Parts included here are:
1. The output as seen using the serial monitor
2. The arduino script used to generate the output and error
3. The debug additions to Adafruit_MQTT_Client.cpp (add Serial.print in strategic places)
4. The debug additions to Adafruit_MQTT.cpp (add Serial.print in strategic places)
5. Version information
Any help and/or suggestions will be greatly appreciated
Connecting to WiFi-AP
WiFi connected
IP address:
192.168.0.13
Sending to MQTT broker:sizeof(strObj): 240
strObj: {"BMPTempValue":27.70,"BMPpressureValue":988.28,"BMPaltitudeValue":210.00,"DHT22tempValueC":27.00,"DHT22tempValueF":80.60,"DHT22heatIndexValueC":27.45,"DHT22heatIndexValueF":81.41,"DHT22humidityValue":50.50,"BatteryValue":86.27}
Adafruit_MQTT_Client::connected()
Connecting to MQTT... Adafruit_MQTT_Client::sendPacket(uint8_t *buffer, uint16_t len)
len: 30
len is > 0
client->connected() = true
Sending: 30
MQTT Connected!
connected so wait half sec then publish strObj to weatherOne
Adafruit_MQTT::publish(const char *topic, const char *data, uint8_t qos)
Topic: trevor/feeds/weatherOne
Data: {"BMPTempValue":27.70,"BMPpressureValue":988.28,"BMPaltitudeValue":210.00,"DHT22tempValueC":27.00,"DHT22tempValueF":80.60,"DHT22heatIndexValueC":27.45,"DHT22heatIndexValueF":81.41,"DHT22humidityValue":50.50,"BatteryValue":86.27}
Adafruit_MQTT::publish(const char *topic, uint8_t *data, uint16_t bLen, uint8_t qos)
bLen: 228
QOS: 0
uint16_t len = publishPacket(buffer, topic, data, bLen, qos); len = 256
DOING - if (!sendPacket(buffer, len)) return false
len: 256
len is > 0
Exception (9):
epc1=0x402030a9 epc2=0x00000000 epc3=0x00000000 excvaddr=0x35342e37 depc=0x00000000
ctx: cont
sp: 3ffef830 end: 3ffefaa0 offset: 01a0
>>>stack>>>
3ffef9d0: 3ffe8afc 3ffeea48 00000100 402030a6
3ffef9e0: 3ffee88e 3ffe8678 3ffeea48 402033c8
3ffef9f0: 00000100 3ffee88e 3ffeea48 3ffee86c
3ffefa00: 00000100 3ffee88e 3ffeea48 40202cf9
3ffefa10: 00000000 3ffe8678 3ffe834c 402033c8
3ffefa20: 00000003 0000001b 3ffeea48 00000000
3ffefa30: 3ffe8678 3ffe834c 3ffeea48 40202dc9
3ffefa40: 3ffee86c 3ffe834c 3ffeea48 4020339d
3ffefa50: 3ffe8618 3ffeea74 3ffeea48 3ffeea74
3ffefa60: 3fffdad0 3ffe834c 3ffeea48 40202f2a
3ffefa70: 3fffdad0 3ffe834c 3ffeea48 40201de0
3ffefa80: 3fffdad0 00000000 3ffeea6c 40203778
3ffefa90: feefeffe feefeffe 3ffeea80 40100718
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,1)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v09f0c112
~ld
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#define WLAN_SSID "---your ssid---"
#define WLAN_PASS "---your passphrase---"
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 1883
#define AIO_USERNAME "---your username---"
#define AIO_KEY "---your key---"
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
Adafruit_MQTT_Publish weatherOne = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/weatherOne");
char strObj[240] = "{\"BMPTempValue\":27.70,\"BMPpressureValue\":988.28,\"BMPaltitudeValue\":210.00,\"DHT22tempValueC\":27.00,\"DHT22tempValueF\":80.60,\"DHT22heatIndexValueC\":27.45,\"DHT22heatIndexValueF\":81.41,\"DHT22humidityValue\":50.50,\"BatteryValue\":86.27}";
Serial.begin(115200);
delay(10);
// Connect to WiFi access point.
Serial.println(); Serial.println();
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println();
Serial.println("WiFi connected");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
Serial.print("Sending to MQTT broker:");
Serial.print("sizeof(strObj): ");Serial.println(sizeof(strObj));
Serial.print("strObj: ");Serial.println(strObj);
MQTT_connect();
Serial.print("connected so wait half sec then ");
delay(500);
Serial.println("publish strObj to weatherOne");
bool publishResult = weatherOne.publish(strObj);
Serial.print("Publish results is: ");
if (publishResult) {
Serial.println("OK");
} else {
Serial.println("Failed!");
delay(2000);
void MQTT_connect() {
int8_t ret;
// Stop if already connected.
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT... ");
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000); // wait 5 seconds
retries--;
if (retries == 0) {
// basically die and wait for WDT to reset me
while (1);
Serial.println("MQTT Connected!");
Note the changes are addition of Serial.print and Serial.println lines only!
..... no changes to original library code above this function .....
bool Adafruit_MQTT_Client::connected() {
Serial.println("Adafruit_MQTT_Client::connected()");
// Return true if connected, false if not connected.
return client->connected();
uint16_t Adafruit_MQTT_Client::readPacket(uint8_t *buffer, uint16_t maxlen,
int16_t timeout)
..... no change to this function ......
bool Adafruit_MQTT_Client::sendPacket(uint8_t *buffer, uint16_t len) {
Serial.println("Adafruit_MQTT_Client::sendPacket(uint8_t *buffer, uint16_t len)");
uint16_t ret = 0;
Serial.print(" len: "); Serial.println(len);
while (len > 0) {
Serial.println(" len is > 0");
Serial.print(" DOING - if (client->connected()) returns: ");
if (client->connected()) {
// send 250 bytes at most at a time, can adjust this later based on Client
Serial.println("true");
uint16_t sendlen = min(len, 250);
Serial.print(" Sending: "); Serial.println(sendlen);
ret = client->write(buffer, sendlen);
DEBUG_PRINT(F("Client sendPacket returned: ")); DEBUG_PRINTLN(ret);
len -= ret;
if (ret != sendlen) {
DEBUG_PRINTLN("Failed to send packet.");
return false;
} else {
Serial.println("false");
DEBUG_PRINTLN(F("Connection failed!"));
return false;
return true;
..... end of Adafruit_MQTT_Client.cpp
bool Adafruit_MQTT::publish(const char *topic, const char *data, uint8_t qos) {
Serial.println();
Serial.println("Adafruit_MQTT::publish(const char *topic, const char *data, uint8_t qos)");
Serial.print(" Topic: "); Serial.println(topic);
Serial.print(" Data: "); Serial.println(data);
return publish(topic, (uint8_t*)(data), strlen(data), qos);
bool Adafruit_MQTT::publish(const char *topic, uint8_t *data, uint16_t bLen, uint8_t qos) {
Serial.println();
Serial.println("Adafruit_MQTT::publish(const char *topic, uint8_t *data, uint16_t bLen, uint8_t qos)");
Serial.print(" bLen: "); Serial.println(bLen);
Serial.print(" QOS: "); Serial.println(qos);
// Construct and send publish packet.
Serial.print(" uint16_t len = publishPacket(buffer, topic, data, bLen, qos); len = ");
Serial.println(" DOING - if (!sendPacket(buffer, len)) return false");
return false;
Serial.println(" sendPacket returned true");
// If QOS level is high enough verify the response packet.
if (qos > 0) {
len = readFullPacket(buffer, MAXBUFFERSIZE, PUBLISH_TIMEOUT_MS);
DEBUG_PRINT(F("Publish QOS1+ reply:\t"));
DEBUG_PRINTBUFFER(buffer, len);
if (len != 4)
return false;
if ((buffer[0] >> 4) != MQTT_CTRL_PUBACK)
return false;
uint16_t packnum = buffer[2];
packnum <<= 8;
packnum |= buffer[3];
// we increment the packet_id_counter right after publishing so inc here too to match
packnum++;
if (packnum != packet_id_counter)
return false;
return true;
..... no changes to original library code below this point .....
Arduino v1.8.1 on Windows 10 64bit
ESP8266WiFi Built-In by Ivan Grokhotkov Version 1.0.0
Adafruit MQTT library by Adafruit Version 0.17.0
