On Saturday, August 13, 2022 we will be working on the Adafruit Customer Support Forums. If you visit over the weekend and things are not complete yet, please check back later, https://adafruit.com/forumupdates
circuitPhyton IOT error: no module named 'socket'
by will22mcneill on Wed Jul 06, 2022 7:09 pm
Guide I'm following: https://learn.adafruit.com/welcome-to-a ... o/overview
I got the quote example to work and get time.
I am running circuitpyton 7.x on feather ESP32 S3
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
# adafruit_circuitpython_adafruitio usage with a CPython socket
import socket
import ssl
from random import randint
import adafruit_requests
from adafruit_io.adafruit_io import IO_HTTP, AdafruitIO_RequestError
# Add a secrets.py to your filesystem that has a dictionary called secrets with "ssid" and
# "password" keys with your WiFi credentials. DO NOT share that file or commit it into Git or other
# source control.
# pylint: disable=no-name-in-module,wrong-import-order
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# Set your Adafruit IO Username and Key in secrets.py
# (visit io.adafruit.com if you need to create an account,
# or if you need your Adafruit IO key.)
aio_username = secrets["aio_username"]
aio_key = secrets["aio_key"]
requests = adafruit_requests.Session(socket, ssl.create_default_context())
# Initialize an Adafruit IO HTTP API object
io = IO_HTTP(aio_username, aio_key, requests)
try:
    # Get the 'temperature' feed from Adafruit IO
    temperature_feed = io.get_feed("temperature")
except AdafruitIO_RequestError:
    # If no 'temperature' feed exists, create one
    temperature_feed = io.create_new_feed("temperature")
# Send random integer values to the feed
random_value = randint(0, 50)
print("Sending {0} to temperature feed...".format(random_value))
io.send_data(temperature_feed["key"], random_value)
print("Data sent!")
# Retrieve data value from the feed
print("Retrieving data from temperature feed...")
received_data = io.receive_data(temperature_feed["key"])
print("Data from temperature feed: ", received_data["value"])
Similar error on CS in
Other IOT codes like this feed example :
# Feed to iot example not running 7-3-2022
# Adafruit IO HTTP API - Feed Interactions
# Documentation: https://io.adafruit.com/api/docs/#feeds
# adafruit_circuitpython_adafruitio with an esp32spi_socket
import board
import busio
from digitalio import DigitalInOut
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi
import adafruit_requests as requests
# has a dictionary called secrets with "ssid" and
# DO NOT share that file or commit it into Git or other
# source control.
print("completed imports")
try:
except ImportError:
    raise
#  If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
# If you have an externally connected ESP32:
# esp32_cs = DigitalInOut(board.D9)
# esp32_ready = DigitalInOut(board.D10)
# esp32_reset = DigitalInOut(board.D5)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
print("Connecting to AP...")
while not esp.is_connected:
    try:
        esp.connect_AP(secrets["ssid"], secrets["password"])
    except RuntimeError as e:
        print("could not connect to AP, retrying: ", e)
        continue
print("Connected to", str(esp.ssid, "utf-8"), "\tRSSI:", esp.rssi)
socket.set_interface(esp)
requests.set_socket(socket, esp)
# Create a new 'circuitpython' feed with a description
print("Creating new Adafruit IO feed...")
feed = io.create_new_feed("circuitpython", "a Adafruit IO CircuitPython feed")
# List a specified feed
# print("Retrieving new Adafruit IO feed...")
# specified_feed = io.get_feed("circuitpython")
print("specified_feed")
# Delete a specified feed by feed key
# print("Deleting feed...")
# io.delete_feed(specified_feed["key"])
print("done")
These give same error for CS_ using either the external or internal board versions. I can not determine which individual pins to try to define for S3 board usage. I will need I2C for intended pressure sensor project. https://learn.adafruit.com/lps35hw-wate ... ure-sensor. Help is greatly appreciated as I am at max frustration level currently.
Reason: Fix code blocks
will22mcneill
Re: circuitPhyton IOT error: no module named 'socket'
by dastels on Wed Jul 06, 2022 7:47 pm
Can you post the REPL output you're getting.
dastels
by neradoc on Wed Jul 06, 2022 8:43 pm
The network situation is a little complicated with CP. These are the wrong examples.
- The first one as mentioned in the comment is "usage with a CPython socket" (C-Python is desktop python, running on linux for example).
- The second one is for ESP32SPI, which is when using an external wifi ESP32 chip.
Here are 2 examples that are written for ESP32 native wifi:
https://github.com/adafruit/Adafruit_CircuitPython_AdafruitIO/blob/main/examples/adafruit_io_http/adafruit_io_simpletest.py
https://github.com/adafruit/Adafruit_CircuitPython_AdafruitIO/blob/main/examples/adafruit_io_mqtt/adafruit_io_simpletest_esp32s2.py
Basically if it uses "socketpool" it's for Circuitpython native wifi.
neradoc
by will22mcneill on Thu Jul 07, 2022 12:47 am
thanks for the response I had not caught on to that naming detail at all.
I'll try on Thursday. Thanks again!!
will22mcneill
by will22mcneill on Thu Jul 07, 2022 2:31 pm
Running the add create feed and get feed example.
in repl get "line 44, in <module>
Not ImplementedError:
so i need more help.
debug output (*******) replaced band words
# SPDX-FileCopyrightText: 2021 Kattni Rembor for Adafruit Industries
Example using create_and_get_feed. Creates a new feed if it does not exist and sends to it, or
sends to an existing feed once it has been created.
import ssl
import socketpool
import wifi
import microcontroller
# "password" keys with your WiFi credentials, and "aio_username" and "aio_key" keys with your
# Adafruit IO credentials, DO NOT share that file or commit it into Git or other
# source control.
try:
except ImportError:
print(
"WiFi and Adafruit IO credentials are kept in secrets.py, please add them there!"
raise
# Connect to Wi-Fi using credentials from secrets.py
wifi.radio.connect(secrets["ssid"], secrets["password"])
print("Connected to {}!".format(secrets["ssid"]))
print("IP:", wifi.radio.ipv4_address)
pool = socketpool.SocketPool(wifi.radio)
requests = adafruit_requests.Session(pool, ssl.create_default_context())
# Obtain Adafruit IO credentials from secrets.py
# Create temperature variable using the CPU temperature and print the current value.
temperature = microcontroller.cpu.temperature
print("Current CPU temperature: {0} C".format(temperature))
# Create and get feed.
io.send_data(io.create_and_get_feed("cpu-temperature-feed")["key"], temperature)
2022-07-07 10:06:09,812 - mu.modes.base:112(open) INFO: Connecting to REPL on port: COM7
2022-07-07 10:06:09,828 - mu.modes.base:130(open) INFO: Connected to REPL on port: COM7
2022-07-07 10:06:09,828 - mu.modes.base:503(add_repl) INFO: Started REPL on port: COM7
2022-07-07 10:06:09,828 - mu.modes.base:474(toggle_repl) INFO: Toggle REPL on.
2022-07-07 10:06:16,679 - mu.logic:1325(check_code) INFO: Checking code.
2022-07-07 10:06:16,679 - mu.logic:1335(check_code) INFO: {15: [{'line_no': 15, 'column': 88, 'message': 'Line too long (90 > 88 characters)', 'code': 'E501'}], 16: [{'line_no': 16, 'column': 88, 'message': 'Line too long (93 > 88 characters)', 'code': 'E501'}], 24: [{'line_no': 24, 'column': 88, 'message': 'Line too long (89 > 88 characters)', 'code': 'E501'}]}
2022-07-07 10:16:04,694 - mu.logic:1416(show_admin) INFO: Showing admin with logs from C:\Users\wilmc\AppData\Local\python\mu\Logs\mu.log
2022-07-07 10:16:04,694 - mu.virtual_environment:922(installed_packages) INFO: Discovering installed third party modules in venv.
2022-07-07 10:16:04,694 - mu.virtual_environment:114(run_blocking) INFO: About to run blocking C:\Users\wilmc\AppData\Local\python\mu\mu_venv-38-20220627-184109\scripts\pip.exe with args ['list', '--disable-pip-version-check'] and envvars {}
2022-07-07 10:16:11,124 - mu.virtual_environment:164(wait) DEBUG: Finished: True; exitStatus 0; exitCode 0
2022-07-07 10:16:11,124 - mu.virtual_environment:249(run) DEBUG: Process output: Package Version
asttokens 2.0.5
backcall 0.2.0
bitstring 3.1.9
black 22.1.0
cffi 1.15.0
click 8.0.4
colorama 0.4.4
******* 36.0.1
decorator 5.1.1
ecdsa 0.17.0
entrypoints 0.4
esptool 3.2
executing 0.8.2
Flask 2.0.3
ipykernel 5.5.6
ipython 8.0.1
ipython-genutils 0.2.0
itsdangerous 2.1.0
0.18.1
Jinja2 3.0.3
jupyter-client 7.1.2
jupyter-core 4.9.2
MarkupSafe 2.1.0
matplotlib-inline 0.1.3
mypy-extensions 0.4.3
nest-asyncio 1.5.4
numpy 1.22.2
parso 0.8.3
pathspec 0.9.0
pgzero 1.2.1
pickleshare 0.7.5
pip 22.0.3
platformdirs 2.5.1
prompt-toolkit 3.0.28
pure-eval 0.2.2
pycparser 2.21
pygame 2.1.2
Pygments 2.11.2
pyserial 3.5
python-dateutil 2.8.2
pywin32 303
pyzmq 22.3.0
reedsolo 1.5.4
setuptools 60.9.3
six 1.16.0
stack-data 0.2.0
tomli 2.0.1
tornado 6.1
traitlets 5.1.1
typing_extensions 4.1.1
wcwidth 0.2.5
Werkzeug 2.0.3
wheel 0.37.1
2022-07-07 10:16:11,124 - mu.virtual_environment:931(installed_packages) INFO: []
2022-07-07 10:37:00,034 - mu.logic:1416(show_admin) INFO: Showing admin with logs from C:\Users\wilmc\AppData\Local\python\mu\Logs\mu.log
2022-07-07 10:37:00,034 - mu.virtual_environment:922(installed_packages) INFO: Discovering installed third party modules in venv.
2022-07-07 10:37:00,034 - mu.virtual_environment:114(run_blocking) INFO: About to run blocking C:\Users\wilmc\AppData\Local\python\mu\mu_venv-38-20220627-184109\scripts\pip.exe with args ['list', '--disable-pip-version-check'] and envvars {}
2022-07-07 10:37:00,616 - mu.virtual_environment:164(wait) DEBUG: Finished: True; exitStatus 0; exitCode 0
2022-07-07 10:37:00,616 - mu.virtual_environment:249(run) DEBUG: Process output: Package Version
asttokens 2.0.5
backcall 0.2.0
bitstring 3.1.9
black 22.1.0
cffi 1.15.0
click 8.0.4
colorama 0.4.4
******** 36.0.1
decorator 5.1.1
ecdsa 0.17.0
entrypoints 0.4
esptool 3.2
executing 0.8.2
Flask 2.0.3
ipykernel 5.5.6
ipython 8.0.1
itsdangerous 2.1.0
****** 0.18.1
Jinja2 3.0.3
jupyter-core 4.9.2
MarkupSafe 2.1.0
nest-asyncio 1.5.4
numpy 1.22.2
parso 0.8.3
pathspec 0.9.0
pgzero 1.2.1
pickleshare 0.7.5
pip 22.0.3
platformdirs 2.5.1
pure-eval 0.2.2
pycparser 2.21
pygame 2.1.2
Pygments 2.11.2
pyserial 3.5
pywin32 303
pyzmq 22.3.0
reedsolo 1.5.4
setuptools 60.9.3
six 1.16.0
stack-data 0.2.0
tomli 2.0.1
tornado 6.1
traitlets 5.1.1
wcwidth 0.2.5
Werkzeug 2.0.3
wheel 0.37.1
2022-07-07 10:37:00,616 - mu.virtual_environment:931(installed_packages) INFO: []
will22mcneill
by neradoc on Thu Jul 07, 2022 6:13 pm
It looks likes it's the microcontroller.cpu.temperature line. CPU temperature is not implemented on the S3 at present time.
It is not available in the stable version of the ESP-IDF used in Circuitpython at this time.
You would need an external temperature sensor if you want to monitor temperature.
neradoc
by will22mcneill on Thu Jul 07, 2022 6:27 pm
Ok thanks. I'll remove it. It was just an easy, I thought, value to use to send to feed as test.
And let me say again how grateful I am for this help!!!
will22mcneill
by will22mcneill on Fri Jul 08, 2022 6:37 pm
I commented out cpu temperature call, and then it fails for: for invalid Api key provided.
I verified my secret aio_key was being passed correctly, and regenerated new aio_key. Same error.
Adafruit_io Request Error: adafruit IO Error 401: request failed invalid API key provided.
So what can i try to do next?
paint copy of the relp output
croped relp output.jpg (112.05 KiB) Viewed 84 times
will22mcneill
by brubell on Mon Jul 11, 2022 11:18 am
brubell
by will22mcneill on Mon Jul 11, 2022 2:44 pm
I finally saw it. In my secret file I had : ' "secret_key" '
Once I removed the ' ' the code worked.
Thanks for all the help. My apologizes for not catching it on my own. I would have given up without the support. Greatly appreciated.
will22mcneill
