IDEAS: ADAFRUIT IO FEATURE SUGGESTIONS
Re: IDEAS: ADAFRUIT IO FEATURE SUGGESTIONS
by ramisthand76 on Tue Mar 08, 2022 10:52 am
Adafruit.io is a cloud service - that just means we run it for you and you don't have to manage it. You can connect to it over the Internet. It's meant primarily for storing and then retrieving data but it can do a lot more than just that!
ramisthand76
by DelarnTheBard on Mon Apr 11, 2022 11:08 am
I would love to make toggles and other input from the dashboar handle dict/json value.
{"temp":"C","grav":"SG","wait_time":30}
and have text input be enterer with a button rather than "enter" on the keyboard
DelarnTheBard
by jwcooper on Tue Apr 12, 2022 3:19 pm
DelarnTheBard wrote:I would love to make toggles and other input from the dashboar handle dict/json value.
You can do that now with the toggle button block. Just paste in that json as the button value. It's one of the text fields that is an option. You can set the 'on' and 'off' values independently of the display text.
jwcooper
by DelarnTheBard on Mon Apr 25, 2022 1:17 pm
a native NoSQL database, so we can make forms like dashboard ?
DelarnTheBard
by pbuelow on Wed Apr 27, 2022 10:28 pm
I have a few hopefully easy feature requests.
* Compass rose graph. I want to push wind direction every now and then and display it as a line pointing to the compass direction in the graph.
* The ability to add a static text/char to variables shown in a text block. If you can do this, I just haven't figure out how. But adding a % or degree symbol to a value would be fantastic.
* Static text as a header to a Dashboard. I'd like to put a small block of text at the top as I want to share one of my Dashboards publicly but with a description. I think I could do this with a header image if I put the text in there, but I think it would be pretty cool to just add text.
Thank you.
pbuelow
by DelarnTheBard on Thu Apr 28, 2022 9:23 am
It only has 2 value. I would need 3 Value. Would be fun to implement a flexible one ;) !!
DelarnTheBard
by D43a89ad20e01ca69CDF on Sun May 15, 2022 1:07 pm
TheCriticalPath wrote:I would love to see the ability to annotate data points in the feed via the API as well as the online portal.
exactly what I am searching for as in
data = {'value': 46 , 'comment': 'something meaningful'}
however your post is two years old, any feedback sofar ?
by vadaparty on Sun May 22, 2022 12:44 pm
Is there a consideration to have Huzzah (ESP 8266) Feather with QT connections?
There are a lot of advantages with the QT (numerous Adafruit sensors connections)...
vadaparty
by brubell on Mon May 23, 2022 9:36 am
vadaparty wrote:Is there a consideration to have Huzzah (ESP 8266) Feather with QT connections?
The ESP32 Feather V2 fits this bill but uses an ESP32 instead of an ESP8266, https://www.adafruit.com/product/5400
The ESP8266 is in the process of being phased out for a newer chipset (ESP32-C3 I believe...). There could be an ESP32-C3 feather with these features in the future, no guarantees though as I do not know the roadmap (esp. with chip availability as it currently stands).
brubell
by vadaparty on Mon May 23, 2022 9:55 am
Thank you
vadaparty
by caroni on Tue Jun 14, 2022 11:26 am
ALTERNATIVES TO PORT 1883 FOR MQTT
I want to create a simple script on my server but my host allows only ports over 50000, 1883 is blocked.
Can't you have alternative ports??
caroni
by brubell on Wed Jun 15, 2022 6:47 pm
caroni wrote:ALTERNATIVES TO PORT 1883 FOR MQTT
Could you please post this in a new thread so I can answer it completely?
brubell
