Using Feeds for default settings?
by GregH105 on Wed Mar 22, 2017 8:45 pm
I would like to setup a dashboard on Adafruit.io and have a section or area of "default" or configuration values for my current project.
From what I have read about the Adafruit.io and MQTT if your not currently connected and a value gets sent, the msg is lost, so it might not be possible taking this approach.
For example I need to determine a threshold value over the next few days empirically.
I'm going to assume a default value of 700, but rather than hardcode this value I was thinking of setting up a feed to store the last or current configured threshold value. Then whenever the system turns on, it would get the last value from the feed history and use that.
Any ideas on implementing this?
Thanks in advance,
Greg
GregH105
Re: Using Feeds for default settings?
by jwcooper on Mon Apr 03, 2017 3:01 pm
You could do this quite easily. Follow one of our tutorials to save and retrieve data: https://learn.adafruit.com/series/adafruit-io-basics
Create a feed that contains your configuration data, and save it. Then next time you need the data, you can connect to IO, pull the last value, and then disconnect again.
You could save the data as comma delimited in a single feed, or you could use multiple feeds if you didn't need that many configuration options.
jwcooper
by jacobgarner123 on Mon Jul 02, 2018 6:44 pm
jwcooper wrote:
...you can connect to IO, pull the last value, and then disconnect again.
Can you explain how to do this?
jacobgarner123
by brubell on Tue Jul 03, 2018 10:05 am
Could you provide the client library you are using (Adafruit IO Arduino, IO Python, raw API calls?) and the board?
Using the Adafruit IO API, you can make a call to previousData to obtain the previous data point in the data feed:
https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data/previous
https://io.adafruit.com/api/docs/#opera ... eviousData
Here's an example of getting previous data from the Python client:
https://github.com/adafruit/io-client-p ... ata.py#L46
brubell
by jacobgarner123 on Fri Jul 06, 2018 12:45 am
Thanks for the reply. I am using a Node MCU V1.0 in the Arduino IDE. I actually ended up just using raw API calls with the ESP8266HTTPClient library, since that makes the most sense to my brain. :)
jacobgarner123
