I am trying to get the above mentioned script working on a MKR1000 arduino.
It compiles without error but wont connect to my dashbord.
What must i do???
Adafruit IO Temperature & Humidity Example on MKR1000
- GHARRYH1957
- Wellsey1972
Re: Adafruit IO Temperature & Humidity Example on MKR1000
you need to do this part listed on github https://github.com/adafruit/Adafruit_IO_Arduino
"You will also need to add the SSL certificate for io.adafruit.com using the MKR1000 SSL utility."
Follow this guide and it should work
https://www.arduino.cc/en/Tutorial/FirmwareUpdater
Happy Sensing.
Happy Sensing.
