The DHT sensor updates appear as expected every 5 minutes and if I toggle the LED Via my dashboard, the feed value updates immediately but there can be very long (several minutes) delays before the LED actually turns on/off on the board. It appears that the delay is in adafruitio call generating the message to my feed. How long should it take?
I am using a feather Huzzah ESP8266 and a DHT11 sensor. The LED is on pin 16, The DHT11 is on Pin2
Am I doing something wrong in my code?
// Adafruit IO Temperature & Humidity Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io-basics-temperature-and-humidity
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016-2017 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
// pin connected to DH22 data line
#define DATA_PIN 2
long previousMillis = 0; // will store last time DTH was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 300000; // interval at which to blink (milliseconds)
// create DHT11 instance
DHT_Unified dht(DATA_PIN, DHT11);
// set up the 'temperature' and 'humidity' feeds
AdafruitIO_Feed *temperature = io.feed("temperature");
AdafruitIO_Feed *humidity = io.feed("humidity");
// digital pin 16
#define LED_PIN 16
// set up the 'digital' feed
AdafruitIO_Feed *digital = io.feed("digital");
// start the serial connection
Serial.begin(115200);
// wait for serial monitor to open
//while(! Serial);
// initialize dht11
dht.begin();
// set led pin as a digital output
pinMode(LED_PIN, OUTPUT);
// connect to io.adafruit.com
Serial.print("Connecting to Adafruit IO");
io.connect();
// set up a message handler for the 'digital' feed.
// the handleMessage function (defined below)
// will be called whenever a message is
// received from adafruit io.
digital->onMessage(handleMessage);
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
delay(500);
// we are connected
Serial.println();
Serial.println(io.statusText());
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;
sensors_event_t event;
dht.temperature().getEvent(&event);
float celsius = event.temperature;
float fahrenheit = (celsius * 1.8) + 32;
Serial.print("celsius: ");
Serial.print(celsius);
Serial.println("C");
Serial.print("fahrenheit: ");
Serial.print(fahrenheit);
Serial.println("F");
// save fahrenheit (or celsius) to Adafruit IO
temperature->save(fahrenheit);
dht.humidity().getEvent(&event);
Serial.print("humidity: ");
Serial.print(event.relative_humidity);
Serial.println("%");
// save humidity to Adafruit IO
humidity->save(event.relative_humidity);
// this function is called whenever an 'digital' feed message
// is received from Adafruit IO. it was attached to
// the 'digital' feed in the setup() function above.
void handleMessage(AdafruitIO_Data *data) {
Serial.print("received <- ");
if(data->toPinLevel() == HIGH)
Serial.println("HIGH");
else
Serial.println("LOW");
// write the current state to the led
digitalWrite(LED_PIN, data->toPinLevel());
