time a new sentence is correctly encoded.
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      displayInfo();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
void displayInfo()
  Serial.print(F("Location: "));
  if (gps.location.isValid())
    Serial.print(gps.location.lat(), 6);
    Serial.print(F(","));
    dtostrf(gps.speed.mph(),9,1,SpeedO);
    dtostrf(gps.altitude.feet(),5,1,ALTo);
    dtostrf(gps.location.lat(),9,7,LAT1);
    dtostrf(gps.location.lng(),9,7,LONG1);
    sprintf(latlong1, "http://www.google.com/maps/place/%s,%s", LAT1, LONG1);
    sprintf(gpsMQTT, "%s,%s,%s,%s",SpeedO, LAT1, LONG1, ALTo);
    Serial.println(latlong1);
    RECtoSD();
  else
    Serial.print(F("INVALID"));
  Serial.print(F("  Date/Time: "));
  if (gps.date.isValid())
    Serial.print(gps.date.month());
    Serial.print(F("/"));
    Serial.print(gps.date.day());
    Serial.print(gps.date.year());
    dtostrf(gps.date.month(),2,0,MONTHo);
    dtostrf(gps.date.day(),2,0,DAYo);
    dtostrf(gps.date.year(),4,0,YEARo);
    sprintf(Dateo, "/%s.%s.%s.txt", MONTHo, DAYo, YEARo);
  else
  Serial.print(F(" "));
  if (gps.time.isValid())
    if (gps.time.hour() < 10) Serial.print(F("0"));
    Serial.print(gps.time.hour());
    Serial.print(F(":"));
    if (gps.time.minute() < 10) Serial.print(F("0"));
    Serial.print(gps.time.minute());
    if (gps.time.second() < 10) Serial.print(F("0"));
    Serial.print(gps.time.second());
    Serial.println(F("  "));
    dtostrf(gps.time.hour(),2,0,houro);
    dtostrf(gps.time.minute(),2,0,minuteo);
    dtostrf(gps.time.second(),2,0,secondo);
    sprintf(thetimeo, "%s:%s:%s", houro, minuteo, secondo);
  else
  Serial.println();
void RECtoSD(void) {
Serial.println("\n**********RECORDING to SD and INTERWEBS******************");
        appendFile(SD, Dateo, "\n");
        appendFile(SD, Dateo, thetimeo);
        appendFile(SD, Dateo, latlong1);
        RECtoMQTT();
void RECtoMQTT() {
        MQTT_connect();
        gpslatlng.publish(gpsMQTT);
        batter.publish(analogRead(BAT_ADC));
        lesol.publish(analogRead(SOLAR_ADC));
        //GPSpowerdown();
        //powerdown();
        delay(timetochill);
void BatteryFlair() {
        MQTT_connect();
        //batter.publish(analogRead(BAT_ADC));
        //GPSpowerdown();
        //powerdown();
        delay(timetochill);
void appendFile(fs::FS &fs, const char * path, const char * message){
File file = fs.open(path, FILE_APPEND);
if(!file){
Serial.println("Failed to open file for appending");
return;
if(file.print(message)){
} else {
Serial.println("SAVE failed");
/*************************** connect to WIFI ************************************
  void connectwifi() {
  Serial.println(); Serial.println();
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  delay(1000);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  delay(2000);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print("."); }
  Serial.println();
  Serial.println("WiFi connected");
  Serial.println("IP address: "); Serial.println(WiFi.localIP());
void readmenu() {
  if (! Serial.available() ) {
    if (fona.available()) {
      Serial.write(fona.read());
  char command = Serial.read();
  //Serial.println(command);
  switch (command) {
    case '?': {
        printMenu();
        break;
    case 'a': {
        // read the ADC
        uint16_t adc;
        if (! fona.getADCVoltage(&adc)) {
          Serial.println(F("Failed to read ADC"));
        } else {
          Serial.print(F("ADC = ")); Serial.print(adc); Serial.println(F(" mV"));
        break;
    case 'b': {
        // read the battery voltage and percentage
        uint16_t vbat;
        if (! fona.getBattVoltage(&vbat)) {
          Serial.println(F("Failed to read Batt"));
        } else {
          Serial.print(F("VBat = ")); Serial.print(vbat); Serial.println(F(" mV"));
        if (type != SIM7500 && type != SIM7600) {
          if (! fona.getBattPercent(&vbat)) {
          } else {
            Serial.print(F("VPct = ")); Serial.print(vbat); Serial.println(F("%"));
        break;
    case 'U': {
        // Unlock the SIM with a PIN code
        char PIN[5];
        flushSerial();
        Serial.println(F("Enter 4-digit PIN"));
        readline(PIN, 3);
        Serial.println(PIN);
        Serial.print(F("Unlocking SIM card: "));
        if (! fona.unlockSIM(PIN)) {
          Serial.println(F("Failed"));
        } else {
          Serial.println(F("OK!"));
        break;
    case 'C': {
        // read the CCID
        fona.getSIMCCID(replybuffer);  // make sure replybuffer is at least 21 bytes!
        Serial.print(F("SIM CCID = ")); Serial.println(replybuffer);
        break;
    case 'i': {
        // read the RSSI
        uint8_t n = fona.getRSSI();
        int8_t r;
        Serial.print(F("RSSI = ")); Serial.print(n); Serial.print(": ");
        if (n == 0) r = -115;
        if (n == 1) r = -111;
        if (n == 31) r = -52;
        if ((n >= 2) && (n <= 30)) {
          r = map(n, 2, 30, -110, -54);
        Serial.print(r); Serial.println(F(" dBm"));
        break;
    case 'n': {
        // read the network/cellular status
        uint8_t n = fona.getNetworkStatus();
        Serial.print(F("Network status "));
        Serial.print(n);
        Serial.print(F(": "));
        if (n == 0) Serial.println(F("Not registered"));
        if (n == 1) Serial.println(F("Registered (home)"));
        if (n == 2) Serial.println(F("Not registered (searching)"));
        if (n == 3) Serial.println(F("Denied"));
        if (n == 4) Serial.println(F("Unknown"));
        if (n == 5) Serial.println(F("Registered roaming"));
        break;
    case '1': {
        // Get connection type, cellular band, carrier name, etc.
        fona.getNetworkInfo();
        break;
    /*** Calling ***/
    case 'c': {
        // call a phone!
        char number[30];
        flushSerial();
        Serial.print(F("Call #"));
        readline(number, 30);
        Serial.println();
        Serial.print(F("Calling ")); Serial.println(number);
        if (!fona.callPhone(number)) {
        } else {
          Serial.println(F("Sent!"));
        break;
    case 'A': {
        // get call status
        int8_t callstat = fona.getCallStatus();
        switch (callstat) {
          case 0: Serial.println(F("Ready")); break;
          case 1: Serial.println(F("Could not get status")); break;
          case 3: Serial.println(F("Ringing (incoming)")); break;
          case 4: Serial.println(F("Ringing/in progress (outgoing)")); break;
          default: Serial.println(F("Unknown")); break;
        break;
    case 'h': {
        // hang up!
        if (! fona.hangUp()) {
        } else {
        break;
    case 'p': {
        // pick up!
        if (! fona.pickUp()) {
        } else {
        break;
#if !defined(SIMCOM_7000) && !defined(SIMCOM_7070)
    /*** Audio ***/
    case 'v': {
        // set volume
        flushSerial();
        if ( (type == SIM5320A) || (type == SIM5320E) ) {
          Serial.print(F("Set Vol [0-8] "));
        } else if (type == SIM7500 || type == SIM7600) {
          Serial.print(F("Set Vol [0-5] "));
        } else {
          Serial.print(F("Set Vol % [0-100] "));
        uint8_t vol = readnumber();
        Serial.println();
        if (! fona.setVolume(vol)) {
        } else {
        break;
    case 'V': {
        uint8_t v = fona.getVolume();
        Serial.print(v);
          Serial.println(" / 8");
        } else if (type == SIM7500 || type == SIM7600) { // Don't write anything for SIM7500
          Serial.println();
        } else {
          Serial.println("%");
        break;
    case 'H': {
        // Set Headphone output
        if (! fona.setAudio(FONA_HEADSETAUDIO)) {
        } else {
        fona.setMicVolume(FONA_HEADSETAUDIO, 15);
        break;
    case 'e': {
        // Set External output
        if (! fona.setAudio(FONA_EXTAUDIO)) {
        } else {
        fona.setMicVolume(FONA_EXTAUDIO, 10);
        break;
    case 'T': {
        // play tone
        flushSerial();
        Serial.print(F("Play tone #"));
        uint8_t kittone = readnumber();
        Serial.println();
        // play for 1 second (1000 ms)
        if (! fona.playToolkitTone(kittone, 1000)) {
        } else {
        break;
    /*** PWM ***/
    case 'P': {
        // PWM Buzzer output @ 2KHz max
        flushSerial();
        Serial.print(F("PWM Freq, 0 = Off, (1-2000): "));
        uint16_t freq = readnumber();
        Serial.println();
        if (! fona.setPWM(freq)) {
        } else {
        break;
#endif
#ifdef SIMCOM_2G
    /*** FM Radio ***/
    case 'f': {
        // get freq
        flushSerial();
        Serial.print(F("FM Freq (eg 1011 == 101.1 MHz): "));
        uint16_t station = readnumber();
        Serial.println();
        // FM radio ON using headset
        if (fona.FMradio(true, FONA_HEADSETAUDIO)) {
          Serial.println(F("Opened"));
        if (! fona.tuneFMradio(station)) {
        } else {
          Serial.println(F("Tuned"));
        break;
    case 'F': {
        // FM radio off
        if (! fona.FMradio(false)) {
        } else {
        break;
    case 'm': {
        // Set FM volume.
        flushSerial();
        Serial.print(F("Set FM Vol [0-6]:"));
        Serial.println();
        if (!fona.setFMVolume(vol)) {
        } else {
        break;
    case 'M': {
        // Get FM volume.
        uint8_t fmvol = fona.getFMVolume();
        if (fmvol < 0) {
        } else {
          Serial.print(F("FM volume: "));
          Serial.println(fmvol, DEC);
        break;
    case 'q': {
        // Get FM station signal level (in decibels).
        flushSerial();
        Serial.println();
        int8_t level = fona.getFMSignalLevel(station);
        if (level < 0) {
          Serial.println(F("Failed! Make sure FM radio is on (tuned to station)."));
        } else {
          Serial.print(F("Signal level (dB): "));
          Serial.println(level, DEC);
        break;
#endif
    /*** SMS ***/
    case 'N': {
        // read the number of SMS's!
        int8_t smsnum = fona.getNumSMS();
        if (smsnum < 0) {
          Serial.println(F("Could not read # SMS"));
        } else {
          Serial.print(smsnum);
          Serial.println(F(" SMS's on SIM card!"));
        break;
    case 'r': {
        // read an SMS
        flushSerial();
        Serial.print(F("Read #"));
        uint8_t smsn = readnumber();
        Serial.print(F("\n\rReading SMS #")); Serial.println(smsn);
        // Retrieve SMS sender address/phone number.
        if (! fona.getSMSSender(smsn, replybuffer, 250)) {
          Serial.println("Failed!");
          break;
        Serial.print(F("FROM: ")); Serial.println(replybuffer);
        // Retrieve SMS value.
        uint16_t smslen;
        if (! fona.readSMS(smsn, replybuffer, 250, &smslen)) { // pass in buffer and max len!
          break;
        Serial.print(F("***** SMS #")); Serial.print(smsn);
        Serial.print(" ("); Serial.print(smslen); Serial.println(F(") bytes *****"));
        Serial.println(F("*****"));
        break;
    case 'R': {
        // read all SMS
        uint16_t smslen;
        int8_t smsn;
          smsn = 0; // zero indexed
          smsnum--;
        } else {
          smsn = 1;  // 1 indexed
        for ( ; smsn <= smsnum; smsn++) {
          if (!fona.readSMS(smsn, replybuffer, 250, &smslen)) {  // pass in buffer and max len!
            Serial.println(F("Failed!"));
            break;
          // if the length is zero, its a special case where the index number is higher
          // so increase the max we'll look at!
          if (smslen == 0) {
            Serial.println(F("[empty slot]"));
            smsnum++;
            continue;
        break;
    case 'd': {
        // delete an SMS
        flushSerial();
        Serial.print(F("Delete #"));
        Serial.print(F("\n\rDeleting SMS #")); Serial.println(smsn);
        if (fona.deleteSMS(smsn)) {
        } else {
          Serial.println(F("Couldn't delete"));
        break;
    case 's': {
        // send an SMS!
        char sendto[21], message[141];
        flushSerial();
        Serial.print(F("Send to #"));
        readline(sendto, 20);
        Serial.println(sendto);
        Serial.print(F("Type out one-line message (140 char): "));
        readline(message, 140);
        Serial.println(message);
        if (!fona.sendSMS(sendto, message)) {
        } else {
        break;
    case 'u': {
      // send a USSD!
      char message[141];
      flushSerial();
      uint16_t ussdlen;
      if (!fona.sendUSSD(message, replybuffer, 250, &ussdlen)) { // pass in buffer and max len!
      } else {
        Serial.print(F("***** USSD Reply"));
        Serial.print(" ("); Serial.print(ussdlen); Serial.println(F(") bytes *****"));
    /*** Time ***/
    case 'y': {
        // enable network time sync
        if (!fona.enableRTC(true))
          Serial.println(F("Failed to enable"));
        break;
    case 'Y': {
        // enable NTP time sync
        if (!fona.enableNTPTimeSync(true, F("pool.ntp.org")))
        break;
    case 't': {
        // read the time
        char buffer[23];
        fona.getTime(buffer, 23);  // make sure replybuffer is at least 23 bytes!
        Serial.print(F("Time = ")); Serial.println(buffer);
        break;
    /*********************************** GPS */
    case 'o': {
        // turn GPS off
        if (!fona.enableGPS(false))
          Serial.println(F("Failed to turn off"));
        break;
    case 'O': {
        // turn GPS on
        if (!fona.enableGPS(true))
          Serial.println(F("Failed to turn on"));
        break;
    case 'x': {
        int8_t stat;
        // check GPS fix
        stat = fona.GPSstatus();
        if (stat < 0)
          Serial.println(F("Failed to query"));
        if (stat == 0) Serial.println(F("GPS off"));
        if (stat == 1) Serial.println(F("No fix"));
        if (stat == 2) Serial.println(F("2D fix"));
        if (stat == 3) Serial.println(F("3D fix"));
        break;
    case 'L': {
        //deleted gps function
    case 'E': {
        flushSerial();
        if (type == SIM808_V1) {
          Serial.print(F("GPS NMEA output sentences (0 = off, 34 = RMC+GGA, 255 = all)"));
        } else {
          Serial.print(F("On (1) or Off (0)? "));
        uint8_t nmeaout = readnumber();
        // turn on NMEA output
        fona.enableGPSNMEA(nmeaout);
        break;
    /*********************************** GPRS */
    case 'g': {
        // turn GPRS off
        if (!fona.enableGPRS(false))
        break;
    case 'G': {
        // turn GPRS off first for SIM7500
        #if defined(SIMCOM_7500) || defined (SIMCOM_7600)
          fona.enableGPRS(false);
        #endif
        // turn GPRS on
        if (!fona.enableGPRS(true))
        break;
    case 'l': {
        // check for GSMLOC (requires GPRS)
        uint16_t returncode;
        if (!fona.getGSMLoc(&returncode, replybuffer, 250))
        if (returncode == 0) {
        } else {
          Serial.print(F("Fail code #")); Serial.println(returncode);
        break;
#if !defined(SIMCOM_3G) && !defined(SIMCOM_7500) && !defined(SIMCOM_7600)
    // The code below was written by Adafruit and only works on some modules
    case 'w': {
        // read website URL
        uint16_t statuscode;
        int16_t length;
        char url[80];
        flushSerial();
        Serial.println(F("URL to read (e.g. dweet.io/get/latest/dweet/for/sim7500test123):"));
        Serial.print(F("http://")); readline(url, 79);
        Serial.println(url);
        Serial.println(F("****"));
        if (!fona.HTTP_GET_start(url, &statuscode, (uint16_t *)&length)) {
          break;
        while (length > 0) {
          while (fona.available()) {
            char c = fona.read();
            // Serial.write is too slow, we'll write directly to Serial register!
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
            loop_until_bit_is_set(UCSR0A, UDRE0); /* Wait until data register empty. */
            UDR0 = c;
#else
            Serial.write(c);
#endif
            length--;
            if (! length) break;
        Serial.println(F("\n****"));
        fona.HTTP_GET_end();
        break;
    case 'W': {
        // Post data to website
        int16_t length;
        char url[80];
        char data[80];
        flushSerial();
        Serial.println(F("NOTE: in beta! Use simple websites to post!"));
        Serial.println(F("URL to post (e.g. httpbin.org/post):"));
        Serial.println(F("Data to post (e.g. \"foo\" or \"{\"simple\":\"json\"}\"):"));
        readline(data, 79);
        Serial.println(data);
        if (!fona.HTTP_POST_start(url, F("text/plain"), (uint8_t *) data, strlen(data), &statuscode, (uint16_t *)&length)) {
          break;
            UDR0 = c;
#else
            Serial.write(c);
#endif
            length--;
        fona.HTTP_POST_end();
        break;
#endif
#if defined(SIMCOM_2G) || defined(SIMCOM_7000)
    case '2': {
        // Post data to website via 2G or LTE CAT-M/NB-IoT
        float temperature = analogRead(A0)*1.23; // Change this to suit your needs
        uint16_t battLevel = 3600; // Dummy voltage in mV for testing
        // Create char buffers for the floating point numbers for sprintf
        // Make sure these buffers are long enough for your request URL
        char URL[150];
        char body[100];
        char tempBuff[16];
        char battLevelBuff[16];
        // Format the floating point numbers as needed
        dtostrf(temperature, 1, 2, tempBuff); // float_val, min_width, digits_after_decimal, char_buffer
        dtostrf(battLevel, 1, 0, battLevelBuff);
        // Construct the appropriate URL's and body, depending on request type
        // Use InEI as device ID for this example
        // GET request
        sprintf(URL, "dweet.io/dweet/for/%s?temp=%s&batt=%s", inei, tempBuff, battLevelBuff); // No need to specify http:// or https://
//        sprintf(URL, "http://dweet.io/dweet/for/%s?temp=%s&batt=%s", inei, tempBuff, battLevelBuff); // But this works too
        if (!fona.postData("GET", URL))
          Serial.println(F("Failed to complete HTTP GET..."));
        // POST request
        sprintf(URL, "http://dweet.io/dweet/for/%s", inei);
        sprintf(body, "{\"temp\":%s,\"batt\":%s}", tempBuff, battLevelBuff);
        if (!fona.postData("POST", URL, body)) // Can also add authorization token parameter!
          Serial.println(F("Failed to complete HTTP POST..."));
        break;
#endif
#if defined(SIMCOM_3G) || defined(SIMCOM_7500) || defined(SIMCOM_7600)
    case '3': {
        // Post data to website via 3G or 4G LTE
        // Voltage in mV, just for testing. Use the read battery function instead for real applications.
        uint16_t battLevel = 3700;
        char URL[150];
        char tempBuff[16];
        // GET request
        sprintf(URL, "GET /dweet/for/%s?temp=%s&batt=%s HTTP/1.1\r\nHost: dweet.io\r\n\r\n", inei, tempBuff, battLevelBuff);
        if (!fona.postData("www.dweet.io", 443, "HTTPS", URL)) // Server, port, connection type, URL
          Serial.println(F("Failed to complete HTTP/HTTPS request..."));
        break;
#endif
    case 'S': {
        Serial.println(F("Creating SERIAL TUBE"));
        while (1) {
          while (Serial.available()) {
            delay(1);
            fona.write(Serial.read());
        break;
    default: {
        return;
  // flush input
  flushSerial();
void flushSerial() {
    Serial.read();
char readBlocking() {
  while (!Serial.available());
  return Serial.read();
uint16_t readnumber() {
  uint16_t x = 0;
  char c;
  while (! isdigit(c = readBlocking())) {
    //Serial.print(c);
  Serial.print(c);
  x = c - '0';
  while (isdigit(c = readBlocking())) {
    Serial.print(c);
    x *= 10;
    x += c - '0';
  return x;
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout) {
  uint16_t buffidx = 0;
  boolean timeoutvalid = true;
  if (timeout == 0) timeoutvalid = false;
  while (true) {
    if (buffidx > maxbuff) {
      //Serial.println(F("SPACE"));
      break;
      char c =  Serial.read();
      //Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
      if (c == '\r') continue;
      if (c == 0xA) {
        if (buffidx == 0)   // the first 0x0A is ignored
          continue;
        timeout = 0;         // the second 0x0A is the end of the line
        break;
      buff[buffidx] = c;
      buffidx++;
    if (timeoutvalid && timeout == 0) {
      //Serial.println(F("TIMEOUT"));
      break;
    delay(1);
  buff[buffidx] = 0;  // null term
  return buffidx;
/*********************************************************mqtt connect *****************************************/
// will crash like a MOFO over LTE!!!
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);  // wait 5 seconds
  Serial.println("MQTT Connected!");
void printMenu(void) {
  Serial.println(F("-------------------------------------"));
  // General
  Serial.println(F("[?] Print this menu"));
  Serial.println(F("[a] Read the ADC; 2.8V max for SIM800/808, 0V-VBAT for SIM7000 shield"));
  Serial.println(F("[b] Read supply voltage")); // Will also give battery % charged for most modules
  Serial.println(F("[C] Read the SIM CCID"));
  Serial.println(F("[U] Unlock SIM with PIN code"));
  Serial.println(F("[i] Read signal strength (RSSI)"));
  Serial.println(F("[n] Get network status"));
  Serial.println(F("[1] Get network connection info")); // See what connection type and band you're on!
  // Audio
  Serial.println(F("[v] Set audio Volume"));
  Serial.println(F("[V] Get volume"));
  Serial.println(F("[H] Set headphone audio (SIM800/808)"));
  Serial.println(F("[e] Set external audio (SIM800/808)"));
  Serial.println(F("[T] Play audio Tone"));
  Serial.println(F("[P] PWM/buzzer out (SIM800/808)"));
#endif
  // Calling
  Serial.println(F("[c] Make phone Call"));
  Serial.println(F("[A] Get call status"));
  Serial.println(F("[h] Hang up phone"));
  Serial.println(F("[p] Pick up phone"));
#ifdef SIMCOM_2G
  // FM (SIM800 only!)
  Serial.println(F("[f] Tune FM radio (SIM800)"));
  Serial.println(F("[F] Turn off FM (SIM800)"));
  Serial.println(F("[m] Set FM volume (SIM800)"));
  Serial.println(F("[M] Get FM volume (SIM800)"));
  Serial.println(F("[q] Get FM station signal level (SIM800)"));
#endif
  // SMS
  Serial.println(F("[N] Number of SMS's"));
  Serial.println(F("[r] Read SMS #"));
  Serial.println(F("[R] Read all SMS"));
  Serial.println(F("[d] Delete SMS #"));
  Serial.println(F("[s] Send SMS"));
  Serial.println(F("[u] Send USSD"));
  // Time
  Serial.println(F("[y] Enable local time stamp (SIM800/808/70X0)"));
  Serial.println(F("[Y] Enable NTP time sync (SIM800/808/70X0)")); // Need to use "G" command first!
  Serial.println(F("[t] Get network time")); // Works just by being connected to network
  // Data Connection
  Serial.println(F("[G] Enable cellular data"));
  Serial.println(F("[g] Disable cellular data"));
  Serial.println(F("[l] Query GSMLOC (2G)"));
  Serial.println(F("[w] Read webpage"));
  Serial.println(F("[W] Post to website"));
#endif
  // The following option below posts dummy data to dweet.io for demonstration purposes. See the
  // IoT_example sketch for an actual application of this function!
  Serial.println(F("[2] Post to dweet.io - 2G / LTE CAT-M / NB-IoT")); // SIM800/808/900/7000/7070
  Serial.println(F("[3] Post to dweet.io - 3G / 4G LTE")); // SIM5320/7500/7600
  // GPS
  if (type >= SIM808_V1) {
    Serial.println(F("[O] Turn GPS on (SIM808/5320/7XX0)"));
    Serial.println(F("[o] Turn GPS off (SIM808/5320/7XX0)"));
    Serial.println(F("[L] Query GPS location (SIM808/5320/7XX0)"));
      Serial.println(F("[x] GPS fix status (FONA808 v1 only)"));
    Serial.println(F("[E] Raw NMEA out (SIM808)"));
  Serial.println(F("[S] Create serial passthru tunnel"));
  Serial.println(F(""));
void GPSpowerdown() {
  //Set GPS to save power by turning off antenna and such
  uint8_t GPSoff[] = {0xB5, 0x62, 0x06, 0x04, 0x04, 0x00, 0x00, 0x00,0x08, 0x00, 0x16, 0x74};
 sendUBX(GPSoff, sizeof(GPSoff)/sizeof(uint8_t));
void GPSpowerUP() {
  //Set GPS to Power up
  uint8_t GPSon[] = {0xB5, 0x62, 0x06, 0x04, 0x04, 0x00, 0x00, 0x00,0x09, 0x00, 0x17, 0x76};
 sendUBX(GPSon, sizeof(GPSon)/sizeof(uint8_t));
void powerdown() {
  Serial.println("Going to sleep now");
  Serial.flush();
  esp_deep_sleep_start();
  Serial.println("This will never be printed");
the error i get is:
https://github.com/TheRobertTalley/lily ... rash%20log
   ---> AT
   ---> AT
   ---> AT
   ---> AT
   ---> AT
   ---> AT
   ---> AT
   <--- +CPIN: READY
   ---> AT
   <--- AT
   ---> AT
   <--- AT
   ---> ATE0
   <--- ATE0
   ---> ATE0
   <--- OK
   ---> AT+GMR
   <--- Revision:1529B04SIM7000G
OK
   ---> AT+CPMS="SM","SM","SM"
   <--- +CPMS: 0,0,0,0,0,0
FONA is OK
Found    ---> AT+CFUN=1
   <--- OK
   ---> AT+CGDCONT=1,"IP","vzwinternet"
   <--- OK
   ---> AT+CBANDCFG="CAT-M",13
   <--- OK
   ---> AT+CNETLIGHT=0
   <--- OK
        SDCard MOUNT FAIL
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC      : 0x400893d8  PS      : 0x00060130  A0      : 0x800d224d  A1      : 0x3ffb1e70
A2      : 0x3ffb1ea8  A3      : 0x00000000  A4      : 0x0000000a  A5      : 0x3ffb1f0c
A6      : 0x00000020  A7      : 0x00000005  A8      : 0x3ffb1eb4  A9      : 0x00000000
A10     : 0x3ffb1eb1  A11     : 0x3ffb1eb1  A12     : 0x0000000a  A13     : 0x0000ff00
A14     : 0x00ff0000  A15     : 0xff000000  SAR     : 0x00000010  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000  LBEG    : 0x400889e4  LEND    : 0x40088a00  LCOUNT  : 0x00000000
ELF file SHA256: 0000000000000000
Backtrace: 0x400893d8:0x3ffb1e70 0x400d224a:0x3ffb1e90 0x400d1542:0x3ffb1f30 0x400d19a0:0x3ffb1f50 0x400d1a23:0x3ffb1f70 0x400d1ef2:0x3ffb1f90 0x400d84c1:0x3ffb1fb0 0x4008b38e:0x3ffb1fd0
Rebooting...
As soon as it attempts to connect to the MQTT server it crashes the esp, This is just out of reach for me at the moment. Any help or a nudge in the right direction, working example or a pointer on how to read and decipher esp error logs would be well appreciated. I have been stuck for a few days and more hours than I'd like to admit now.
-Talley
TheRobertTalley
Re: AIO esp32/sim7000 combo
by brubell on Mon Aug 02, 2021 10:09 am
To decipher the ESP's stack trace, install and use the esp exception decoder tool: https://github.com/me-no-dev/EspExceptionDecoder
brubell
by TheRobertTalley on Tue Aug 03, 2021 7:31 pm
You're my boy brubell!!!!!
from the other post:
#include <Adafruit_FONA.h> // https://github.com/botletics/SIM7000-LTE-Shield/tree/master/Code its TIM Woo's
#include <WiFi.h>
#define SIMCOM_7000            //pinset for a lilygo tcallsim7000 and external gps
#define FONA_RST 4
#define FONA_RX 27
#define RXPin 33
#define SD_MISO     2
#define SD_MOSI     15
#define SD_SCLK     14
#define SD_CS       13
#define LED_PIN     12
#define BAT_ADC     35
uint32_t x=0; //formqqttoconnect
/*****************************************************MODEM***********************************/
Adafruit_FONA_LTE fona = Adafruit_FONA_LTE();//woo modem marker
uint8_t type;
char EYEEMEEEEYE[16] = {0}; // MUST use a 16 character buffer for EYEEMEEEEYE!
#define WLAN_SSID "ATTnggggg"       //Guest Wifi
#define WLAN_PASS "faec7ggggg"
// Using port 8883 for MQTTS
#define AIO_SERVERPORT  8883  //1883
// Adafruit IO Account Configuration
// (to obtain these values, visit https://io.adafruit.com and click on Active Key)
#define AIO_USERNAME  "usernameyname"
#define AIO_KEY       "aio_keypoo"
// WiFiFlientSecure for SSL/TLS support
WiFiClientSecure client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
// io.adafruit.com root CA
const char* adafruitio_root_ca = \
    "-----BEGIN CERTIFICATE-----\n" \
    "MIIDrzCCApegAwIBAgIQCDvgVpBCRrGhdWrJWZHHSjANBgkqhkiG9w0BAQUFADBh\n" \
    "MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3\n" \
    "d3cuZGlnaWNlcnQuY29tMSAwHgYDVQQDExdEaWdpQ2VydCBHbG9iYWwgUm9vdCBD\n" \
    "QTAeFw0wNjExMTAwMDAwMDBaFw0zMTExMTAwMDAwMDBaMGExCzAJBgNVBAYTAlVT\n" \
    "MRUwEwYDVQQKEwxEaWdpQ2VydCBJbmMxGTAXBgNVBAsTEHd3dy5kaWdpY2VydC5j\n" \
    "b20xIDAeBgNVBAMTF0RpZ2lDZXJ0IEdsb2JhbCBSb290IENBMIIBIjANBgkqhkiG\n" \
    "9w0BAQEFAAOCAQ8AMIIBCgKCAQEA4jvhEXLeqKTTo1eqUKKPC3eQyaKl7hLOllsB\n" \
    "CSDMAZOnTjC3U/dDxGkAV53ijSLdhwZAAIEJzs4bg7/fzTtxRuLWZscFs3YnFo97\n" \
    "nh6Vfe63SKMI2tavegw5BmV/Sl0fvBf4q77uKNd0f3p4mVmFaG5cIzJLv07A6Fpt\n" \
    "43C/dxC//AH2hdmoRBBYMql1GNXRor5H4idq9Joz+EkIYIvUX7Q6hL+hqkpMfT7P\n" \
    "T19sdl6gSzeRntwi5m3OFBqOasv+zbMUZBfHWymeMr/y7vrTC0LUq7dBMtoM1O/4\n" \
    "gdW7jVg/tRvoSSiicNoxBN33shbyTApOB6jtSj1etX+jkMOvJwIDAQABo2MwYTAO\n" \
    "BgNVHQ8BAf8EBAMCAYYwDwYDVR0TAQH/BAUwAwEB/zAdBgNVHQ4EFgQUA95QNVbR\n" \
    "TLtm8KPiGxvDl7I90VUwHwYDVR0jBBgwFoAUA95QNVbRTLtm8KPiGxvDl7I90VUw\n" \
    "DQYJKoZIhvcNAQEFBQADggEBAMucN6pIExIK+t1EnE9SsPTfrgT1eXkIoyQY/Esr\n" \
    "hMAtudXH/vTBH1jLuG2cenTnmCmrEbXjcKChzUyImZOMkXDiqw8cvpOp/2PV5Adg\n" \
    "06O/nVsJ8dWO41P0jmP6P6fbtGbfYmbW0W5BjfIttep3Sp+dWOIrWcBAI+0tKIJF\n" \
    "PnlUkiaY4IBIqDfv8NZ5YBberOgOzW6sRBc4L0na4UU+Krk2U886UAb3LujEV0ls\n" \
    "YSEY1QSteDwsOoBrp+uvFRTp2InBuThs4pFsiv9kuXclVzDAGySj4dzp30d8tbQk\n" \
    "CAUw7C29C79Fv1C5qfPrmAESrciIxpg0X40KPMbp1ZWVbd4=\n" \
    "-----END CERTIFICATE-----\n";
/****************************** Feeds ***************************************/
// Setup a feed called 'test' for publishing.
Adafruit_MQTT_Publish test1 = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/test");
  delay(500);
  startmodem();
  delay(500);
  checknet();
  delay(5000);
  wificonnect();  //set cert
  //printMenu();
  Serial.println("triggering mqqt connect");
  MQTT_connect();
  pubstuff();
void startmodem() {
  type = fona.type();
  switch (type) {
    case SIM800L:
      Serial.println(F("SIM800L")); break;
    case SIM800H:
      Serial.println(F("SIM800H")); break;
    case SIM808_V1:
      Serial.println(F("SIM808 (v1)")); break;
    case SIM808_V2:
      Serial.println(F("SIM808 (v2)")); break;
    case SIM5320A:
      Serial.println(F("SIM5320A (American)")); break;
    case SIM5320E:
      Serial.println(F("SIM5320E (European)")); break;
    case SIM7000:
      Serial.println(F("SIM7000")); break;
    case SIM7070:
      Serial.println(F("SIM7070")); break;
    case SIM7500:
      Serial.println(F("SIM7500")); break;
    case SIM7600:
      Serial.println(F("SIM7600")); break;
    default:
      Serial.println(F("???")); break;
  // Print module EYEEMEEEEYE number.
  uint8_t EYEEMEEEEYELen = fona.getEYEEMEEEEYE(EYEEMEEEEYE);
  if (EYEEMEEEEYELen > 0) {
    Serial.print("Module EYEEMEEEEYE: "); Serial.println(EYEEMEEEEYE);
  fona.setNetworkSettings(F("vzwinternet"), F(""), F(""));  //for verizon
void wificonnect() {  //i dont want the wifi
  /*Serial.println(F("Adafruit IO MQTTS (SSL/TLS) Example"));
  // Connect to WiFi access point.
  delay(1000);
  delay(2000);
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.println("IP address: "); Serial.println(WiFi.localIP()); */
  // Set Adafruit IO's root CA
  //client.setCACert(adafruitio_root_ca);
  fona.addRootCA(adafruitio_root_ca);
  Serial.println("sert is on");
  int8_t ret;
    return;
  uint8_t retries = 3;
       mqtt.disconnect();
       retries--;
       if (retries == 0) {
         // basically die and wait for WDT to reset me
         while (1);
void pubstuff() {
  // Now we can publish stuff!
  Serial.print(F("\nSending val "));
  Serial.print(x);
  Serial.print(F(" to test feed..."));
  if (! test1.publish(x++)) {
  } else {
  // wait a couple seconds to avoid rate limit
  delay(2000);
void checknet() {
        Serial.print(n);
        if (n < 5) Serial.println(F("Not registered"));{
            Serial.println("start again");
            delay(2000);
            startmodem();
        if (n == 5) Serial.println(F("Registered roaming"));{
          return;
void GPRSon(){
  // turn GPRS on
  if (!fona.enableGPRS(true)){
   delay(2000);
   GPRSon();
/******* ORIGINAL ADAFRUIT FONA LIBRARY TEXT *******/
  This is an example for our Adafruit FONA Cellular Module
  Designed specifically to work with the Adafruit FONA
  ----> http://www.adafruit.com/products/1946
  ----> http://www.adafruit.com/products/1963
  ----> http://www.adafruit.com/products/2468
  ----> http://www.adafruit.com/products/2542
  These cellular modules use TTL Serial to communicate, 2 pins are
  required to interface
  products from Adafruit!
I am attempting to Connect to AIO and now I get a simple "Connecting to MQTT... Connection failed" instead of crashing the ESP32.
I am once again banging my head on the wall and would love a little help in the right direction. YOUR MY BOY BRUBELL!
*EYEEMEEEEYE*was changed
TheRobertTalley
by TheRobertTalley on Fri Aug 06, 2021 11:23 pm
TheRobertTalley
by brubell on Mon Aug 09, 2021 10:00 am
Try modifying:
To
#define AIO_SERVERPORT 1883
brubell
by TheRobertTalley on Wed Aug 11, 2021 8:40 pm
LOL. that didnt fix all my issues though here is what worked if someone is looking:
https://github.com/TheRobertTalley/lily ... fruit%20IO
I would post it here but EYEEMEEEYE* is a spam word.
TheRobertTalley
