Change Min Max in program
by AstroGuy on Sat Oct 16, 2021 2:01 pm
I would like to change the min and max settings of a feed on the fly (from within the program) using inputted data....
AstroGuy
Re: Change Min Max in program
by brubell on Mon Oct 18, 2021 9:38 am
Which library are you working with?
What do you mean by "min and max settings of a feed"
brubell
by AstroGuy on Mon Oct 18, 2021 4:31 pm
this is not a library it is the IOT....I have a gauge as one feed that has a min of 0 and a max of 400...can I change that in my python code or do I need to change the gauge online every time I run my project....
AstroGuy
by jwcooper on Mon Oct 18, 2021 4:46 pm
You can edit blocks via the api. In that situation, you could programmatically update the min/max values of the gauge block.
Here is the documentation:
https://io.adafruit.com/api/docs/?shell#replace-a-block
One note, the "dashboard_id" in the api call should be the 'key'. We'll have to update that. For now, you can get the key by using the last value in the url when viewing your dashboard, or by getting the key from the dashboards API.
jwcooper
by AstroGuy on Wed Oct 20, 2021 3:17 pm
Thanks, but API docs mean nothing to me...I need examples in python but the examples in the api doc are useless.
AstroGuy
by jwcooper on Thu Oct 21, 2021 2:47 pm
I don't believe our python clients support modifying blocks programmatically as this isn't a common use case.
We do accept pull requests, and you can find our python libraries below if you'd like to contribute this feature:
https://github.com/adafruit/Adafruit_Ci ... AdafruitIO
https://github.com/adafruit/Adafruit_IO_Python
jwcooper
