Extracting On Off Data Points
by Buzzie8 on Tue Nov 30, 2021 10:26 am
Hi all, I want to be able to extract on and off data from a dashboard I created on Adafruit IO. My sensor senses a vibration on and off but I need to extract the on-off times to create a timestamp and duration database that I can use for some other analytics that I am working on. Essentially, I need to be able to take on off data points and move them into a spreadsheet/database for now. Any similar projects to review that do this? Any guidance is greatly appreciated.
Buzzie8
Re: Extracting On Off Data Points
by mikeysklar on Thu Dec 02, 2021 2:16 pm
It seems like this should be doable using "Get Feed Data" we supply some examples in the documentation using curl to pull down the data in formats you could import to a spreadsheet.
https://io.adafruit.com/api/docs/#get-feed-data
A more elaborate setup to lookup for automatic logging to a spreadsheet of on/off durations in the future would be the time tracking cube.
https://learn.adafruit.com/time-tracking-cube
mikeysklar
