Using NEOPixel with NEO_RGB & NEO_GRB not working
by NM_Artist on Tue Oct 26, 2021 1:29 am
Hi, I have two types of NEOPIXELS from Adafruit. One is NEO_GRB and the other, that I just received, is NEO_RGB. Using #include <Adafruit_NeoPixel.h> I can daisy chain these on a breadboard, but Red and Green colors are switched when given the same hex code. I have attempted creating an additional object for each NEO_GRB and NEO_RGB, i.e.,
Adafruit_NeoPixel pixel_1(PIXELCOUNT, PIXELPIN_1, NEO_RGB + NEO_KHZ800); // declare object
Adafruit_NeoPixel pixel_2(PIXELCOUNT, PIXELPIN_2, NEO_GRB + NEO_KHZ800); // declare object
When I do this only the NEOPIXEL for pixel_1 lights up with the following code:
pixel_1.begin();
pixel_2.begin();
bri = 100;
pixel_1.setBrightness(bri);
pixel_2.setBrightness(bri);
pixel_1.setPixelColor(n, 0xFF0000); // Sets LED on pin 11 to Red
pixel_2.setPixelColor(1, 0xFF0000); // Sets LED on pin 12 to Red
delay(500);
pixel_1.show();
pixel_2.show();
I'm seeking advice for the best way to use two Adafruit_NeoPixel objects in the same program, or, failing that, what is a work-around might be for using both RGB and GRB Neopixels in the same program.
Thank you
NM_Artist
Re: Using NEOPixel with NEO_RGB & NEO_GRB not working
by dastels on Tue Oct 26, 2021 8:06 am
A couple questions:
What happens if you swap the order of the two begin calls?
What MCU/board are you running this on?
dastels
by NM_Artist on Tue Oct 26, 2021 10:26 am
Hi Dave,
Thanks for responding :) I'm doing this on a Teensy 3.2, but the problem was in my array addressing. When I created the second object,
"pixel_2.setPixelColor(1, 0xFF0000); // Sets LED on pin 12 to Red,"
I forgot to set the array call for the 1st pixel to 0, from 1.
After making that change it's working correctly now.
Best,
Ivan
NM_Artist
by dastels on Tue Oct 26, 2021 10:30 am
OK, cool.
dastels
