Adafruit RP2040 flush/empty buffer
TobyGraf
Post by TobyGraf »
I am using an Adafruit RP2040 and have it set up with 2 Rotary encoders and a small display. When I start the program I can change the value on the display using the Rotary encoders, but as soon as I set the value via PC command the two Rotary encoders don't react anymore. I tried to close the instance with the pc but still nothing. I can reconnect the PC again after closing the instance and set the values via PC again, but no reactions from the Rotary encoders anymore until I restart the whole RP2040.
Is there a command I can use to make the RP2040 listen to the encoders again?
Here is the code I use to establish connection:
 import pyvisa
import board
import time
resources = rm.list_resources()
foundInstr = None
for iRes in resources:
    if 'ASRL6' in iRes:
        foundInstr = iRes
    if foundInstr != None:
        inst = rm.open_resource(foundInstr)
and here the code I use to set the value and read back the set value:
 inst.clear()
inst.write('250')
value = inst.read()
print(value)
Thank you very much for your help
TobyGraf
Re: Adafruit RP2040 flush/empty buffer
Post by TobyGraf »
I use the supervisor.runtime to check for an input:
if supervisor.runtime.serial_bytes_available:  # 65536        /    0,000050354
    cmd = input()
    if cmd.replace('.','',1).isdigit() and cmd[0] in ['1','2']:
        Vset = float(cmd)
        if Vset < 100.:
            print('not recognized command: \"' + cmd + '\"')
        elif Vset < 200.: # set voltage for channel 1
            V1 = Vset - 100.
            changeV1 = True
        else:          # set voltage for channel 2
            V2 = Vset - 200.
            changeV2 = True
    else:
        if 'test' in cmd.lower():
            print('PZT driver')
        elif 'idn' in cmd.lower():
            print(ID + ',' + SerialNumber + ',' + version)
        elif 'now?' in cmd.lower():
            print(f'{measure100V(analog_1):.2f};{measure100V(analog_3):.2f}')
        elif 'set?' in cmd.lower():
            print(f'{V1:.2f};{V2:.2f}')
        else:
I read something about the input() function blocking the system, but I can't find how to unblock it....
Some help would really be appreciated :D
