Report feed value in Alexa
by eframe on Sun Sep 19, 2021 10:47 am
Is there a way to ask Alexa to get a value from a feed? I have a temperature sensor in my barn that sends the temperature every few minutes to an Adafruit IO feed and I would like to be able ask Alexa what the temperature is in the barn.
eframe
Re: Report feed value in Alexa
by mikeysklar on Sun Sep 19, 2021 7:53 pm
@eframe,
Our FAQ suggests using IFTT to bridge AIO and Alexa.
https://learn.adafruit.com/welcome-to-a ... aq-2990207
mikeysklar
by eframe on Sun Sep 19, 2021 8:30 pm
That's only for posting to Adafruit IO from Alexa not going the other way.
eframe
by mikeysklar on Mon Sep 20, 2021 12:55 pm
@eframe,
I don't see a guide on the Adafruit side that details how to connect query Alexa for AIO data.
It might be worth checking out Zapier setup and see how well they integrate AIO <--> Alexa. It might just work for your question of "What temperature is the barn".
https://zapier.com/apps/amazon-alexa/in ... dafruit-io
mikeysklar
by hcs_system on Mon Sep 27, 2021 7:45 am
eframe wrote:Is there a way to ask Alexa to get a value from a feed? I have a temperature sensor in my barn that sends the temperature every few minutes to an Adafruit IO feed and I would like to be able ask Alexa what the temperature is in the barn.
This can be done with a Node-Red flow by activating the Alexa Remote2 palette.
You should set up an MQTT-in palette to connect on adafruit.io, with this way you can read the feed data and then send it to Alexa via the Alexa-Echo palette. ;-)
hcs_system
by hcs_system on Mon Sep 27, 2021 8:49 am
Sorry, not Alexa Echo palette, but Alexa Routine palette
hcs_system
