C# MotorHat Both Stepper Motors Run Same Time?
by cschron on Sat Sep 25, 2021 9:46 am
I'm using Adafruit Class Library for Windows IoT Core with the MotorHat.
I can get the stepper motors 1 & 2 to work individually. How do I get BOTH to work at the same time?
Looking for examples in C#.
Thanks!!
cschron
Re: C# MotorHat Both Stepper Motors Run Same Time?
by franklin97355 on Sat Sep 25, 2021 7:54 pm
Please post you code so we can see what you've tried.
franklin97355
by cschron on Sun Sep 26, 2021 7:51 am
Below is the code. When the button is pressed Stepper 1 works then Stepper 2 works. But what I want is both Steppers to go at same time. THANKS!!
using Windows.UI.Xaml;
using AdafruitClassLibrary;
namespace Blinky
    public sealed partial class MainPage
       static MotorHat motorHat;
       static MotorHat.Stepper stepper1;
       static MotorHat.Stepper stepper2;
    public MainPage()
            InitializeComponent();
           motorHat = new MotorHat();
           motorHat.InitAsync(1600).ConfigureAwait(true);
            stepper1 = motorHat.GetStepper(100, 1);
            stepper2 = motorHat.GetStepper(100, 2);
   private void buttonON_Click(object sender, RoutedEventArgs e)
            while (true)
                motor1();
                motor2();
        public void motor1() {
                   stepper1.SetSpeed(500); //10 rpm
                   stepper1.step(2000, MotorHat.Stepper.Command.FORWARD, MotorHat.Stepper.Style.DOUBLE);
        public void motor2()
                stepper2.SetSpeed(500); //10 rpm
                stepper2.step(2000, MotorHat.Stepper.Command.FORWARD, MotorHat.Stepper.Style.DOUBLE);
cschron
by adafruit2 on Sun Sep 26, 2021 4:49 pm
you should perform one step at a time, interleaved
adafruit2
Site Admin
by cschron on Mon Sep 27, 2021 2:47 pm
Thank you that worked!
cschron
