It's Holiday Sale Weekend at Adafruit - use the code ADATY to get 15% off items storewide! Some restrictions apply.
MQTT subscriptions callback doesn't work
by aelorenzo on Sun Oct 17, 2021 5:52 pm
Hi all!
I have an Arduino Sketch for an ESP32 board (ESPDUINO), configured to use my free MQTT Adafruit IO account services.
I am subscribed to two feeds linked to the dashboard (a slider and a button), and defined as follows:
Slider: Name: led-int Key: led-int
Button: Name: led-onoff Key: led-onoff
and I publish in two feeds without any problem with the same wificlientsecure instance (mqtt).
If I modified the value of the slider or the button state in the dashboard, no data arrived to the device.
I have tried several ways to setup the subs, etc...
any help please?
The code declarations for the subs are:
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
/****************************** Feeds ***************************************/
// Setup feeds for subscribing
Adafruit_MQTT_Subscribe LED_int_feed = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/led-int", MQTT_QOS_1);
Adafruit_MQTT_Subscribe LED_onoff_feed = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/led-onoff", MQTT_QOS_1);
void LEDintcallback(double x) {
  Serial.print("Hey we're in a slider callback, the slider value is: ");
  Serial.println(x);
void LEDonoffcallback(char *data, uint16_t len) {
  Serial.print("Hey we're in a onoff callback, the button value is: ");
  Serial.println(data);
And in the setup():
// Set Adafruit IO's root CA
  client.setCACert(adafruitio_root_ca);
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  Serial.println("done");
  Serial.print("Starting MQTT client... ");
 * Subscribing configuration
  LED_int_feed.setCallback(LEDintcallback);
  LED_onoff_feed.setCallback(LEDonoffcallback);
// Setup MQTT subscription
  mqtt.subscribe(&LED_int_feed);
  mqtt.subscribe(&LED_onoff_feed);
In the loop() section:
  MQTT_connect();
  // Now we can publish stuff!
  if (! TD_feed.publish(tdsValue)) {
    Serial.println(F("Failed TD feed"));
  } else {
    Serial.println(F("TD feed published"));
  if (! Temp_feed.publish(tempavg)) {
    Serial.println(F("Failed temperature feed"));
  } else {
    Serial.println(F("Temperature feed published"));
  Serial.println();
// MQTT subcriptions
// this is our 'wait for incoming subscription packets and callback em' busy subloop
// try to spend your time here:
  mqtt.processPackets(10000);
aelorenzo
Re: MQTT subscriptions callback doesn't work
by brubell on Mon Oct 18, 2021 9:33 am
Could you please copy and paste the full code here so I can take a look, thank you.
brubell
by aelorenzo on Mon Oct 18, 2021 3:33 pm
Hi @brubell,
Here is a sketch that I used just to test the Adafruit IO functions.
I trimmed all the "not related" code.
 * DESCRIPTION
#include <WiFi.h>
#include "WiFiClientSecure.h"
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#include <ESPmDNS.h>
#include <Pushover.h>
#include <IRremoteESP8266.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <TimeLib.h>
#include <Timezone.h>
#include <time.h>
#include <IRutils.h>
#include <IRsend.h>
#include <RCSwitch.h>
#include <Dusk2Dawn.h>
#include "config.h"
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Fonts/Org_01.h>
static const uint8_t LED_BUILTIN = 2;
#define BUILTIN_LED  LED_BUILTIN // backward compatibility
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     -1 // Reset pin # (or -1 if sh aring Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
/************************* Adafruit.io Setup *********************************/
// Create an ESP32 WiFiClient class to connect to the MQTT server.
WiFiClientSecure client;
#define AIO_SERVER      "io.adafruit.com"
// Using port 8883 for MQTTS
#define AIO_SERVERPORT  8883
// Adafruit IO Account Configuration
// (to obtain these values, visit https://io.adafruit.com and click on Active Key)
#define AIO_USERNAME  "XXXXX"
#define AIO_KEY       "XXXX"
// Setup a feeds for subscribing
// Setup a feeds for publishing.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
Adafruit_MQTT_Publish TDS_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/TDS");
Adafruit_MQTT_Publish Temperature_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/Temperature");
// MQTT example
  Serial.println(x);
// io.adafruit.com root CA
const char* adafruitio_root_ca = \
    "-----BEGIN CERTIFICATE-----\n" \
    "MIIDrzCCApegAwIBAgIQCDvgVpBCRrGhdWrJWZHHSjANBgkqhkiG9w0BAQUFADBh\n" \
    "MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3\n" \
    "d3cuZGlnaWNlcnQuY29tMSAwHgYDVQQDExdEaWdpQ2VydCBHbG9iYWwgUm9vdCBD\n" \
    "QTAeFw0wNjExMTAwMDAwMDBaFw0zMTExMTAwMDAwMDBaMGExCzAJBgNVBAYTAlVT\n" \
    "MRUwEwYDVQQKEwxEaWdpQ2VydCBJbmMxGTAXBgNVBAsTEHd3dy5kaWdpY2VydC5j\n" \
    "b20xIDAeBgNVBAMTF0RpZ2lDZXJ0IEdsb2JhbCBSb290IENBMIIBIjANBgkqhkiG\n" \
    "9w0BAQEFAAOCAQ8AMIIBCgKCAQEA4jvhEXLeqKTTo1eqUKKPC3eQyaKl7hLOllsB\n" \
    "CSDMAZOnTjC3U/dDxGkAV53ijSLdhwZAAIEJzs4bg7/fzTtxRuLWZscFs3YnFo97\n" \
    "nh6Vfe63SKMI2tavegw5BmV/Sl0fvBf4q77uKNd0f3p4mVmFaG5cIzJLv07A6Fpt\n" \
    "43C/dxC//AH2hdmoRBBYMql1GNXRor5H4idq9Joz+EkIYIvUX7Q6hL+hqkpMfT7P\n" \
    "T19sdl6gSzeRntwi5m3OFBqOasv+zbMUZBfHWymeMr/y7vrTC0LUq7dBMtoM1O/4\n" \
    "gdW7jVg/tRvoSSiicNoxBN33shbyTApOB6jtSj1etX+jkMOvJwIDAQABo2MwYTAO\n" \
    "BgNVHQ8BAf8EBAMCAYYwDwYDVR0TAQH/BAUwAwEB/zAdBgNVHQ4EFgQUA95QNVbR\n" \
    "TLtm8KPiGxvDl7I90VUwHwYDVR0jBBgwFoAUA95QNVbRTLtm8KPiGxvDl7I90VUw\n" \
    "DQYJKoZIhvcNAQEFBQADggEBAMucN6pIExIK+t1EnE9SsPTfrgT1eXkIoyQY/Esr\n" \
    "hMAtudXH/vTBH1jLuG2cenTnmCmrEbXjcKChzUyImZOMkXDiqw8cvpOp/2PV5Adg\n" \
    "06O/nVsJ8dWO41P0jmP6P6fbtGbfYmbW0W5BjfIttep3Sp+dWOIrWcBAI+0tKIJF\n" \
    "PnlUkiaY4IBIqDfv8NZ5YBberOgOzW6sRBc4L0na4UU+Krk2U886UAb3LujEV0ls\n" \
    "YSEY1QSteDwsOoBrp+uvFRTp2InBuThs4pFsiv9kuXclVzDAGySj4dzp30d8tbQk\n" \
    "CAUw7C29C79Fv1C5qfPrmAESrciIxpg0X40KPMbp1ZWVbd4=\n" \
    "-----END CERTIFICATE-----\n";
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println("Retrying MQTT connection in 5 seconds...");
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
       retries--;
       if (retries == 0) {
         // basically die and wait for WDT to reset me
         while (1);
  Serial.println("MQTT Connected!");
  unsigned long current_millis;
  unsigned long start_millis;
  unsigned long timing;
void setup(void){
  Serial.begin(115200);
  while (!Serial)  // Wait for the serial connection to be establised.
    delay(500);
  WiFi.mode(WIFI_STA);
  WiFi.begin(SSID, PASSWORD);
  Serial.println();
  Serial.print("Trying to set WIFI link up");
  // Wait for connection
  while (WiFi.status() != WL_CONNECTED) {  //TODO no wifi available
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.print("Connected to ");
  Serial.println(SSID);
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());
  WiFi.setAutoReconnect(true);
  WiFi.persistent(true);
// MQTT
  Serial.print("Starting Adafruit MQTT service... ");
  MQTT_connect();
void loop(void){
  Serial.println();
  Serial.println("Tasks LOOP started");
  Serial.println();
  current_millis = millis();
// Check WIFI status
  switch (WiFi.status()){
    case WL_NO_SSID_AVAIL:
      Serial.println("WIFI configured SSID cannot be reached");
      break;
    case WL_CONNECTED:
      Serial.println("WIFI connection successfully established");
      break;
    case WL_CONNECT_FAILED:
      Serial.println("WIFI connection failed");
      break;
  int wifi_rssi = WiFi.RSSI();
  Serial.printf("WIFI connection status: %d RSSI %d", WiFi.status(),wifi_rssi);
  Serial.println();
  float tdsValue = 414.14;
  float tempavg = 26.0;
// MQTT publishing
  Serial.println();
  Serial.println(F("MQTT publishing..."));
  MQTT_connect();
  if (! TDS_feed.publish(tdsValue)) {
    Serial.println(F("Failed TDS feed"));
  } else {
    Serial.println(F("TDS feed published"));
  if (! Temperature_feed.publish(tempavg)) {
  } else {
// Timing
  Serial.println();
  timing = millis()-current_millis;
  Serial.print("Tasks took (ms): ");
  Serial.println(timing);
  Serial.println();
  Serial.println("Waiting for new tasks cycle...");
  Serial.println();
  Serial.print("Free memory: ");
  Serial.print(ESP.getFreeHeap(),DEC);
  Serial.print(" Running for (mins): ");
  Serial.println(((millis()/1000)/60));
  Serial.println();
  mqtt.processPackets(10000-timing);
aelorenzo
by aelorenzo on Wed Oct 20, 2021 4:13 am
Hi again!
Is this sketch useful for you?
I have the same problem with this simplified version of my project.
I left the includes for all the libraries that I am using just to be able to check if maybe there is some kind of incompatibility.
Thank you!
aelorenzo
by aelorenzo on Fri Oct 22, 2021 12:28 pm
I have read more info, and I think that this setup should work. Why it doesn´t work?
Any help would be appreciated.
Thank you!
aelorenzo
by aelorenzo on Sat Oct 23, 2021 3:39 pm
Solved.
I have two MQTT_connect() calls, one in setup and another in loop.
Only one, and in the loop section of the sketch should be used.
aelorenzo
by brubell on Mon Oct 25, 2021 9:56 am
  MQTT_connect();
Place the mqtt_connect call after the subscription and callback calls, it should be last. The connect() call sends all information relating to the client's setup to the broker.
brubell
