Adafruit IO with Micropython?
by rmarlan on Thu Aug 05, 2021 4:31 pm
I would like to use Adafruit IO with Micropython not Circus Python. This is what my board requires. Is there any getting started guide or tutorial for using Micropython? Thanks!
rmarlan
Re: Adafruit IO with Micropython?
by dastels on Thu Aug 05, 2021 5:32 pm
Use of Adafruit IO is through either an MQTT or RESTful API, so it's language agnostic. Additionally, since CircuitPython is a fork of MicroPython it should be a fairly simple matter to get the CircuitPython AdafruitIO library running with MicroPython.
dastels
by rmarlan on Thu Aug 05, 2021 7:49 pm
@dastels
Thanks - that makes it too easy.
I didn't know if adafruit io used standard MQTT or a proprietary platform.
rmarlan
by brubell on Mon Aug 09, 2021 10:04 am
rmarlan wrote:@dastels
Standard MQTT! Check out the MQTT API documentation here: https://io.adafruit.com/api/docs/mqtt.html
brubell
