Image Trasnfer to eInk Display
adafruit.io help, discussions and more!
Post Reply
K4Kaushik
Post by K4Kaushik »
I have been working on the nRF52832 Blue Feather module, using the BlueFruit Le Connect app I can send images to the module to display on an e-paper display.
But I want to do the same automatically, between two nRF52832 Blue Feather modules.
I found the following instructions, but couldn't implement the same for the nRF52832 module code.
/* The Image Transfer module sends the image of your choice to Bluefruit LE over UART.
 * Each image sent begins with
 * - A single byte char '!' (0x21) followed by 'I' helper for image
 * - Color depth: 24-bit for RGB 888, 16-bit for RGB 565
 * - Image width (uint16 little endian, 2 bytes)
 * - Image height (uint16 little endian, 2 bytes)
 * - Pixel data encoded as RGB 16/24 bit and suffixed by a single byte CRC.
 * Format: [ '!' ] [ 'I' ] [uint8_t color bit] [ uint16 width ] [ uint16 height ] [ r g b ] [ r g b ] [ r g b ] … [ CRC ]
Could anyone help me to how to sent the image bitmap from one nRF52832 Module to another module?
rooppoorali
Re: Image Trasnfer to eInk Display
Post by rooppoorali »
Where are you facing problems? With the image conversion or image transfer?
K4Kaushik
Post by K4Kaushik »
I converted the image into two bitmaps of Red-White (8-bit) and Black-White (8-bit). So I have two uint8_t objects.
But while receiving images using the sample code of Image Transfer, I saw some instructions as I mentioned in the previous post.
As I can't send direct bitmap files (Array/variable) need to add '!', 'I', and the Size of the image before sending it. I need help to send those bitmap files over BLE between two nRF52832 Blue Fruit Modules.
Post Reply
Return to “Internet of Things: Adafruit IO”
