I don't know whether this is the correct forum, but I didn't find a more suitable one.
I installed the Adafruit_BluefruitLE code on the Raspberry Pi 3.
Everytime I launch the list_uarts.py example, everything seems ok, but after a few tens of seconds the code stops with the following error
File "list_uarts.py", line 60, in <module>
ble.run_mainloop_with(main)
File "build/bdist.linux-armv7l/egg/Adafruit_BluefruitLE/bluez_dbus/provider.py", line 118, in _user_thread_main
File "list_uarts.py", line 43, in main
found = set(UART.find_devices())
File "build/bdist.linux-armv7l/egg/Adafruit_BluefruitLE/services/servicebase.py", line 50, in find_devices
File "build/bdist.linux-armv7l/egg/Adafruit_BluefruitLE/interfaces/provider.py", line 110, in find_devices
File "build/bdist.linux-armv7l/egg/Adafruit_BluefruitLE/bluez_dbus/provider.py", line 168, in list_devices
File "build/bdist.linux-armv7l/egg/Adafruit_BluefruitLE/bluez_dbus/device.py", line 53, in __init__
File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 544, in connect_to_signal
dbus_interface, **keywords)
File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 369, in connect_to_signal
**keywords)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 157, in add_signal_receiver
watch = self.watch_name_owner(bus_name, callback)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 373, in watch_name_owner
return NameOwnerWatch(self, bus_name, callback)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 80, in __init__
arg0=bus_name)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 160, in add_signal_receiver
self.add_match_string(str(match))
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 398, in add_match_string
BUS_DAEMON_IFACE, 'AddMatch', 's', (rule,))
File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.LimitsExceeded: Connection ":1.35" is not allowed to add more match rules (increase limits in configuration file if required)
list-uarts.py in Adafruit_BluefruitLE python code on RPi sto
- sthor69
- luopio
- hughanderson
Re: list-uarts.py in Adafruit_BluefruitLE python code on RPi
Hi Sthor69, Luopio,
Sorry for cross post - just saw this one as well. I wondered if you had had any joy getting past this?
I am running a recent copy of bluez/adafruitBLE/Ubuntu/rpi3, and have the same sort of issues.
I am unable to do a connect, and run into this error, using code that works fine on OSX.
Were you able to find a solution/workaround?
One thing that I have noticed different between the OSX and Rpi/Ubuntu versions of my software is that the OSX and Ubuntu/rpi3 versions report just a single advertised service with my BLE device, before and after a connection: [UUID('00002220-XXXX')], but after I try to do a connect, the OSX version continues to report a single service, but the Ubuntu/rpi3 version reports four: [UUID('00001800-XXXX'),UUID('00001801-XXXX'),UUID('0000180a-XXXX'),UUID('00002220-XXXX')]
By the way, I have tried both raspbian and Ubuntu-mate, and also older versions of bluez (5.33), and the same issue happens each time - an error about match-rules when I try to connect...
Cheers Hugh
hughanderson
Cheers Hugh
hughanderson
