I believe the ESP32-S2 TFT Feather P/N 5300 I received on order 2846587-7319580171 has a defective TFT display.
1) When I first plugged it in the NeoPixel changed colors but nothing on the TFT display
2) When I loaded ESPHole I got dots on REPL but nothing on the TFT display
3) When I loaded CircuitPython GitHub Stars Viewer I got valid information on REPL but nothing on the TFT display
The backlight TFT LEDs are lit. The WiFi module connects to my WiFi network on items 1 & 2.
Is there any further testing you would like me to do?
Bruce
Defective ESP32-S2 TFT Feather P/N 5300
- Franklin97355
Re: Defective ESP32-S2 TFT Feather P/N 5300
Could you post clear pictures of your board on both sides? I can't think of anything you can do but I don't have one so I'm going to ask others.
- adafruit2
hi - if you double click the reset button (press second time when the purple LED comes on) you dont get a bootloader display?
- blakebr
@adafruit2, I do not. The display is blank.
@franklin97355, Photos attached.
- Attachments
- Back
- unnamed1.jpg (981.19 KiB) Viewed 187 times
- Front
- unnamed2.jpg (948.95 KiB) Viewed 187 times
- adafruit2
ok lets replace it- email support@adafruit for a new one
this board'll still work for other projects, just not the screen part (for some reason!)
- blakebr
adafruit2,
Thank you for your help. I have contacted support as you suggested.
When I receive the replacement and get my project working it is my plan to try and see what is wrong with the first board. It is my guess a faulty solder joint where the ribbon cable connects to the PCB or the TFT display. The TFT display looks to only be glued to the PCB at the end away from the ribbon cable. It is my hope that the glue will release with heat from a hair dryer or the liberal application of 90% isopropyl alcohol. After all, I can't break the TFT display any more than it already is. I will post my results.
Franklin97355, Thank you for your help.
Bruce
Bruce
- adafruit2
could be! good luck :)
