Feed has been disabled
by weal on Tue Sep 28, 2021 11:46 am
This feed has been disabled. You can read data, but can no longer modify the feed or add new data.
What does this mean? How to fix it?
weal
Re: Feed has been disabled
by franklin97355 on Tue Sep 28, 2021 12:26 pm
What version of Adafruitio do you have? Adafruitio free has a 'throttle' that regulates the amount and speed you can input data.
franklin97355
by weal on Tue Sep 28, 2021 12:52 pm
Thank you for your reply.
I have had Adafruit IO+, and now the free version.
weal
by jwcooper on Tue Sep 28, 2021 1:14 pm
When you downgrade from IO+, the feed limit is set to 10 feeds. Any feeds over that limit are disabled and unable to be used. You can delete those feeds if you'd like. I believe we keep the 10 most recently used feeds, and disable the rest.
When downgrading, there should be a pretty clear description of how it all works.
jwcooper
