Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days.
Problems Sending String Payloads with Adafruit IO Arduino Li
by okyang on Tue Dec 07, 2021 2:54 am
I've been scratching my head for a while on trying to send Strings to Adafruit IO using Arduino (with the ultimate goal trying to send a base64 image that usually has over 1000 characters). I'm not an expert, but I tried a couple simple tests and ran into some interesting problems. Was wondering if it is a bug with the library or my code or something else.
Here were my findings:
1. `String` and `char *` payloads that were 100 characters in length did not show up in Adafruit IO feed, but the `save` method still returned a `1` for `true`
2. `const char *` payloads showed up as a boolean in the Adafruit IO feed
More context:
1. I am using PlatformIO
2. Tested on ESP32-CAM
Thank you :)
#include <Arduino.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#include "config.h"
// Adafruit IO
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
AdafruitIO_Feed *imageFeed = io.feed(IMAGE_FEEDNAME);
bool chrPayloadTest(int payloadLen, AdafruitIO_Feed*  feed) {
  char t[payloadLen +1];
  for (int i=0; i<payloadLen; i++){
    t[i] = 'a';
  t[payloadLen-1] = 0;
  char * test = t;
  Serial.println(test);
  return imageFeed->save(test);
bool constChrPayloadTest(int payloadLen, AdafruitIO_Feed*  feed) {
    t[i] = 'a';
  const char * test = t;
bool strPayloadTest(int payloadLen, AdafruitIO_Feed*  feed) {
  String test;
    test+= 'a';
  Serial.begin(115200);
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  Serial.println();
  Serial.println(io.statusText());
  io.run();
  // 1.1 - char of len 10
  Serial.println("1.1");
  Serial.println(chrPayloadTest(10, imageFeed));
  delay(5000);
  // 1.2 - char of len 100
  Serial.println("1.2");
  Serial.println(chrPayloadTest(100, imageFeed));
  delay(5000);
  // 2.1 - const char of len 10
  Serial.println("2.1");
  Serial.println(constChrPayloadTest(10, imageFeed));
  delay(5000);
  // 2.2 - const char of len 100
  Serial.println("2.2");
  Serial.println(constChrPayloadTest(100, imageFeed));
  delay(5000);
  // 3.1 - String of len 10
  Serial.println("3.1");
  Serial.println(strPayloadTest(100, imageFeed));
  delay(5000);
  // 3.2 - String of len 100
  Serial.println("3.2");
  Serial.println(strPayloadTest(10, imageFeed));
  delay(5000);
Screenshot 2021-12-06 224804.png (27.97 KiB) Viewed 212 times
okyang
