It's Holiday Sale Weekend at Adafruit - use the code ADATY to get 15% off items storewide! Some restrictions apply.
Help finding the proper libraries
by hextejas on Sat Oct 16, 2021 10:01 am
My code is calling out 2 libraries that seem to be a mess.
Adafruit_MCP23017.h
Adafruit_RGBLCDShield.h
The library manager points to Arduino-mcp23017 and Adafruit_ tinyRGBLCDShield_Master.
What's going on ? These libraries seem to be a mess as to naming conventions.
hextejas
Re: Help finding the proper libraries
by franklin97355 on Sat Oct 16, 2021 10:59 am
Where did you get the code you are trying to run and what board is it?
franklin97355
by hextejas on Sat Oct 16, 2021 12:36 pm
The code is from github
https://github.com/k3ng/k3ng_rotator_controller
and the board is a Arduino Mega R3.
I had started to modify it to select some of the supposedly options when I ran into the library mess.
Here are some statements that cause an error after I made this change:
Original code
// #define FEATURE_ADAFRUIT_I2C_LCD
My change...Just uncommented
and it caused the following error.
#if defined(FEATURE_ADAFRUIT_I2C_LCD)
  #include <Adafruit_MCP23017.h>
  #include <Adafruit_RGBLCDShield.h>
             <=====[b]exit status 1 Adafruit_RGBLCDShield.h: No such file or directory[/b]==========>
  Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
#endif
When I started to try and sort out the above error, I ran into a lot more.
hextejas
